Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Sign in using an external account
Register Forgot Password?
Search
This Rennlist Forum is sponsored by      ....dedicated to Your Porsche 928
Thread Tools Search this Thread
Old 04-15-2007, 03:20 PM   #1
Dan87951
Super User
Dan87951's Avatar
Send a message via AIM to Dan87951
Default *%^^& dipstick won't come out
Preping the 85S for a full belt job/waterpump and the stupid dipstick will not come out. There is a 17mm but at the base of the pan but I can never get a good fit on the bolt because there is a lump on one side of the pan which prevents be from getting a good wrench around it. Any ideas or methods you guys tried? I'm taking my time and want to ask the board before I do something stupid and strip it. Any feedback would be great.
To remove this ad, register today or login if you already are registered!
Dan87951 is offline   Reply With Quote
Old 04-15-2007, 03:36 PM   #2
tdelarm
928 Addict
tdelarm's Avatar
Location: IN BETWEEN A FROZEN CONCOCTION AND INDECISION
Its your Avatar that is jinxing ya...consult Andrew...the keeper of the 928 shrine and perhaps the curse can be lifited!
Sorry...I know I have been no help...but....
tdelarm is offline   Reply With Quote
Old 04-15-2007, 03:42 PM   #3
Mike Frye
Craic Head
Mike Frye's Avatar
Default Dipstick tube?
Dan,
I'm not sure if I'm thinking of the same thing, but for mine, once you take out the (10mm?) bolt that holds it in place against the timing cover partway up the dipstick tube, you can just pull the dipstick tube up. There's a gasket down there that seals it, but it doesn't require any tools. My O-ring/gasket was toast, so I just used some RTV when I put it back in.
Mike Frye is offline   Reply With Quote
Old 04-15-2007, 04:45 PM   #4
Dan87951
Super User
Dan87951's Avatar
Mine didn't have anything holding it to the belt covers. I tried yanking it up with not dice. I original thought it just pulled right out like the 944's but I thought maybe the bolt down below is whats keeping it in there. I'm gonna go right out there and give it a really good yank and see what happens.
Quote:
Originally Posted by NJSharkFan
Dan,
Old 04-15-2007, 04:51 PM   #5
Shark Attack
Shark Attack's Avatar
Boy, I had the exact same problem on an 84.. I ended up buying a new extra long box end wrench, then I had to grind down the box to fit down onto the big nut. AND I STILL BUSTED MY FREAKING KNUCKLES WHEN IT BROKE LOOSE. I tried to get it off FOR DAYS.. before i resorted to this. The more i tried the more is got rounded off.
Shark Attack is offline   Reply With Quote
Old 04-15-2007, 05:12 PM   #6
Dan87951
Super User
Dan87951's Avatar
So the bolt at the bottom of the oil pan does have to break loose before the dip stick will gone out? I'm getting conflicting info..
Old 04-15-2007, 05:20 PM   #7
Mike Frye
Craic Head
Mike Frye's Avatar
Dan,
Do you have a photo? I'm not sure what bolt you're referring to.
Also, the dipstick is just to test the oil level, I assumed you meant the dipstick tube, right?
Old 04-15-2007, 05:30 PM   #8
Dan87951
Super User
Dan87951's Avatar
No I don't. But its the bolt at the bottom of the dip stick tube.
Dan
Old 04-15-2007, 05:33 PM   #9
Mike Frye
Craic Head
Mike Frye's Avatar
Stand by, I'm uploading a couple of photos, I need to resize them first.
Old 04-15-2007, 05:46 PM   #10
Mike Frye
Craic Head
Mike Frye's Avatar
Dan,
On mine, you just have to remove the top 10mm bolt shown here, then pull up the dipstick tube.
Click the image to open in full size.
On mine, you just pull up and it comes free. If yours is set up differently, I'm afraid I can't help, and it sounds like Shark Attack has experience with that. Weird that the setup would be different.
(Damn, I guess that tensioner gasket is leaking worse than I thought. Amazing how much you can see when you stick a camera in there. How embarassing).
Old 04-15-2007, 05:53 PM   #11
SharkSkin
SharkSkin's Avatar
Send a message via ICQ to SharkSkin Send a message via AIM to SharkSkin Send a message via MSN to SharkSkin Send a message via Yahoo to SharkSkin
I used a flare nut wrench to get mine out. No big deal. Lucky I guess...
Dave A.
1978 928 5spd
My 928 Site
Anyone who is capable of getting themselves made President should on no account be allowed to do the job.
--Douglas Adams
There is no doubt about precisely when folks began racing each other in automobiles.
It was the day they built the second automobile.
--Richard Petty
SharkSkin is offline   Reply With Quote
Old 04-15-2007, 06:06 PM   #12
Dan87951
Super User
Dan87951's Avatar
Dan,
Thanks for the pictures. Im guessing yours is an 85 as well 32v engine? Mine is a compeltely different setup. Yep there is a bolt down there at the base of the tube where it connects to the oil pan.
Currently im taking a break on it. Gettin fustrated... ahh
Old 04-15-2007, 06:14 PM   #13
Mike Frye
Craic Head
Mike Frye's Avatar
Yep, mine's an '85. I don't know if yours is odd or mine (This is the only one I know, but I'm getting to know it REALLY WELL).
I know what you mean about taking a break. Have a beer, come back fresh. Dave A. sounds like he's got your answer, flare nut wrench and patience .
Old 04-15-2007, 06:24 PM   #14
Dan87951
Super User
Dan87951's Avatar
Where can I get a flare nut wrench? Sears? I'll give it a whirl. PO never maintained the car so as more parts come off more crap gets bought. We are nearing close to 2k in parts.
Old 04-15-2007, 06:29 PM   #15
Shark Attack
Quote:
Dan
the nut is attached to the tube when you turn the nut you will turn t he tube
Paid Advertisement
Tags
2001, 300, 300m, 740il, boxster, buell, dip, dipstick, oil, pan, porsche, removal, remove, stick, tube, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
