Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Old 10-09-2006, 05:21 AM   #1
Nicole
Nicole's Avatar
Default 928 Interior Decorating and Improved Shifting - Version 2.0
I got lots of compliments on my interior decoration project described in the following thread:
http://forums.rennlist.com/rennforum...d.php?t=170073
But somehow I felt it was time to take things to the next level. So I decided to order an authentic wood kit for my car to replace the synthetic wood I already had. My initial plans was to order African Rose, which is not too dark, has a very warm tone to it, and is very lively. It had always been one of my favorites, and is very close to the factory rootwood color.
Then I found out that Jager had a special wood called "Bloody Burl" available in very limited quantity. In fact, there was only enough wood for two kits. And it was said to be very dark and very red. So I thought a wood that's dark and red could make a very nice contrast to my classic grey interior, and I ordered a kit sight unseen.
When it arrived, I really fell in love with its color, so when Roger Tyson called me a few days later to inquire about wood options for his black/red GTS, I offered him the second set. Can't wait to see how it turns out in his car!
Anyway, the kit sat in my garage for a few weeks before I finally got around to tear apart my center console and trace some slow vacuum actuator leaks. This was the time to fix, clean and redecorate the interior, and you can see the results below.
For demonstration purposes, I used all pieces of the 22-piece base kit, plus the seat switch surrounds and the new rear AC trim. The latter was of particular importance to me, because its thickness offers great protection for our delicate rear AC vents.
In order to make servicing of the AC control unit easy, I used rubber cement to attach the upper console trim piece. This way, I can remove and reattach it easily when needed - without any risk of damage to the wood. The trick is to put the rubber cement on both the back of the trim piece and the surfaces it will be attached to.
Following my philosophy of minimizing interior colors, I was thinking of adding a leather shift plate matching my interior color. However, in the end I decided to add a bit of contrast with an aluminum shifter plate. This would also go best with the silver Tip Shifter I planned to use.
Another goal of the "remodel" was futher enhancement of driving pleasure (in German: "Fahrvergnügen", or "Fahrspass"): I wanted to get rid of the slider in the factory shift plate, as it makes shifter movement real jerky. I used a spare shifter plate to dissect and install a custom dyed full leather boot. I drove the car for two days now, and can't believe what a difference this modification makes in shifter feel. Now it's even more fun to shift manually!!!
So here is the result. Let me know what you think!
PS: If you plan an interior upgrade for your car, please contact me. Based on your 928 model and interior coloring, we can find materials and products that enhance the beauty of your interior, and make it look more up-to-date. Most products I offer do not require any modifications to the car and can be removed without trace, if the need should ever arise.
Nicole
'91 928 S4, slate grey metallic / all classic grey, GTS mirrors, 17" 'Turbo Twist' rims, Custom Wood Interior Trim
'95 900 SE, dark green metallic (waSAABi)
This one after I won the lottery
Clear/smoked lenses, books, and accessories:
www.HookedOnCars.com
New:
Porsche 928 Book by Brian Long
Smoked lenses and marker lights
AutoArt 928 1:18 and 1:43 Scale
Nicole is offline   Reply With Quote
Old 10-09-2006, 05:45 AM   #2
Nicole
Nicole's Avatar
And then, because I had so much fun, I decided to add a little bit of pizzaz to my engine compartment with the Engine Compartment Lettering for the Intake Manifold.
Similar letters are also available for the cam covers - in red, black, or chrome.
Nicole
New:
Old 10-09-2006, 05:58 AM   #3
Champagne
Champagne's Avatar
That turned out really well Nicole
Well done
Paul
1988 S4 AT Expresso
Custom Ostrich Interior.
Champagne is online now   Reply With Quote
Old 10-09-2006, 09:39 AM   #4
fbarnhill
fbarnhill's Avatar
Nicole, it looks great. You have realy good taste when it comes to matching things to make them look factory
Frank Barnhill
79 Euro AT
fbarnhill is offline   Reply With Quote
Old 10-09-2006, 10:04 AM   #5
Normy
Normy's Avatar
That looks every bit as good as you described Nicole!
The rear-AC covering is particularly nice, but your shifter mod is the best I've ever seen in one of these cars. You can tell a good modification easily- it looks factory, not "added on" and the shifter in particular fits this perfectly.
That shifter knob: Do you think they make one in champagne and brass instead of gray and silver? Where did you find this?
N!
Normy is offline   Reply With Quote
Old 10-09-2006, 11:03 AM   #6
MGW-Fla
MGW-Fla's Avatar
That looks absolutely AWESOME Nicole! I just ordered some more Jager stuff last week, including more interior pieces! Their stuff is first class all the way & they offer things for our sharks that aren't available anywhere else!
Mel
'85 928S; #333; 32V; AT; DunkelBlau/Champagne; Xpipe; AA chipped; Jager mods; Kinesis K28R wheels.
'91 928S4; #364; AT; Grand Prix white/dark blue; wife's.
'03 Roush Stage II Ford Mustang GT; silver/black; son's.
'99 VW Jetta VR6; gold/tan; daughter's.
'85 928S; #1076; 32V; AT; gold/brown;(Adopted Out).
'90 911/964; Cab.; Linen/Linen;(911 Heaven).
'04 BMW Z4 Roadster; 3.0; silver/black; (sold).
928 Owners Club - Fla Rep
MGW-Fla is offline   Reply With Quote
Old 10-09-2006, 12:06 PM   #7
ROG100
Nicole,
Awesome - Once I receive my leather dash and console from Paul I will install my set.
Well done.
Roger
Roger Tyson
www.928sRus.com
Email Roger@928sRus.com or call 817 430 2688
SPEC Clutches & Lightweight Flywheels at awesome prices
Porsche 928 Parts - Porsche & OEM - World Wide Shipping
85 to 95 Fuel Hose Kits - Save your car Ford Injector O Rings
Motor Mounts, Silicone Pan Gasket & Stud Kits
MotorSport SLC X & Y Pipes in stock - BEST PRICES
Replacement Diaphragms for the Center, Footwell & Recirc actuator
ROG100 is offline   Reply With Quote
Old 10-09-2006, 12:10 PM   #8
Joe '87 S4
Joe '87 S4's Avatar
That looks really nice. Did they always offer the rectangle center vent piece or is that a new option?
Black/Black 1987 S4 Auto
Joe '87 S4 is offline   Reply With Quote
Old 10-09-2006, 12:16 PM   #9
Chuck Schreiber
Chuck Schreiber's Avatar
Nicole,
Looks good!!! I really like the shifter!!!
Chuck S.
79 5spd SilverBulit
94 5spd Charlie Car
Chuck Schreiber is offline   Reply With Quote
Old 10-09-2006, 02:32 PM   #10
SharkSkin
SharkSkin's Avatar
Send a message via ICQ to SharkSkin Send a message via AIM to SharkSkin Send a message via MSN to SharkSkin Send a message via Yahoo to SharkSkin
Very sharp, Nicole! Are you going to hand out drool bibs at Sharktoberfest for people who want to ogle your interior?
Dave A.
1978 928 5spd
My 928 Site
Anyone who is capable of getting themselves made President should on no account be allowed to do the job.
--Douglas Adams
There is no doubt about precisely when folks began racing each other in automobiles.
It was the day they built the second automobile.
--Richard Petty
SharkSkin is offline   Reply With Quote
Old 10-09-2006, 03:08 PM   #11
dr bob
The Doctor is IN
dr bob's Avatar
Nicole--
Have you and Paul looked at matching wood inserts for the knobs in the console? The wood looks spectacular in your car, but... The pictures with the great wood inserts make the knobs for the fan, rear AC, Rear AC temp look way out of place. It was easy for the factory to settle on easy-to-match no-glare black. Now your new wood bits push you dangerously close to the edge of a very slippery slope. On that slope are the above-mentioned knobs, the slider knobs with mini-LED's embedded in the ends, and either a blanking plate for the radio or a trim piece that covers at least the outside frame for the DIN-sized perimeter.
Your choice of the extra-dark wood with red in it is excellent.
For contrast, I've been spending the last week+ of "spare time" refinishing the larger of the two wood garage doors. It's 18' wide, in a red cherry finish. It doesn't have quite the finish quality that your dash pieces have, though. It's hard to find 18' burls...
'89 S4 Auto, black
928OC Charter Member
SoCal 928 Co-Founder
PCA SGVR Member
Chairman, Glendale Yacht Club
Free advice and experience, with absolutely no relationship to real-world conditions. No warranty of any kind expressed or implied. Use at your own risk. Small parts may cause choking hazard. Harmful or fatal if swallowed.
Visit the SoCal928 group at http://socal928.com/
dr bob is offline   Reply With Quote
Old 10-09-2006, 05:37 PM   #12
DSC928
Quote:
Originally Posted by Chuck Schreiber
Nicole,
Yeah nice shifter........Where is that on your site? I couldn't find it at "hookedoncars" or the Jager site. ????
Russell P. Wittenberg
current lot
'06 Cayman S
'85 Euro Prussian 5spd
past transgressions
'94 GTS Polar Silver (92M)/ Classic gray
'97 993 Forest Green
'86 944 Turbo Zermatt
'86.5 928 Red/Tan Therapy complete, adopted out to new home
'91 928GT, Black/Light gray w/ black piping.....sold
'88 928S4, Dark Blue/Light gray w/ Blue piping.....sold
DSC928 is offline   Reply With Quote
Old 10-09-2006, 05:44 PM   #13
Bill Swift
Fleet of Foot
Bill Swift's Avatar
Very nice Nicole, can't wait to see it in person!
Bill
'89 S4 Automatic, Black on Black on Black
"...the triple distillation of evil, the baddest machine on any block..."
1990 Miata, you guessed it, Classic Red SCCA SOLO
Avatar: PCH just south of Half Moon Bay, DEVEK Days 2006
Photo taken by George Suennen
When the people fear their government, there is tyranny; when the government fears the people, there is liberty.
Thomas Jefferson
Bill Swift is offline   Reply With Quote
Old 10-09-2006, 07:28 PM   #14
Charley B
Charley B's Avatar
Looks terrific Nicole. Did you end up placing the trim at the back of the shfter area under the center consol piece? I'm assuming, to make mine look right, that is what I need to do. The red works out much better than I had imagined when you told me about it. Very impressive.
Charley
There is something about the outside of a 928, that's good for the inside of a man.
'93 GTS 5 spd
'88 S4 Auto Red
'82/'83 Euro Track Car
'55 T-Bird (Show Car)
'01 Town Car (Myrtle the Turtle)
'03 Deville (Plain Jane)
'90 Harley Springer Softail
'90 Harley 1200C Chopper
Charley B is offline   Reply With Quote
Old 10-09-2006, 07:35 PM   #15
IcemanG17
IcemanG17's Avatar
Nicole
Looks great.....I like it better than the medium dark wood you had before.....bummer there was only two kits!
Brian
Co-founding member of the "Stockton Sharks Society"
89 S4 5 speed track beast!!!! BLACK WIDOW 360HP(in rehab..AGAIN)
79 5 speed....
84 auto lemons project part deux 189whp 246torque
2008 BMW M3 V8 coupe, Melbourne red, Bamboo Beige extended leather, DCT, 19" wheels, loaded!! Corsa Exhaust=445HP!!
06 Acura TL (Wife)
02 Saturn SC2 (Sold)
92 Daihatsu Charade (G-Ride) 1.0L 3 cyl!! RETIRED
88 S4 Guards Red/Champagne Leather (gone to a new home)
IcemanG17 is online now   Reply With Quote
Tags
1978, 928, 928s, black, boot, custom, decor, decorating, filetype, frame, interior, jpg, plates, porsche, shift, shifter, speed, trim, wood
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
