928 Forum 1978-1995
Sponsored by: 928 Specialists
Interior LED Changeover (uhm...Looooong)
Old 10-12-2007, 05:16 PM
928ntslow
928ntslow's Avatar
Default Interior LED Changeover (uhm...Looooong)
If you haven’t yet switched to LED instrument lighting, you just don’t know what you are missing. This of course is my opinion. However, look at the new cars out there, they use LED. Why?...because they last longer, draw less current and produce a vivid light with distinct color. In comparison to incandescent filament, it is like comparing the point at which the world changed from candle light to incandescent. It is just the technological succession in lighting.
I changed out every bulb in the interior with the exception of several of the cluster bulbs which I will address in a bit. It is recommended that if you are rear lighting a colored lens, that you use the same color bulb. I disagree…at least for interior lighting. Exterior, I would follow this suggestion. There are a few instances where I used LED’s when it wasn’t necessary. I already owned them and tested, so I may have just left them in. Another thing to note is that I did this on a 1993 GTS, your instrument cluster, clock light and cig lighter light may be different.
I wrote this up to help those who have considered this, but didn’t want to assemble or couldn’t find all of the info in one place. I hope this helps.
Also, let me say now that I used Wojtek, of southern California’s website as a guide for my change over. He is a fantastic fellow for doing the research he did to make these changes possible. Of course, I had embellished on a few things as maybe you will as well. Please use his site as a guide to help you through your modifications.
http://members.***.net/my_1987s4_928...m#illumination)
NOTES:
1) LED’s for the most part are polar specific, meaning there is a positive side and a negative side. They MUST be installed correctly in regard to the polarity of the circuit
2) Have a 9v battery with two leads and alligator clips at each end. This will allow you to not only check polarities, but also check your work as you assemble and install. You don’t want to get it all back together and find out you have a bulb 180 degrees out of polarity or a bad connection or improper lighting adjustment as in a few cases.
3) Buy extra bulbs! You will undoubtedly get a bad one or two, break one or two or lose one or two.
4) These bulbs all work off of a 12v system, DO NOT apply more than 12v to any of this stuff, ESPECIALLY the instrument cluster.
5) At the bottom is a reference chart as to what type bulb goes where
6) It is difficult to take accurate photos of this type of lighting as it seems a high end camera is the only option. That I don’t have so my best efforts were made to get the best possible photos that I could.
7) DISCONNECT THE BATTERY BEFORE YOU DO ANY WORK ON ELECTRICAL.
COURTESY LIGHTING
The first and easiest is the courtesy lighting throughout. 6 lights total. Festoon bulbs, 4 are the same for the doors, rear overhead/dome and rear hatch. The glove box light is a shorter festoon type bulb. The center light above the mirror is basically a reading/map
light which requires a brighter bulb. This will take a more intense bulb for actually reading something at night. BTW, this same bulb will work well for the engine bay light if yours is of the festoon type. (These have such a low draw that you can leave the hood open all day and the bulb will not get hot nor run down your battery. As for lighting at night, they do as good, if not a better job under the hood)
DOOR MARKERS
These are of the bayonet type and I used Red. I think white would work well, but after all is said and done the difference in the filament and the LED is hardly noticeable. This is due to the thick red lens of the door marker.
CIGARETTE LIGHTER
I removed mine and ditched the bulb, but it uses the same bulb as the pod switches.
CLOCK
Rather easy to get to. A fixed base bulb with a 1/4 twist located at the rear of the unit.
ACKNOWLEDGMENT BAR
Geez, I have seen all types of these things. All I can say is there are 2 lights in mine, one for the AC button and the other for the door lock button. You will need to remove this unit and disassemble…just do it with care. It is possible however, to just replace the AC bulb by removing the button itself at the face of the unit. By squeezing the opposing ends, you work the cover off. This will give you visible access to the bulb. If you have never done this, then I recommend playing it safe and disassembling the thing…it’s quite easy. As for the door lock button bulb, it is a soldered in place bulb. I chose to leave it as is since it is a two stage light that would need a resister soldered in. The quality of lighting is pretty vivid to begin with and I expect replacing with an LED wouldn’t be worth the work. You guys with the blue and green buttons, well, make your best choice.
HVAC
This is the fun one! It’s going to require a strong stomach, steady hands and craftiness. Let me explain how this thing works before I tell you how to make it better. There are two wedge based bulbs in here that for the most part, are directed and reflected towards the temperature/function plastic lens in the center of the unit. Then what you have is fiber optic lighting that is piggybacked off of these two bulbs. If I recall correctly, there are two fiber optic lines from each bulb, two on top and two on the bottom. For both top and bottom, one line runs to a slider ****, lighting the **** face and the other to the rotary fan ****, lighting the numbers and fan HI and LO.
To improve this, you are going to have to improvise a better set up. First, you are going to have to remove the existing bulbs and then you are going to have to rewire from the circuit board for the new LED bulbs as they require a 1w_200ohm resistor. This is because what I used was a bare wire lead LED not in any kind of base. Most base mounted LED’s have a resistor inside. Brush up on your soldering skills cause you’re gonna need it. You could just use replacement wedge base bulbs, but the beam pattern is not going to allow you to get a good enough light intensity through the fiber optics. After you have fit your resistor and wired your LED, you will need to fit the bulbs into the openings where the original bulbs were. The issue you will now be faced with is that the LED’s do not have a full omni-directional lighting pattern that a filament bulb does. The LED’s are projective or for the most part, uni-directional. I tell you this because the bases of the fiber optics are set perpendicular to the bulbs. When the LED is pushed all of the way into its socket, the fiber optic base meets the LED behind the projected beam. In essence, you are going to have to get the bulbs back a little so as to allow the fiber optics to catch enough light to brightly do their job. Having the wire leads to the LED’s allows you to make minor adjustments for this.
As for the fiber optics, slip them back into the same sockets to adjust the LED bulbs. I had also drilled a little deeper into the slider lenses to get a brighter light at the slider head. From the fiber optic lines...just be careful if you do this so you don’t to drill all the way through. You will end up needing to fill it in and start over again. I am sure some kind of glue will work well enough to fill the hole, but best to avoid this of course.
Lastly, I lit the fan **** itself. No, it has no lighting. I took the top pair of fiber optic lines and added a third line. I made the fiber optic line with several strands of fiber and heat shrink. I opened up the coupling where the fiber optic meets the LED bulb and stuffed a third line in there and then re-crimped. It’s a bit tricky, but you have to run the new fiber optic line to the back of the fan **** bezel.
All in all, you are going to have to pull the ***** and sliders off and really disassemble this thing to get to what you need to make it work. Refer to Wojtek’s site to help you with visuals and illustrations. You will need to be pretty good with a drill as well.
INSTRUMENT CLUSTER
I did a bit of testing with this part. I ordered several LED’s to see what colors would work best. I had replaced the 4 main back lights with the proper LED replacement bulbs. I have to say that if there is a single best thing in using the LED’s it is this right here. It totally changed the viewing of the instruments and daylight viewing is very vivid….no more squinting to see the gauges. Replacing these bulbs and all others in the cluster is very easy. Getting the cluster out though, takes patience. I was removing the whole shebang before I read Shocki’s post on removing the cluster in 15 minutes. Not sure I agree with the time frame, but the idea works and works well! So once you have the cluster out, you will need to release the 4 locking clips and carefully open the back housing. There is a multi pin plug that connects through the backing so go easy.
The main back lighting bulbs are wedge and plug into the bases. If I remember correctly, you can check for good bulb seating with the 9v as there are exposed leads on the outside of the base holder. Make sure you correctly place the bulbs with their respective polarities into the circuit board You can check this with the the rear of the cluster closed and tabs locked using the photo shown below. Do this as a final check JUST for the back lighting. You will undoubtedly be sure that all 4 bulbs are properly seated and polarity correct.
As for the rest of the cluster, it is entirely up to you if you would prefer LED’s. They are all fixed base bulbs. I think it is important to note here, that LCD and LED do not mix well! I had tried different combinations and due to the LED’s being a focused or projected beam pattern, LCD requires a wide “washed” pattern of light.. I used white, yellow and red LED bulbs for testing and they just did not do as good of a job as the original filament bulbs. However, I did change out the lower LCD display to 2w VW bulbs (green base). These are the bulbs with red latex covers over them, so you will need to transfer the covers. The red now jumps out of the display. Use the original 1.5w (yellow base) bulbs for the normal display as anything brighter just adds to the background lighting and the contrast/definition is not as good. Besides, this panel is as crisp as it is going to get using the filament bulbs.
I did decide to change a few bulbs over that got a fair amount of usage and I did like the way they looked with the LED bulbs. I used green LED’s for the Parking Lights and Turn Signal indicator. I had tried a blue LED for the Hi Beams, but white worked much better. You guys that have automatic tranny’s may want to use LED’s as I have a feeling they would work much better than the filament bulbs. There are a couple more that I probably would have changed over like the Low Fuel and the PSD, but I don’t see those indicators much of the time. For the most part, the indicators around the cluster are pretty vivid and bright to begin with…especially the red so I saw no need to fool with them. Changing out really wouldn’t make much difference color wise. I did have to modify the backing cover to close over the Parking Light LED base. It stuck too far up so I drilled a hole to accommodate.
Make sure you check your connections and polarities before you button every thing back up. Just to be safe, when you get the cluster reconnected to the four harnesses, reattach the battery and just turn the key to the #1 position to make sure everything functions. You can check your turn signals and such at that time as well. If it all works, disconnect the battery and finish putting everything back together.
POD *****
If you’re doing this mod, may as well do the instrument cluster as you will now have to remove the pod completely. All *****/switches need to be disconnected and removed. You will need full access to the switch wiring. Following Wojtek’s schematics, you will need to install resistors to the switches that will dim when not in use such as the Fog, Rear Defrost and Hazard. Solder in the resistors and heat shrink over them. As for the wedge base bulbs, they will not slip right into the switch socket. I had to file down and custom fit the bases some to allow the bulb base to fit properly. This is where the 9v battery came in handy too. There may be other wedge base bulbs out there by other manufacturers that will fit better, but which ones, I don’t know. Again, polarity has to be correct.
This mod to the lighting was way beyond well worth it. It’s one of those things that you wonder how you ever lived without it. I know there is concern about dimming as the dimmer switch hardly works now. I personally don’t think you need the dimmer switch for LED as the light is not necessarily brighter, but more vivid and concentrated. There are dimmer switches available for LED lighting, but that is something you will have to decide if you need. To me, the light isn’t all that bright or distracting at night. Daylight viewing is excellent and to be honest, I never knew I had it until I installed the LED’s. Your headlight switch and cluster are illuminated all of the time as soon as you turn the key past the #1 position. No more do I have to squint to see the gauges during the day. Clear as a bell and easy to read anytime. As for the rest of the lighting at night, no longer is there an weak amber glow to anything, it is all crisp cool white and very vivid, not to mention the updated look that you get. It’s a fun and satisfying modification that is well worth the effort. Also, there is no issue with current draw and faulty lighting issues. The two stage lighting on the pod switches works great also!
I have made a list of the bulbs and their respective placement in the car. I hope this will help others if they choose to do the change over. I had gotten all of my bulbs from SUPERBRIGHT LED. http://superbrightleds.com I think other LED companies may have their own part numbers, but it shouldn’t be tough figure out what you need.
The following is for the last inception of the clusters with the LCD info screen. I have listed the possible bulbs for replacement if anyone is interested.
INSTUMENT CLUSTER
WLED 5-LED WIDE ANGLE WEDGE BASE LED BULB [White]
(4) Instrument Cluster Main Back Lighting
#74 WEDGE BASE LED BULB (see colors next to item)
(4) LCD Display [White]
(4) LCD Display [Red]
(6) P R N D 3 2 [white] or P=(1)[Red], R=(1)[Blue], N=(1)[White], D 3 2=(3)[Green]
(1) Low Fuel [Orange]
(1) Low Oil [Red}
(1) Low Battery [Red]
(1) High Temperature [Red]
(1) Brake [Red]
(1) Parking Brake [Red}
(1) Seat Belt [Red]
(1) Antilock [Orange]
(1) Trailer Connection [Green]
(1) Turn Signal [Green]
(1) Hi Beam [White]
(1) Tire Pressure [Red]
(1) Parking lights [Green]
(1) Check Engine [Red]
(1) Stop Lamp [Red]
(1) PSD [Green]
POD SWITCHES
#74 WEDGE BASE LED [White]
(1) Headlight
(1) Fog + 1K ohm 1w resistor
(1) Trip Reset
(1) Rear Window Defog + 1K ohm 1w resistor
(1) Hazard + 1K ohm 1w resistor
CIGARETTE LIGHTER
(1) Cigarette Lighter
INTERIOR COURTESY LIGHTING
HID HIGH POWER LED FESTOON BULB 42mm [White]
(1) Map Light
(1) Dome Light
(2) Convenience Light
(1) Cargo Light
GLOVE BOX
3022 x 4 LED FESTOON BULB 30mm [White]
(1) Glove Box
HVAC
SUPERBRIGHT WHITE LED 11C 5mm [White]
1w_200ohm resistor 1W120-NTE HVAC
(2) HVAC (two sliders and fan switch)
#74 WEDGEBASE LED [White]
(1) HVAC (back light)
CLOCK
(1) Backlight
AC
(1) Button Backlight
ASHTRAY
BA9s 1-LED Bayonet Base bulb [White]
(1) Cigarette Lighter (backlight)
DOOR
BA9s-x-WV WIDE ANGLE BULB [Red]
(2) Open Door Marker
If you have any questions, I will do my best to answer them. Again, I apologize as these are the best photo's I can come up with at this time. It is truly something you have to see in person.
Though ridiculously blurry, this is about as true as it gets in regard to the actual colors of the dash and console.
Old 10-12-2007, 05:20 PM
IcemanG17
IcemanG17's Avatar
Keith
DAMMM......I'm very impressed.....that looks bad ***...just like my new acura......
Old 10-12-2007, 06:42 PM
imfinlay
imfinlay's Avatar
Looks great, but surely the dash lights won't dim anymore with the rheostat?
Old 10-12-2007, 07:01 PM
RicerSchnitzzle
RicerSchnitzzle's Avatar
upon further inspection of your car and mods, I have decided I hate you.
Great way to top off the stereo install. Very professional results. Love it. I went with glo gauges and LED's everywhere else. Really updates the look on your shark.
Old 10-12-2007, 07:04 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Excellent, Keith! I have done some of this too, but not the cluster or console lighting yet, so this really helps.
I used the red LEDs as you did for the door edge lights. The red LEDS are much cheaper than white. I tried both and even with the deep red lens, the red LEDS actually looked better.
Don't forget the license plate lights, even though that's exterior. The pure white LED light looks very sharp in place of the yellow incandescents. 36mm festoon.
Old 10-12-2007, 07:11 PM
928ntslow
928ntslow's Avatar
PHP Code:
If you look real hard, you can see them dim from bright to bright Actually there IS a tad of a difference, but as I had mentioned in the long winded first post, there is a separate unit you can get to dim the lighting, but I really see no need for it.
Bill- The exterior lighting is on the list of future things, right down to Xenon bulbs. There is an exterior mod I must do before anything else though. It's radical...and my next "must do" project.
Old 10-12-2007, 07:14 PM
928autobahndreamer
928autobahndreamer's Avatar
OK, I gotta do this. At least on the instrument cluster. At night I really have to look hard to see the gauges. Very dim.
Old 10-12-2007, 09:55 PM
ew928
Owns the Streets
Needs Camber
ew928's Avatar
Kewl!
Can't wait till my stash of #74 bulbs arrive.
Dive into pod to reactivate odometer and plop in 4 white led's. Hope I don't end up with 'Tokyo by Night' instruments.
Maybe the LED will revive my long dead headlight switch. And putting an LED into the AC button should make that button less hot after a nice long drive. Hope it's the filament bulb heating up the AC switch and not weak contacts.
Thanks for pointing the way, Keith.
(Praying for 'Assembly is reverse of disassembly')
Old 10-12-2007, 09:56 PM
Mike B
Done With Sidepatch
Mike B's Avatar
WoW!!! Great write up! Thanks for doing the homework and especially for sharing. Looks great by the way!
Old 10-12-2007, 10:23 PM
Hilton
Hilton's Avatar
Originally Posted by 928ntslow
POD *****
...As for the wedge base bulbs, they will not slip right into the switch socket. I had to file down and custom fit the bases some to allow the bulb base to fit properly. This is where the 9v battery came in handy too. There may be other wedge base bulbs out there by other manufacturers that will fit better, but which ones, I don’t know. Again, polarity has to be correct.
I actually ordered a bunch of bulbs for future cluster work and all courtesy lighting a few days ago. Some T10 wedges for the main dials, and a variety of T5's for the instrument lights and pod switches.
On the pod-bulbs; I did notice that some ebay vendors sell shorter wedge-base led bulbs in the T5 size (most are 20mm.. I've seen a few vendors with 14mm).
Might be enough to not have to file them down to fit?
Old 10-13-2007, 02:15 AM
928ntslow
928ntslow's Avatar
The issue is not the length, it is the diameter of the base. With the filament, all you have is the wedge glass and the total diameter of the glass bulb slips snugly into the switch socket. The LED's require a base and micro resistor fitted at the bottom of the bulb in the base. I am not sure there is any getting around this unless someone is making them specifically for this type of application. I have small hand files for craft/precision use.What I ended up doing was grabbing a hold of the bulb with some small pliers and running the base back and forth over the file which was held flat on a surface. Yea, I know, a bogus way to do it, but it got the job done. The other option I didn't try was a Dremel with the sanding barrel/wheel attachment. I can't remember why I didn't at this time....might have been too lazy to bust out the power tools
Old 10-14-2007, 03:51 PM
JHowell37
JHowell37's Avatar
In your post, you had referred to "#74 wedge base LED." On your link which ones are they? Even though the resolution isn't great, it does convey the vast improvement of LED over conventional bulbs.
Old 10-14-2007, 04:06 PM
JHowell37
JHowell37's Avatar
One other thing I was wondering is do the later 928s have backlit instruments?
jra911 (08-23-2023)
Old 10-14-2007, 07:16 PM
928ntslow
928ntslow's Avatar
You will have to navigate your way from the Home page > LED Bulbs & Products > 12 Volt Car Bulbs (READ the info on the page and then move on to the next page) > Continue To Car Bulbs > Miniature And Wedge Base Bulbs, then scroll down to Instrument Cluster and Gauge Backlights. Click on MORE INFO for...more info.
I have tried so many different camera settings, lighting, angles and distances, and I just can't get my camera to capture what can be seen in person.
I think from 1990 on, the gauges are back lit. Wojtek addresses the face lit gauges, but that just looks too bright for my tastes...I just want to see the needle and dial.
Old 10-18-2007, 09:29 AM
piccardo
piccardo's Avatar
Very nice. I need to get started with mine. It really makes the console design look ten years more recent.
Quick Reply: Interior LED Changeover (uhm...Looooong)
