928 Forum 1978-1995
Sponsored by: 928 Specialists
Loctite 290 experience after 2 years and 12000 miles
Old 01-01-2009, 06:16 AM
  #31
Z
Z's Avatar
Originally Posted by SharkSkin
Thanks for the details,Z. It sounds like you just put a small ring of glue around the spline. I had been visualizing a coat of loctite over the whole spline, which sounds like trouble to me. Sounds like it worked out well for you.
When I applied the Loctite with the clamp fully loosened, it wicked along the splines pretty well, and did pretty much coat all or most of the length of the clamp to shaft contact area. When the parts were separated, the residual Loctite was visible, and it was pretty easy to see how far along the splines it had gotten.
Old 10-10-2009, 03:28 PM
  #32
Schocki
Schocki's Avatar
Latest update on the Loctite 290 flexplate fix. I started my TB winter project and checked the TB wear and flexplate movement today again.
Loctite was used in 2005 at 110625 miles. Now 4 years later and at 135625 miles there is still no flexplate movement.
The thrust bearing was checked last time in fall 2004 and was at 0.27 mm (wear limit 0.4 mm). Today's measurement was 0.25 mm (0.02 can be neglected as measurement error).
Looks like a very healthy GTS engine
Old 10-10-2009, 10:11 PM
  #33
Fogey1
Fogey1's Avatar
Default re: applying heat
Wet towels or rags draped over/attached to adjacent surfaces are your friend when applying heat to a localized area. They make good heat sinks.
Old 10-11-2009, 12:40 AM
  #34
Bill Ball
Under the Lift
Bill Ball's Avatar
Schocki: I can't find a description of how you checked the crank endplay. Did you break the Loctite bond to free the flexplate or did you just pry the flywheel with the clamp still locked down?
Old 10-11-2009, 04:21 AM
  #35
Schocki
Schocki's Avatar
Pried the fly wheel with everything in clamped in place, no problem. I let the flexplate "flex" so to speak...
Old 10-11-2009, 09:17 AM
  #36
M. Requin
M. Requin's Avatar
I've done the same, no problem.
Old 10-11-2009, 06:19 PM
  #37
marton
marton's Avatar
just convert to 5 speed
Marton
Old 10-12-2009, 02:02 AM
  #38
Schocki
Schocki's Avatar
TBF can happen to a 5 speed too, BTW.
Why should I get rid of the superior Rogerbox?
Old 01-19-2013, 03:17 PM
  #39
Schocki
Schocki's Avatar
Loctite 290 update after 7 years...
Checked my flexplate again today. Since 2005 and about 45000 km (28000 miles) no movement
Thrust bearing check: no changes still 0.27 mm. Total miles 224000 km (140000 miles)
Pretty cheap and effective solution (no PKlamp available in 2005).
Old 01-19-2013, 08:07 PM
  #40
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Its interesting that the data sheet on this shows a significant loss in lock grip over time.
Id say 100c isnt an unrealistic temperature down there, and after 1000hrs (30k?) you would be down 35% in grip.
Exposure to motor oil exacerbates the degradation as well. (so no leakers!)
That may not be too much to still not work, considering the immense surface area in play in the clamp.
If you were to use this, the spec for wiking into a seal:
For Porosity Sealing
1. Clean area and apply localized heat to the area to approximately 121°C.
2. Allow to cool to approximately 85°C and apply the product.
Old 01-20-2013, 04:53 AM
  #41
danglerb
danglerb's Avatar
Where was the loctite applied, the threads of the torque tube or threads of the bolt on the clamp?
Old 01-20-2013, 07:33 AM
  #42
Speedtoys
Speedtoys's Avatar
Its applied where the shaft goes into the collar..and it wicks into the engagement of the shaft and collar...then tightened down.
Old 01-20-2013, 01:35 PM
  #43
Schocki
Schocki's Avatar
Exactly Loctite 290 is designed to be used after assembly. So far it works just fine. But I would go with the PKlamp option today. Back in 2005 there was no PKlamp and no real solution to the problem.
The transaxle will be fine for a long time. The car received new torque converter bearings, rebuilt torque tube from Mark Anderson, all seals were changed and a flexplate that was secured with Loctite 290 in 2005.
Old 01-20-2013, 02:02 PM
  #44
Black Sea RD
Former Vendor
Black Sea RD's Avatar
Beg to differ on that one point since the Super Clamp was being offered back then.
Great to hear the loctite is working so well for you!
Happy New Year,
Old 01-20-2013, 02:06 PM
  #45
Schocki
Schocki's Avatar
That´s true it would have been an alternative, since everything was out of the car. But Loctite 290 was more cost effective.
Quick Reply: Loctite 290 experience after 2 years and 12000 miles
