928 Forum 1978-1995
Sponsored by: 928 Specialists
Removing steering wheel lock
Old 12-17-2006, 04:44 PM
Benton
Benton's Avatar
Default Removing steering wheel lock
I want to do this on my race car for several reasons. Can anyone guide me in the right direction? Thanks in advance.
Old 12-18-2006, 11:24 AM
Benton
Benton's Avatar
Anyone? This would really help me out.
Old 12-18-2006, 11:36 AM
the flyin' scotsman
the flyin' scotsman's Avatar
Not sure about the 928s but on the Chevs I've worked on the steering lock is in the steering column part of the ignition switch assembly.
Old 12-18-2006, 11:50 AM
the flyin' scotsman
Just checked PET.........looks as if there's a cam, a dowl pin and a steering lock assembly in the steering column.
Old 12-18-2006, 02:41 PM
Benton
Benton's Avatar
Thanks, Malcolm. I don't have PET; does it show where the dowel pin is located so that I can cut it off? I'm guessing it is similar to a 944, but the description isn't exactly the same. I'm going to go check it out and just start tearing into. I need to find my shop manuals, but I'm not sure if they will help me.
Old 12-18-2006, 03:23 PM
the flyin' scotsman
Mark..........PET clearly shows where the dowel pin is located on MG 4 SG 03 ill. 403-05. I have it softcopy but don't know how to copy the image into a post; perhaps someone else can provide instruction.
Old 12-18-2006, 07:57 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
the control cam is from the ignition lock to the igniton electrical switch the cam on the connector pushes the shuttle / spring so it engages the teeth on the steering column locking it. If you remove the control cam and grind off the cam part it will not push on thr shuttle and the wheel will not lock You then could ALSO drill a hole through the shuttle and housing to secure the shuttle from moving. The control cam loocks like the one in the link...http://www.mailordercentral.com/928i...928 347 755 02
To access you will be removing the pod and the ignition lock ....
Old 12-18-2006, 08:10 PM
Benton
Benton's Avatar
Thanks a bunch, Jim. I really appreciate it. I'll probably be doing this tomorrow, I'll post back up with the results or any questions.
Old 10-23-2023, 02:40 PM
S4-on-your-back-door
S4-on-your-back-door's Avatar
On an 87 s4. There isn't a gold plug on the ignition side by the steering column. Drill that off center towards the steering wheel and driver's door with a small 16 inch drill bit into it drops in. Be careful if you're trying to retain the steering lock for the future. After that I Reed the hole within 8 inch drill bit until I could see the mechanism move back and forth with the key
. At that point I took a self-tapping screw and slowly screwed it up until the mechanism wouldn't latch the steering wheel.
Quick Reply: Removing steering wheel lock
