LH 2.2/EZF replacements
With the release of the LH2.2/EZF sharktuner are there any other LH or EZF modules that can be reprogrammed to work in a 928? SAAB? Mercedes?
The Volvo 740 and 760 turbo LH boxes look the same from the outside, but in fact they are rather different inside. Not feasable to use those.
I buy them to rob the 25 way connectors for SharkTuner LH2.2/EZF break out boxes.
IIRC, most Volvos are LH 2.4 as are 90 or 91+ SAABs. I think 84-88 SAABs are LH 2.2 and the boxes go for well under $100 on ebay in supposedly working condition.
Yes, that is correct, I was talking about LH2.2 only. The later LH2.4 as used on Volvo and Saab again look similar outside to the Porsche LH2.3 but inside there are completely different, much simpler.
Does this mean you can buy one of these Saab units and swap out the guts and EPROMs, and your good to go?
http://cgi.ebay.com/ebaymotors/1989-...QQcmdZViewItem
Inventor
AFAIK, there's programming in chip(s) soldered onto the board of the LH, that's unique to the application. So, just changing the EPROM won't make it work.
No need to be evasive. This is supposed to be a forum for ideas about the 928, not just for the benifit of the sponsors.
I guess I'm stomping on the wrong feet here by asking a simple question.
"Being a sponsor" is nothing to do with the brevity of my response. I'm just telling you that investigating that avenue would be a waste your time.
