One side of my exhaust is running hotter than the other
Hey Guys,
One side of my exhaust is running hotter than the other. Difference at idle on a warm engine is 50 degrees. I had the car on a lift today and both cats are good and no obstructions in the mufflers. So my driver side is much hotter at idle.
Bill Ball asked me to check for a loose spark plug or plugs and everything was good. We are thinking that the previous owner might have the timing belt off a tooth. Any thoughts on what might cause the difference in temperature from one side to the other?
Matt
What adam said.....is it right at the header-cat or further back (tailpipe area).....
Hot typically means lean....but cam timing could be a factor...but thats a BIG difference....hopefully its the passenger side bank, since its easier to check.....I would say bad injectors...but you just had them fixed along with the fuel pressure reg too.....
We took the reading where the exhaust manifold enters the H-Pipe, before the cats, before the two sides mix in the H section. At idle on a warm engine Drivers side 260 degrees / Passenger side 217 degrees
Engine is running fine, almost got 21mpg on the trip up and back, 11mpg on race day
your mileage is fine....not running rough....about the only other thing that would tell if you truely are running lean is a smog check....when is your next one?
I know that the headers are not quite the same length....one side is slightly longer than the other (don't know which one)...its not much...but might explain it a little bit.....
I would test someone elses 928 (bills)....maybe its normal?
Brian,
There is a problem it's hot enough that it is discoloring the bumper cover at the RMB on the same side that is hot at the manifold. So it's not if it's to hot or not but what would cause it to be 45 degrees hotter than the other side at idle. Who knows what that temp difference might be at freeway speed? I took it to a shop today to have a look on the rack thinking it could be a bad cat or blocked muffler they all checked out ok. The tech is not a 928 guy but said it was not the norm to have such extreme difference in temps before the cats
I have known a GT where the cam timing was off about a tooth, and that caused a temp differential sufficient to trigger the "ignition protection relay".
If all of the tubes on one bank are cooler than the other bank, then it must be the cam timing.
Since matts is an 88 it doesn't have that circuit...could be dumping fuel which is burning in the header?? Just a little bit anyway?
time to check the cams
I appreciate that Matt's S4 doesn't have that circuit, but I was making the point that incorrect cam timing can make a significant difference to exhaust temps.
The incorrect timing may also mess up the mixture on the correctly timed head because the O2 loop will be fooled by possible incomplete combusition from the faulty side.
Thanks John,
That is what Bill Ball suspected, I just thought it never hurts to see what the group thinks as well. Well check it out today and report back.
Under the Lift
Matt, if you need help with this, I am free today.
Inventor
Originally Posted by Bill Ball
It is real easy to be a tooth off on a TB job if you aren't careful. If the temp difference is the whole bank but the gears are right on, then we need to pull the cam covers and do a factory cam timing job.
I've heard there is a less invasive way to check/set the cam timing.
Originally Posted by Obi-Wan
You must do what you feel is right, of course.
Originally Posted by Darth Vader
I find your lack of faith disturbing.
