928 Forum 1978-1995
Sponsored by: 928 Specialists
Aero underbody pics
Old 01-21-2007, 04:41 AM
slate blue
slate blue's Avatar
Default Aero underbody pics
Guys has anybody got underbody pics of new top end supercars, e.g Enzo, 599, 575, Zonda, Aston Marton etc? I have requested some pics from Ferrari and will post them if I get a response, that is if there is any interest of course, please anybody with pics post away! I will see what I can find.
Thanks Greg.
P.S I think I need counselling, I'm spending too much on this car, $10K this month alone, so maybe I should ask for pics and counselling???
Old 01-21-2007, 05:56 AM
danglerb
danglerb's Avatar
$10k this month on underbody pics is a bit high, not sure where you might find a counselor for that though.
Old 01-21-2007, 08:42 AM
dpritch
dpritch's Avatar
Wink
Supercar underbody pics? Wouldn't you find that at an automotive **** site?
Old 01-21-2007, 08:49 AM
C.F.
C.F.'s Avatar
Is a 207 MPH underbody any good for you Greg ?
McLaren Mercedes SLR
Very plain , completely flat , no side skirts, only vents appear to be at rear of engine & they sit proud of the surface. The bolts apart from the ones at the front are standard size 13mm hex head , you'd have thought they would have used mushroom allen headed bolts.
Old 01-21-2007, 09:01 AM
Mike Frye
Craic Head
Mike Frye's Avatar
Greg,
Repeat after me,: 'Hi my name is Greg and I have a problem... '
Old 01-21-2007, 09:12 AM
Rick Carter
Rick Carter's Avatar
Greg,
When you're done, and have tested stability at high 150-200mph direstion changes, post your pics. A WIAT for me is having a plate made to extend back from the stock 85/86 mini cover. I looked at the underside of the car while it was on the lift and it doesn't look easy to make a front to back undercover, let alone figuring out the correct shape. My cover will only extend to the support points at the back of the engine similar to the S4+. It would be nice to have an effective diffuser to clean up the rear airflow.
Old 01-21-2007, 12:54 PM
perrys4
The Lady's Man
perrys4's Avatar
Try googling pikes peak racers for shots like that, They use aero to vaccumm them to the road.
Old 01-21-2007, 02:56 PM
ew928
Owns the Streets
Needs Camber
ew928's Avatar
I'm guessing flat plate from back of bellypan to rear suspension/gearbox area.
Ducts (NACA?) to draw heat out from the cat/exhaust area.
Then diffuser to a trimmed back rear bumper cover.
The fuel tank/external pump sits low and may get in the way of an efficient diffuser design.
May need more vents/ducts by the tranny to keep it cool.
Ernest (NYC) Just speculating. Nothing like the downforce generating ducted fans from the Can Am crazy days.
Old 01-21-2007, 03:10 PM
PorKen
Inventor
PorKen's Avatar
They are using plain aluminum tread plate! I suppose that makes some boundary layer turbulence, but easier than putting dimples all over the surface.
The header vents are plain louvered vents. It looks like the rear brakes have curved diverters.
At the stock ride height, there's plenty of room under a 928 for a pan like this...
Old 01-21-2007, 03:52 PM
slate blue
slate blue's Avatar
O.K thanks for the SLR pics
Here's some pics of the 599
Unfortunately I don't have the last one for the diffuser but here is one for the Enzo.
Hope this is helpful to anyone working on an aero program, I will add some other stuff later. Please keep those pics coming.
Old 01-21-2007, 03:57 PM
PorKen
Inventor
PorKen's Avatar
The rear channels are interesting on that 599. Curved at the front, they are channeling air that is pulled in forward of the rear wheels.
Old 01-21-2007, 04:24 PM
RSKY BIZ
Shark Slayer
RSKY BIZ's Avatar
Location: 'BETWEEN NORTH STAR BOROUGH...& THE CONCH REPUBLIC'
Default CLOSE, BUT . . .
I'll try to make it a point to 'crawl under' for ya next time! Here's what I got...
Old 01-21-2007, 04:41 PM
mark kibort
mark kibort's Avatar
No need for this underbody stuff for our uses, even on a road race car . It's just drag and a small amount at that. however if you are trying to get to the 185 to 200mph range on a regular basis, then it probably becomes important. remember the drag of my rear wing??? This is much more drag than the underbody would prevent. look at the drag coefficient of a ferarri vs our 928s4. what, .29 vs .32? not a lot. a wing will bring the Cd to .36. At 100mph, total wing drag would be near 25lbs. through a 4.5:1 reduction in 3rd gear, thats 5ft-lbs of torque lost. Now, at 200mph, it would be near 20ft-lbs and that becomes subtantial. However, the underbody , uncovered, doesnt create as much drag as a racing wing. Its only a parasitc drag. a boundary layer drag and its total effects are relatively small.
sure it looks cool under the car, but I'd be more worried about your windshield wipers and the older mirrors!
also notice the vents in the engine area of the underpanel tray. its venting frontal pressure that builds in the engine compartment to underneath the car. (bad for downforce and bad for drag) the diffuser toward the rear is to accelerate the flow under the car for lower pressure for that flow, and the pressure raises as it exits the rear of the car. those underbody panels are mainly for keeping the engine parts cleaner.
mk
Old 01-21-2007, 06:04 PM
C.F.
C.F.'s Avatar
The tread plate is the bed of the truck, you are seeing its reflection .
Old 01-24-2007, 05:42 AM
slate blue
slate blue's Avatar
Searched some downforce figures for the Ferraris, these figures come from the Ferrari chat site, They are said to be taken at 300 kph.
Model = lbs = kg
F355 = 220 = 100
360S = 374 = 170
360M = 397 = 180
F430 = 550 = 252
F430 = 573 = 260
CS__ = 592 = 270
599 = 419 = 190
F50_ = 683 = 310
Enzo = 1710 = 775
F1 car 3310 =1500
The photo below shows the 355's underbody, basically flat with no diffusers,
The next drawing is that of the Enzo
This from Auto Motor und Sport
Enzo from AMS :
@200km/h - 344kg
@300km/h - 775kg
@350km/h - 585kg
The reason for the differing figures is
Cheers Greg
Quick Reply: Aero underbody pics
