928 Forum 1978-1995
Sponsored by: 928 Specialists
installing AEM wideband
Old 05-18-2006, 06:16 PM
zoltan944
zoltan944's Avatar
Default installing AEM wideband
i am going to be putting in a wideband on the 85. It really helps diagnosis of problems and i will be putting boost on it in the near future. My question is do you think i should add a bung and put this in, or should i replace the narrow band with this one and wire the incoming signal to the computer for accurate input?
what wire would i tap on the LH to 'give' it the signal? (id rather 'tap' in the brain signal than hack up my wires under the car
Old 05-18-2006, 06:55 PM
Rob M Budd
Rob M Budd's Avatar
I'd add a bung.
I'm pretty sure the two use two different voltages. The wide band is 0-5volts and the narrow band is 0-1volt.
I suspect you will have to adjust the signal so the brain can read it.
Some wide bands come with processors that change the signal down to 0-1volt. Some don't.
Old 05-18-2006, 06:57 PM
John Veninger
John Veninger's Avatar
Most WB units have a (0-1v)NB output to feed "stock" computers.
Old 05-18-2006, 07:29 PM
jeff jackson
jeff jackson's Avatar
Unless you are sending the wideband sensors output to a datalogger...or a standalone fuel management computer...whats the point ? It won't improve the fuel management of the factory LH controller.. I see you will be adding boost in the future. So perhaps your goals are for this. BUT...even when you do, it will only allow the stock LH unit to respond within its preprogrammed ( by the EPROM chip) limitations. So don't expect any gains from a wideband,(other thn Datalogging capability, with separate software and hardware) unless you are completely switching the system over to a "standalone"...or aftermarket fuel injection controller... Good Luck. I hope this works out well for you.
Old 05-18-2006, 07:44 PM
MarkRobinson
MarkRobinson's Avatar
Use a separate bung for the O2 like I did with my AEM. This leaves the factory O2/closed-loop feeback & the shielded lines in place: otherwise you're looking for trouble.
Most xhaust places charge $5-10 to add a bung.
Old 05-18-2006, 07:56 PM
zoltan944
zoltan944's Avatar
jeff- not looking for gains. with how old are cars are, a wideband can really help in diagnosis. take all of the post on here for examples. thats all. when the boost does come, obviously its for 'tuning' and safety readings. the only thing about tying it in was overriding the possibly OLD sensor with a super better version
Mark: I think i am just gonna order my X-pipe with one in it, a couple of the places will do that when you order the x-pipe. or i can take it down to someone off the car and it be really easy
Old 05-18-2006, 08:02 PM
FlyingDog
FlyingDog's Avatar
That's what I'd do.
Old 05-18-2006, 08:04 PM
zoltan944
zoltan944's Avatar
Originally Posted by FlyingDog
That's what I'd do.
know what wire i need to tap?
Old 05-18-2006, 08:09 PM
FlyingDog
FlyingDog's Avatar
For your 82 there should only be 1 wire on the O2 sensor, just connect the narrowband output on the AEM to that. For the 3 wire on the 85, black is signal. I'm assuming the AEM has a narrowband output since, like John said, most do.
Old 05-18-2006, 08:11 PM
zoltan944
zoltan944's Avatar
ok, its for the 85 so im sure its the black one then
Old 05-18-2006, 08:13 PM
FlyingDog
FlyingDog's Avatar
I just checked the wire diagrams. On the harness side, it's a shielded green wire. On the O2 side, it's should be black. Black on the harness side is power for the sensor heater, it would be bad to hook that to the AEM.
Old 05-18-2006, 09:46 PM
SwayBar
SwayBar's Avatar
Absolutely. Add a bung for the new wide band, and use the existing narrow band for the computer; you will be much happier in the long run from less headaches.
Old 05-18-2006, 09:55 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Instead of leaving the old O2 in, you can just replace your old with a brand new one. I woudl say that this is a must for a boosted 928. If you keep the old O2 the LH might be getting an inaccurate reading.
On my SC'd '85, I've replaced my 02 with a single wire unit and it works fine. Much more resposive than the old one. The heaters on the 3 wire O2 are not necesarry. The singel wire will come up to operating temp about 30 sec later than the heated one. Once it's hot it works exaclty like a 3 wire. Single wire O2s are around ~$10-$15.
Old 05-18-2006, 10:05 PM
SwayBar
SwayBar's Avatar
WOT is mission-critical on any car let alone a boosted one. Nonetheless, at WOT, the LH-equipped engine is open-loop, meaning that the O2 sensor is ignored, and the engine gets it's fueling information from maps on the EPROM based upon MAF voltage and RPM.
With that said, a fresh O2 sensor is a good idea in any car; idle and cruise air/fuel will be spot-on as a result.
Old 05-18-2006, 10:45 PM
mspiegle
mspiegle's Avatar
I installed a TechEdge wideband setup on my car in the stock O2 location and used the NB-Simulated signal to feed the LH. Never had a problem with it.
Quick Reply: installing AEM wideband
