928 Forum 1978-1995
Sponsored by: 928 Specialists
ABS electric draw
Old 05-01-2008, 10:37 PM
the flyin' scotsman
the flyin' scotsman's Avatar
Sounds as if you had different issues Ernest...........thx for the input.
Dave............I re-looked (since my tbelt install) at that seroius power cable that electrifies the ABS system; cable is good as are the connections.
Word of caution to all who may be following along................Daves statement that this cable is unfused is absolute.............be very careful in this area. I now wonder if I damaged the realys when doing the tbelt project but I'm sure the batt. was disconnected.
Old 05-01-2008, 11:12 PM
SeanR
SeanR's Avatar
Malcolm,
there is a 14 pin connector up there in that ABS pump box, you might want to take the cover off of it and see if there is any corrosion. It's really not that bad to get to.
Old 05-01-2008, 11:17 PM
the flyin' scotsman
Sean................can you get at it from under the hood?.............I don't see where.
Old 05-01-2008, 11:58 PM
BrianG
BrianG's Avatar
Malcolm, I think you get at it from behind the fender liner pocket....
Old 05-01-2008, 11:59 PM
the flyin' scotsman
thx Brian..............I recall you had an ABS issue..............how was it resoleved?
Old 05-02-2008, 02:08 AM
BrianG
BrianG's Avatar
Eventually found a dead relay...
Was fooled for a while by swapping in another defective one.....
Old 05-02-2008, 03:18 AM
ColinB
ColinB's Avatar
Malcolm
To get to the pump relays is not too difficult. You have to remove the LF wheel and forward wheel arch splash panel. The panel is moulded to wrap around the pump. The relays are on top of the pump under a cover which is secured by a knurled 'finger nut'.
Colin. 89GT
Quick Reply: ABS electric draw
