928 Forum 1978-1995
Sponsored by: 928 Specialists
Bearing madness
Old 02-17-2009, 04:33 PM
  #91
SharkSkin
SharkSkin's Avatar
I bought a rebuilt smog pump a couple years back for $50... Hardly worth the trouble of rebuilding myself to save $5.
Old 04-14-2009, 06:45 PM
  #92
Leslie 928 S2
Leslie 928 S2's Avatar
I've read and read and read through this thread, and I think I've lost my way at this point.
Before I make the wrong choice....am I correct in understanding that the bearing number for both torque tubes AND torque converters is 6008? (This would be for Franken-Shark -- 85 Euro with 84 US TT and TC.) I guess what I'm asking is, are all the years the same?
Thanks for your help!
Old 05-07-2009, 09:07 AM
  #93
slartibartfast
Cruisin'
slartibartfast's Avatar
Can someone who's replaced their clutch release bearing please tell me the exact part number of the bearing they used?
I know it's a 6008 bearing but that just specifies the size. I need to know whether it's shielded/sealed/etc.
Thanks.
Old 05-07-2009, 09:21 AM
  #94
marton
marton's Avatar
Thanks.
I think that is your choice; myself I would buy the top quality shielded, sealed ceramic bearing but Porsche themselves offered a relatively low quality one.
Marton
Old 05-08-2009, 04:25 AM
  #95
Podguy
Podguy's Avatar
Shielding is not such a concern because it gets pressed into the bearing holder and is shielded that way.
I just ordered some that were 6000 RPM capable and they worked great. About $3.50 a bearing. There should be some other numbers or letters in the bearing you removed that defines specification.
Good luck
Old 11-08-2009, 03:40 AM
  #96
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,577 Likes on 1,244 Posts
I had the pleasure of buying a new transmission input shaft bearing (999.052.138.00), It's a *** # 566796A, for '87-95 5 -speeds.
Old 11-08-2009, 05:16 AM
  #97
marton
marton's Avatar
nice foto.
Old 11-08-2009, 02:36 PM
  #98
danglerb
danglerb's Avatar
You don't "buy" those bearings, you invest in them.
Tried all sort of searches and found nothing related to 566796A, not even on the *** site. Can you take all those measurements bearings need measured and post that?
Old 11-08-2009, 07:21 PM
  #99
Rob Edwards
Archive Gatekeeper
Mike-
I did the search too, couldn't find anything whatsoever. At the risk of outing myself as the retard that I am, what measurements? Just OD, ID, and thickness?
Old 11-08-2009, 08:42 PM
  #100
Imo000
Captain Obvious
Super User
Imo000's Avatar
Mike-
Yup, those are it and you need to know the type of bearing and it's operating environemt (highspeed, cold climate, high pressure, etc.). BUT the "A" or any other letter at the end usually indicates that the bearing is a unique part, specially made for the manufacturer.
Old 11-08-2009, 10:13 PM
  #101
danglerb
danglerb's Avatar
http://mechanical-components.globals...ings_All_Types
http://www.ahrinternational.com/FAG_nomenclature.shtml
Old 11-09-2009, 02:37 AM
  #102
Rob Edwards
Archive Gatekeeper
Mkay, here goes:
There's a 5mm thick flange on the bearing that makes it 105mm OD in greatest dimension, and 100 mm OD over the remainder of the OD. Thickness is ~21.1 mm, and the ID is ~55mm:
Old 11-09-2009, 11:25 AM
  #103
Imo000
Captain Obvious
Super User
Imo000's Avatar
Ahhh...you didn't show the lip in the first pic. This bearing is definetly a custom one. Standard sized bearings are ........... well, standard. No funky lip or extra machining. That's a ball bearing by the way.
Old 08-13-2010, 07:26 PM
  #104
Hilton
Hilton's Avatar
Ken posted this in another thread, so I'm stealing it to add to this one:
Originally Posted by PorKen
Slow wiping and/or whirring/grinding noise is usually a sign of a greaseless, bad bearing in the wiper motor. It is replaceable, but it's not a quick job. (A new wiper motor is >$400, vs. <$10 for a bearing.)
The bearing is 26 x 10 x 8 (often used on bicycles). I used '6000 2RS C3' to rebuild mine.
Old 08-13-2010, 08:31 PM
  #105
LT Texan
LT Texan's Avatar
Hilton, thanks for cross-posting! This is a problem that I have to tackle soon.
Quick Reply: Bearing madness
