928 Forum 1978-1995
Sponsored by: 928 Specialists
Big Silvers (brakes & rotors)
Old 07-09-2007, 09:28 PM
928ntslow
928ntslow's Avatar
Default Big Silvers (brakes & rotors)
Needed new pads...good a time as any to change things around. Never did like the big blacks so I changed them to silver to better match the car....and try to keep up with modern times. Got new pads, sensors and a new set of cross drilled rotors. Painted up the rotors and calipers, painted on the new style PORSCHE logo on the cali's and I am pleased with the changes.
Now for the problem! My BRAKE PAD SERVICE light came on a month or two back. When I pulled the old components, there was indeed a worn sensor. Now that I have put everything back together, I still get the BRAKE PAD SERVICE light. I checked all of the new sensors with a multi meter and all are fine. I thought maybe I needed to disconnect the battery for a bit to clear the code...which didn't seem right to begin with, but I did it anyway. Still have the light. I did a search on the Rennlist and found what I already know. It is a very simple system...a closed loop. Unless this is a coincidence, I cannot see how I have a bad connection or break in the system. I do not expect that I would need the Hammer or the Tuner to clear this would I??? Worse comes to worse, I'll have to do the trace chase. Any suggestions though?
Old 07-09-2007, 09:44 PM
Robert_H
Robert_H's Avatar
I don't have any answers for you, but I wanted to say that the brakes look very nice with the silver calipers and the new rotors. You're right, they do have a modern look to them.
Old 07-09-2007, 09:54 PM
AO
Supercharged
AO's Avatar
Looks good!
You must have a break somewhere in your lines to cause the warning light.
Old 07-09-2007, 10:17 PM
RDS928S
RDS928S's Avatar
Nice job.
Old 07-09-2007, 10:25 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,079 Likes on 1,186 Posts
Good job Keith, very nice!
Old 07-09-2007, 10:32 PM
ROG100
Basic Sponsor
ROG100's Avatar
Keith,
Nice, very nice!
1) Are you sure you have the right sensors - yes? GTS Fronts are different IIRC.
2) Are they pushed all the way home in the connectors.
3) If you have an early 93 also check the connectors in the engine bay.
Good luck,
Roger
Old 07-09-2007, 11:21 PM
PorKen
Inventor
PorKen's Avatar
That turned out nice!
What's up with that red sidemarker?
Old 07-09-2007, 11:25 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,284 Likes on 1,266 Posts
You did a great job on the brakes now throw your closest friend the keys and ride alongside so you can see your work in motion. I would check the connections at the wheels for the light, and check with a multi meter the sensors for continuity
Old 07-09-2007, 11:32 PM
928ntslow
928ntslow's Avatar
Thanks guys. As soon as I have a better shot of the whole car with the change, it will make even more sense.
Roger...Thanks again for the rotors btw...was a bit perplexed when I saw the rears were non-directional...looks a tad weird with the cross drilled holes going the wrong way...
I double checked the plugs...even crimped the females so they have a bit more grab just incase the connection wasn't being made at the plug. Sensors are properly inserted into the pads, but that is not the issue...you can have all the sensors dangling and they would still close the circuit. I have a later 93. I guess I am just going to have to track it down manually....that sucks.
...did all of that Stan.
Ken...that'll change eventually BTW...those lift bars are awesome! they take the car up to a nice height too!
Old 07-09-2007, 11:37 PM
IcemanG17
IcemanG17's Avatar
Keith
Looking great as always......
On the sensor....if I remember correctly the circuit is normally "open" and once it closes the warning goes off.....if all the sensors are installed correctly (probably are)...then there must be a broken sensor causing a short & the light....does anyone near you have a hammer or the PC clone? Maybe Louie?
Old 07-10-2007, 12:07 AM
lorenolson888
lorenolson888's Avatar
Default All 928 should have brembos
Those look sick...
That is good thing by the way...
LO
Old 07-10-2007, 12:17 AM
bd0nalds0n
bd0nalds0n's Avatar
There's a writeup by Wally P that goes thru the step by step. There's a bunch of potential points of failure along the way.
Old 07-10-2007, 12:40 AM
Popo928
Popo928's Avatar
Man, I just ordered black letters to do my new calipers. Was going to paint them red but I thought silver with black letters would look good. Now I know it will, I just won't be the first. VERY, VERY NICE!
Old 07-10-2007, 12:42 AM
redpathtribe
redpathtribe's Avatar
Looks great Keith. Only thing better is if you would have painted them RED... You know that would make your GTS go faster... and STOP faster too!!! A little contrast is OK, no really, it is... Well, I guess your tires are still black... so far.
Seriously, looks great! Still need to put mine on and really paint my calipers red. Pads are gettin' thin, must make time soon...
Old 07-10-2007, 12:52 AM
928ntslow
928ntslow's Avatar
uh..you can kinda see them in this pic
Quick Reply: Big Silvers (brakes & rotors)
