928 Forum 1978-1995
Sponsored by: 928 Specialists
Horn not working after Momo install
Old 03-20-2007, 05:10 PM
Will928
Will928's Avatar
Default Horn not working after Momo install
I've been using this board like crazy diagnosing and fixing things on my awesome new 928. I so love everyone here.
Now that I'm up your a$$e$...
Has anyone here installed a steering wheel and not had their horn work afterwards? I may just need to go back in and check things, but I'm pretty sure I wired it up correctly. It wasn't hard to do.
I just love the 928 horn, and even though I hardly use it, I'd hate to not have it.
Thanks for everything you all don't know you've helped me with...
Dave
Old 03-20-2007, 05:14 PM
Randy V
Randy V's Avatar
Is it possible you blew the fuse at some point during the installation?
Old 03-20-2007, 05:21 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
Did you move the metal rub circle from the back of the original wheel to the new wheel
Old 03-20-2007, 05:24 PM
Jadz928
Jadz928's Avatar
I've had this problem. You may need to adjust the metal clip on the back of the horn button to allow it to contact the metal on the wheel. Just pull the clip out a little bit. Not much is needed.
Old 03-20-2007, 06:08 PM
Will928
Will928's Avatar
Thanks guys. It may be the metal rub circle from the original hub. I didn't use it for the new one so I'll fix that and see what happens. I'll also check the the metal contacts.
Thanks!
Old 03-20-2007, 06:56 PM
Tampa 928s
Tampa 928s's Avatar
Default horn
I have the same wheel just ground the wire if it works check the button. Factory ground wire to metal adapator, momo to ground tab in column.
Old 03-20-2007, 07:17 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
The Momo button has a spade for the single black horn wire that is in the steering column. There is an extra spade on the hub adapter (circled in red) that is not used and needs to be bent in or cut off or it will potentially short circuit the horn. The button has a partial brass ring that makes contact with the hub.
Old 03-20-2007, 08:12 PM
F451
F451's Avatar
Make sure this metal tab is making contact with the steering wheel hub. Mine was not and the horn did not work.
I GENTLY pried mine up and then cleaned it electrical cleaner, then used a pencil eraser on it to insure it was clean.
I'm betting this is the problem.
Old 03-20-2007, 11:17 PM
Will928
Will928's Avatar
Awesome! Thanks for the pics and info. I'll check all these things and be back.
Old 07-07-2007, 05:05 PM
majhopper
majhopper's Avatar
Update. I was trying to fix the horn (inop since purchased) after changing out pods last night. My burgundy pod is a cracked mess, I had some wiring issues (reseating connectors can work miracles) and I had a much nicer black pod from my parts car. The black pod in the burgundy interior actually looks pretty good.
I search Rennlist for "Horn". Right at the top is this thread. Yay!
It appears that not only was this thread about exactly my exact problem, but my particular car as well!
I read some of Will928's other threads and everything tracks - the work done, his location, color, interior, wheel, horn prob. etc. Too funny.
Anyhow, I was struggling to figure out some of the advice I was reading about wiring the horn up, seems Momo made about fifty different horn buttons.
So I ohm'd it out with a meter and one of the posts above makes perfect sense to me now, although it didn't when I read it.
There are three contact tabs on the back of my horn. One is "ground" on the outside of the horn button "frame". The other two are located in the middle and it is these two contacts which make a closed circuit when the button is pressed.
Luckily, Will left me a perfect length of wire with spade connectors in the drivers side door compartment. I just bridged from one of the inner contacts to the "ground" tab and attached the wire from the Horn Contact Ring to the remaining tab. Voilla!
I didn't want to take it apart again, so I sketched it. I know it's an academic problem, one which I solved in five seconds with a voltmeter, but I figured it might help somebody else not electrically inclined.
Quick Reply: Horn not working after Momo install
