Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Sign in using an external account
Register Forgot Password?
Search
This Rennlist Forum is sponsored by      ....dedicated to Your Porsche 928
Thread Tools Search this Thread
Old 01-19-2008, 11:35 PM   #1
Glenn M
Glenn M's Avatar
Default Car keeps running after turned off and key removed?
88 928 Auto keeps running for a few minutes after the key is turned off and removed.
Any ideas?
Meeting up with Wayne (NYC) at our Maryland GTG and he has the problem.
I don't know if the fuel pump is running after the car is off but can't think it is scavenging fuel for three to five minutes turned off.
Thanks,
Glenn
To remove this ad, register today or login if you already are registered!
Cheers,
Glenn
87 928 - Strosek Ultra - AT, X-Pipe, Fuchs RMB
88 928 - AT, LSD, Lumbar, Heat, Extended steering wheel, Cups. Silver/Black "Silver Bullet"
70 Jaguar E-Type 2+2, Navy Blue/Blood Red- "project car"
71 Triumph Stag 3.0L SOHC V8
1980 Triumph TR7
Glenn M is offline   Reply With Quote
Old 01-19-2008, 11:43 PM   #2
Mrmerlin
Petie3rd
Mrmerlin's Avatar
first look at the CE panel and look for water drips or tell tale drips stains ,(look up). if this is happening then check the relays for corroded pins , if you find any (then you need to reseal the bottom of the blower box,) open any corroded relays to inspect the insides they can sometimes look good on the outside and fill with water on the inside.
If all is good here then i would consider replacing the ignition switch, disconnect the battery before you remove the pod, or work on the CE panel
1988 S4 Elfenbein Perlglanz with a full Pearl Gray leather interior, Auto, Motorsport of Utah X pipe
1985 Euro 5 speed with big brakes Black/Black 16Valve
Past survivors sent to new happy owners
1986 5 speed Mossgruen,Brown
1986.5 Auto Meteor metallic/Tan
1984 Euro Auto, Grand Prix white/ Tan
Mrmerlin is offline   Reply With Quote
Old 01-20-2008, 12:00 PM   #3
LT Texan
LT Texan's Avatar
Glenn,
Are you saying it is "dieseling" or is it properly running, as if everything was normal, except the key is off?
Dan / '78 928 5-speed / 928 Owners' Club
LT Texan is offline   Reply With Quote
Old 01-20-2008, 12:38 PM   #4
Mrmerlin
Petie3rd
Mrmerlin's Avatar
if the ignition switch shorts out inside there is a possibility that the electric connection that keeps the car running wont disengage, even with the key turned to the off position.
Remember that the key only turns the steering wheel locking cylinder and the actual igniton switch is screwed onto the rear side of the key cylinder,. So all thats happening when you turn the key is move a rotary switch and unlock the steering lock.
Usually the pod must be removed to replace the IG switch, it is held onto the key cylinder with 2 screws at 12 and 6 O clock, the lower screw can usually be removed without removing the pod but the upper one is very tight with the pod on.
Remember to always DISCONNECT the BATTERY before working on Pod removal or any elex parts
Old 01-20-2008, 10:00 PM   #5
Glenn M
Glenn M's Avatar
Thanks for the replies, looks like Wayne will need to replace the switch.
Glenn
Cheers,
Glenn
1980 Triumph TR7
Old 01-20-2008, 10:09 PM   #6
jon928se
jon928se's Avatar
Check the heated rear window switch also. I seem to have in my mind that if the timer relay sticks on it effectively energises the ignition circuit causing the car to conitue running. Sometimes it is just the push button itself sticking "pushed in"
Jon in OZ
928OC Member
Black SE
Slate Grey '90 GT (hers)
Ex UK, Ex NZ (me and the 928s)
Quote:
Originally Posted by ew928 View Post
Torchwood. Too much kissing. Not enough sci-fi.
Priceless
jon928se is online now   Reply With Quote
Paid Advertisement
Tags
car, dieseling, e, engine, ignition, jaguar, key, removed, running, stays, stop, switch, turned, type, wont, xke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
