classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat     |
Sign in using an external account
| This Rennlist Forum is sponsored by | ![]() | ....dedicated to Your Porsche 928 |
Thread Tools | Search this Thread |
#1 |
Rennlist Member Join Date: Jan 2002
When driving along in fairly low RPM in a higher gear, I'll give the car some gas and a vibration resonates from the transmission that sounds like an accelerating F350 diesel truck. Is this considered "chatter" or is this some other vibration (selector rods..etc..)? It doesn't always make a noise, but sometimes depending on RPM and gear selection.
- Question: What is "Chatter"? I was reading on the back of a Red Line Synthetic 75W90 Gear Oil bottle and it says: "The extreme slipperiness of this lubricant helps prevent limited-slip chatter and reduces differential temperatures 10ºF-70ºF in heavy-duty use. Supplemental friction modifier additive is usually not required for limited-slip differentials, but can be used if chatter occurs. Red Line 75W90 is used for high-speed and high torque conventional and racing applications. This product is not designed for use in most manual transmissions, since the extreme slipperiness may cause gear clash." According to the bottle label, the 928 transmission does not fall into the "most manual transmissions" category. In our transmissions, the differential and the transmission use the same lubrication. - Question: How does the "slipperiness" affect shifting? As I understand it, quite a few people use a mix of "slip" and "non-slip (NS)" gear oil to help syncro grip because the slipperiness required for proper LSD operation is too slippery for proper syncro operation. There really seems to be a contradiction in having the transmission and the LSD sharing the same gear oil. - Question: Am I just not understanding something correctly, or is this another example of Porsche "over-engineering" to the point where the exact specification of oil has to be used which is near impossible to get "exact"?
John Kelly 1986 928s 5-spd I have 85-86 32v Timing Belt Manuals available. |
#2 | |||
Guess I'll have this discussion with myself................
Quote:
Quote:
Quote:
#3 |
Having a list that identifies and attempts to troubleshoot problems which can occur with the clutch system and/or transmission and some of the potential causes would be helpful. Anybody care to add to it:
- Sloppy shifter: Front shift rod ball cup bushing, Rear shift rod coupler bushings, Weak shifter springs, Broken R-1st spring in transmission, - Cricket noises (chirping): Throw-out bearing, Pilot bearing, - Clutch slipping: Clutch disks, - Rattles: Ball cup bushing on clutch fork, - No Shift: Front shift rod ball cup bushing, - Clutch drag: "T" adjusters on Intermediate plate, - Soft Clutch: Air in slave cylinder, - Notchiness: - Grinding: - Difficult up-shifts: Bad syncros, - Difficult down-shifts: - Popping out of gear: - Chatter: - Shuddering: Torque tube,
#4 | |
Craic Head
Lifetime Rennlist Member Join Date: Sep 2006
Hey John,
I don't mean to interrupt here , but you said Quote:
Not sure I can help here, but I thought this might further isolate the problem. I'd break down two of your item further to warm and cold - Notchiness (when cold): gear oil? (try synth, new, different brand/blend) - Grinding (when cold): gear oil? (try synth, new, different brand/blend) - Notchiness (when warm): - Grinding (when warm): |
#5 |
Rennlist Member Join Date: Apr 2004
worn shift bands/shift selectors will cause same problems as worn synchros.
88 951s 84 928 Red Euro 5 speed LSD Sold 9/3/2006 87 951 Sold 12/05/2004 87 951 Sold 05/24/1999 |
#6 |
Rennlist Member Join Date: Aug 2006
It would be helpful to know what the rpm, mph and gear is when this happens. Did this start after the fluid change ? Chatter from lsd happens when turning.
1988S4 Auto w/89 low gear trans, LSD, X-Pipe, RMB, AFPR, AAchips, 18's 1984S 5spd Drove it hard,now with Juvius ASE Master Technician Associates in Automotive Technologies, NHTC 1983 |
#7 | |||
Quote:
Quote:
Quote:
Thanks for the clarification of "chatter". The sound is not chatter then.
#8 |
Does anyone know if this is a normal amount of metallic residue buildup on the transmission drain plug? This is after 5 years and 20,000 miles. It is like a fine powder that is magnetized into spikes.
#9 |
Craic Head
John,
Dude, you're gonna hate me, but what are you doing in second trying to rapidly accellerate at 1500? Isn't that like shifting out of first at like 20mph? You can do it, but not if you're in a hurry. My car hates that too, but if you run it up a bit then let the clutch out it likes it much better. The owner's manual specifically says not to 'lug' the engine at low rpms. I think this is what they mean. On the filings, I dunno, I've only done one of these and one or two other kinds of cars. It looks about like what mine had, but I have no idea how long it had been since the previous change. |
#10 |
Rennlist Member Join Date: Apr 2006
On the filings, run them through your thumb and index finger and if it's all powdery and no larger pieces, you're probably OK.
On the deiseling sound while accelerating at lower rpm's, are you sure your not hearing pre-ignition?
Charley Life is 99.8% fair. You may not like the rules but you gotta' love the odds. '93 GTS 5 spd '88 S4 Auto Red '82/'83 Euro Track Car '55 T-Bird (Show Car) '03 Lincoln LS V8 '90 Harley Springer Softail '90 Harley 1200C Chopper |
#11 |
Rennlist Member Join Date: Nov 2003
They all do that sir!
Well not exactly but both my 88 SE and my 90GT and Paul (Ukkid35) '87 make that same chattering sound when accelerating at 1000 - 1500 rpm in say 2nd or 3rd gear. For some reason not in 4th or 5th and in 1st maybe it does who knows. We always thought it was cams but there's a simple answer. keep the revs over 5000 always LOL |
#12 |
Supercharged
Rennlist Member |
You haven't said where the noise is coming from. Is it coming from the front of the car, middle, or rear? All three of which are possible. If it's front, you may be experiencing pre-ignition becasue you're lugging the engine (BTW, this is not good for the car). If it's in the middle, it could be the clutch, or the TT that's casuing the sound. If it's the rear, then it's most likely a trans issue.
#13 | ||||
Quote:
Quote:
The diesel sound is coming from the rear. Quote:
"Manual Transmission Gear Growl Noise When starting off slowly, customers may notice a slight gear rattle or growl coming from the transmission. This is a result of clearance between the gears, shifters and shift rails. This is a normal condition and does not require repairs." This may be what I'm hearing. I am interested to see if a fill of fresh gear oil has an effect (synthetic). If it doesn't, then I'll try a dino oil next time. What kind of gear oil do you use? Quote:
#14 |
Rennlist Member Join Date: Jul 2001
Steve Cattaeneo is the gear (head) guru here. I believe that applies to both manual and AT. Checks in periodically, you may want to try a PM.
That looks like a lot of filings, but if powdery I guess OK. I changed oil at 89K and less than half what you show, also very fine material. FYI, With rear suspended turn one wheel by hand fore and aft; mine seemed to have a lot of play in the box, but I was told this is normal. Still suspended as part of the change I flushed with 1/2 oil and 1/2 risolene and ran it through the gears at about 1000 RPMs. No LSD. It chattered, but w/o friction on either wheel, I was told this is same symptom and normal. HTH
928 '93 GTS, A/T, slate grey metallic, Konis, RMB 928 '85, 5-sp, Schwarz/Burgundy, gone but not forgotten. |
#15 |
Sharkaholic
Lifetime Rennlist Member Join Date: May 2002
My 5speed with out limited slip makes the same noises as yours. Always with low rpms, and light acceleration. It is more noticable when going around a corner. I also have redline in my tranny.
My 5speed with limited slip doesn't do this, it instead gets wheel hop on heavy acceleration. I have no idea what this transmission has for gear oil.
Heidi... '86 928S #0223 Garnet Red Metallic/Burgundy auto (crispy) Helmut '86.5 928S 5sp #1396 Guards Red/Slate Gray 32Vr -1° +1° Beth... '86.5 928S Auto #2641 Garnet Red Metallic/Burgundy Stage III Supershark 32Vr -2° 0° Zelda.. '86.5 928S 5sp #2698 Meteor Metallic/Burgundy LSD Sharkvent 32Vr +2° +4° |
