Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
marketplace | store
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
New! Use your Facebook to securely log into this site, click logo to login
Old 12-28-2007, 09:34 PM   #1
Rob Edwards
Rob Edwards's Avatar
Default Removing tenacious rear main seal?
Feel free to toll your eyes, most people have trouble getting their RMS back in, I can't even get the old one out. I tried prying under the edge of the RMS in the groove at 8 o-clock- no go. Then I gently wedged a 90 degree hook into the side in the groove and tore the rubber coating a little. I recall reading on some BMW site about drilling a hole into the RMS and screwing a screw in a turn or two. I pulled the screw out of the hole. Then I stuck the tip of the 90o hook in the hole, yanked on it, and broke it off, so it's stuck behind the RMS now. So I'm committed to getting this bastard out. And it's now seeping oil down and onto my oil pan. And I'm afraid to jack on it too much for fear of slipping and scratching the crank.
I have the clutch assembly and the TT out, so I have all the room in the world, relatively speaking. I recall seeing a picture of someone's RMS post-removal with strips of rubber still attached, maybe I just need to run a blade around the outer circumference? Is the 'sealing' done entriely around the crank (ie- if I scratch the block where the outer edge of the RMS sits, is that a disaster?) If not, can I either A) hammer the screwdriver under the outer lip in the groove, or B) dremel thru the outer rim of the RMS and break the tension of the ring, a la removing flappy bearings?
My apologies to all the real mechanics who are probably shaking their heads....
Suggestions/tips/hints?
1990 928GT #278, Black/Black, C03 048 418 474 498 538 570 850 691 935 980 114K miles
1993 928GTS 5-speed, Midnight Blue/Light Gray, C02 139 340 418 474 570 586 650 691 980 XD4 XGB65L 100K miles
Wag more, bark less.
Rob Edwards is offline   Reply With Quote
Old 12-28-2007, 09:43 PM   #2
RyanPerrella
RyanPerrella's Avatar
its a pain in the ass in the car.
3 days ago i finally pressed the new seal in, but i havent been bothered to get back under the car and put the flywheel back in cause i am kinda burnt out at the moment
I would suggest the drilling tip, but maybe you need to just try and find something else to use to pry the thing out. I pulled my seal and it was a pain but getting it back in was a bigger PITA,
To install use the old seal, plus the new seal and get longer then stock bolts for the flywheel and use the flywheel and the old seal to press the new one in. When its seated, remove the bolts (3 or 4) remove the old seal thats used as a shim and then fully seat the new seal and reinstall the flywheel using the correct bolts.
1985 928 S3 parts for sale:
S3 cams w/lifters $350
S3 LH and EZ computers $350
RyanPerrella is offline   Reply With Quote
Old 12-28-2007, 09:56 PM   #3
heinrich
928 Collector
heinrich's Avatar
explosives
Actually I punch a hole and grab with a bent pick of sorts... i heat bent a screwdriver. Be careful, the aluminium there is very soft Rob
"Life moves pretty fast. If you don't stop and look around once in a while, you could miss it" ...
'87 S4 5spd all leather 2.64 GODZILLA
94 GTS taking years to resurrect.
Proudly South African
heinrich is offline   Reply With Quote
Old 12-28-2007, 10:02 PM   #4
928ntslow
928ntslow's Avatar
Just take a big screw driver( long handle) , place it in the groove, smack the end with a hammer a couple of time to get the screw driver in there and pry it out. If you can get a bit of an angle on it to get under it some that would be better, but it should pop out. You just want to disfigure the seal a bit to create a gap around the edge by the groove. It'll come out, just don't pussy around with it. Of course be carefull you don't drive the screw drive into the crank shaft.
Keith Widom
GTS = Got The SPEED!
928ntslow is offline   Reply With Quote
Old 12-28-2007, 10:10 PM   #5
heinrich
928 Collector
heinrich's Avatar
Keith I personally am a big believer in pussy. Especially around thin oil galleys....
Old 12-28-2007, 10:37 PM   #6
Lizard931
Lizard931's Avatar
take a fairly thin (cant be too thin) flat head screw driver, file or sand all edges/surfaces to remove really abrasive marks, and slide it between the crank and the seal.
Do not put it between the block and the seal.
This will get you under the metal part of it, move the handle of the screwdriver towards the opposite side of the crankshaft.
This will give you leverage and it will come out fairly easily.
Keep in mind it will probably deform the seal slightly on exit which is fine.
Colin J
Don't steal, the government hates competition!
1981 928S Euro, S4 bumper caps, 86 engine, currently undergoing MASSIVE changes.
1987 928S4 Auto
1987 928S4 5 speed
They ALL have the porkensioner!
PM me for services/parts.
Lizard931 is offline   Reply With Quote
Old 12-28-2007, 10:42 PM   #7
heinrich
928 Collector
heinrich's Avatar
gr8 idea
Old 12-28-2007, 10:42 PM   #8
Rob Edwards
Well, she's out.
Take THAT, beyotch!
Couple of big hits with the BFH, and the old seal buckled. Took about 60 seconds.
The bad news is that I must have made a little ding on the edge of the crank while pissing with my screw or hook:
It's right on that diagonal surface, it's not on the swept surface of the crank, so am I ok if I just emery paper the edge so it doesn't tear the new seal on its way in?
The RMS did manage to extract a lb o' flesh while I was messing with the hook:
Nice view:
Old 12-28-2007, 10:48 PM   #9
RyanPerrella
yeah that is a neat view, it took me a minute to figure where the hell that was. Obviously your TT is out.
How did you find rebuilding the TT? Dont you need to make some type of giant press to get those bearings in and out?
Old 12-29-2007, 12:23 AM   #10
928ntslow
928ntslow's Avatar
Good job...should have waited a little bit to read our advice and you could have saved some trouble. Glad you got it out...didn't pussy it!
Anyway, just tell your friends you got bit by a shark.
Keith Widom
Old 12-29-2007, 12:42 AM   #11
Bill Ball
Under the Lift
Bill Ball's Avatar
I used Keith's technique with not so much force as to cause the screwdriver to nick the crank. The seal has a metal core under the rubber, so the goal is to create a small longitudinal dent in seal at the notch area. One or two smacks will do that. Then use the tip of the screwdriver in the notch and lever the seal out with the shaft against the pan edge. It won't move at first, but will begin to work out slowly. The notch was cut ln the block just for this purpose.
Hopefully your nicks are away from the seal area, although it looks close. Dress them using a small emery point/drum and Dremel to make sure the new seal does not catch on them during insertion. Those nicks are deep. I once made some very fine scratches on a motorcycle counter-shaft while extracting the seal and the new seal leaked worse than the old one. It took a lot of work with an emery point to smooth it out and get the new seal not to leak.
Bill
Grand Prix White 89 S4 - 221K miles - Supermodel Jag/Eaton blower with 6 PSI and air/water I/C
View burnout
Another burnout
If you live in North or Central CA, join our group at Norcal928.org
Bill Ball is offline   Reply With Quote
Old 12-29-2007, 12:57 AM   #12
Rob Edwards
Ryan-
Rebuilding the TT was a snap- 5 easy steps:
1. remove old TT
2. Call Jim
3. Drive to Anaheim
4. Transfer shifter bracket, shifter, and re-align.
5. Install new TT.
Bill:
Dumb question- By 'dress', what would you use to smooth that edge of the crank? I have some 2000 grit sandpaper, but I can't find how that compares to crocus cloth or emery paper. Is that ok?
Old 12-29-2007, 01:11 AM   #13
RyanPerrella
well thats the $400 method right?
I figured you would have just bought the 3 bearings for $50 and done it yourself. Perhaps it is too much of a pain to get involved in all that
Old 12-29-2007, 01:19 AM   #14
Bill Ball
Under the Lift
Bill Ball's Avatar
Quote:
Originally Posted by Rob Edwards View Post
Bill:
I think emery works best on this metal. Crocus would probably be OK. Just trying to take the edge/burr off. If the nicks are in the sealing area, you've got a problem.
Bill
View burnout
Another burnout
Old 12-29-2007, 01:22 AM   #15
largecar379
User
largecar379's Avatar
if there is no seal or bearing riding on the scuffed area of the crank, you could just leave it alone...? other-wise, emory cloth should do......
--Russ
largecar379 is offline   Reply With Quote
Tags
340, afrikan, alamo, bearing, heiri, install, main, method, pussi, pussy, rear, remove, removing, screwdriver, seal
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Contact Us - Rennlist Discussion Forums -
Privacy Statement - Top
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
