928 Forum 1978-1995
Sponsored by: 928 Specialists
Rear Interior Foam Underlayment Replacement with Pics
Old 05-26-2008, 02:43 PM
Dwayne
Dwayne's Avatar
Default Rear Interior Foam Underlayment Replacement with Pics
So the foam that was underneath the carpet and spare tire cover at the back of the '84 (my daily driver) had hoplessly disintegrated. Last summer, I cleaned it all out but was left with no foam under the carpet at all. When we purchased my Wife's '88, it had all the original foam in pristine condition so I thought I'd take it for myself! NOT!!
I was, however, able to sneak her's out and use it as a template to make my own. Since this was a first for me and I imagine there are others out there that also need to replace their foam underlayment, I took a few pics along the way.
Here's a list of the materials I used:
1. Replacement Foam (got some from Wal-Mart)
2. Cardboard sheets from a large box at least 2' by 3'
3. Utility knife
4. Felt tip Marker
5. Straight Edge
6. Scissors
7. Spray adhesive (I used 3M 77 Multi-purpose adhesive)
8. Spray paint
Here's what I started with in my car (the previously abused '84).
Name:  01 no foam in 1984.jpg
Here's the foam sections from my wife's '88.
Name:  02 wifes 88 has foam.jpg
The original foam is about 5/8" thick and has a glossy coating on the top side. Its consistency is similar to lightweight foam rubber or the type of material you find in egg crate foam sheets for sleeping.
Name:  03 measurement of orig.jpg
First, I confirmed the size of her tire cover was the same size as mine. And it is. When I cleaned the old decaying foam from the back of my spare tire cover, I could not get 100% of the glue stain color off the plastic. I tried several things such as soap and water, citrus cleaner, brake parts cleaner, mineral spirits, rubbing compount, bug and tar remover. None of which worked very effectively so I cleaned it the best I could with a razor blade.
Name:  04 compare sizes.jpg
Next, I found some cardboard to make a template for the foam pieces. I though it might come in handy to have templates for future use. Here's the foam piece from wifey's '88 on the cardboard.
Name:  05 place on cardboard.jpg
I drew the outline on the cardboard with a marker. Lined up the straight edges with the straight edges of the cardboard to minimize cutting.
Name:  06 draw outline.jpg
I then cut the template out using a utility knife.
Name:  07 cut cardboard.jpg
Here's one of the templates after the cutout.
Name:  08 cardboard template.jpg
I found some foam for replacement at Wal-Mart. It's 2' by 8' by 1" thick, urethane foam.
Name:  09 foam replacement.jpg
It's a little thicker (about 3/8" thicker) than the original foam. I wasn't sure if it would be too thick but thougth I'd give it a try anyway. At least it might provide additional padding and sound deadening.
Name:  10 measure new foam.jpg
I then traced the pattern onto the foam with the marker.
Name:  11 trace onto new foam.jpg
I used scissors to cut the rounds and.....
Name:  12 cut foam with scissors.jpg
....used a straight edge and utility knife to cut the straights.
Name:  13 cut foam with straight edge.jpg
Next, I test fit the tire cover on the foam cutout and installed it in the hatch area to ensure everything would fit. I trimmed the foam where needed with the scissors. You have to be careful when cutting with scissors because it is easy to leave jagged edges. Then I sprayed the adhesive to the foam and to the back of the hard spare tire cover. I let the adhesive sit a couple of minutes then mate the two and line up the notches in the foam for proper fit.
Name:  14 glue foam to cover.jpg
Continued....
Old 05-26-2008, 02:44 PM
RyanPerrella
RyanPerrella's Avatar
Dwayne, your Attachments arent working
OrionKhan
OrionKhan's Avatar
none of the links are working
Old 05-26-2008, 03:02 PM
Joe F
Joe F's Avatar
They all worked for me.
Keep it up. You are inspiring me to do the same job on my 83.
Old 05-26-2008, 03:06 PM
Dwayne
Dwayne's Avatar
Next, I placed both pieces in the area for a test fitting.
Name:  15 test fit foam.jpg
It didn't seem right to leave the foam unaltered and white so I decided to paint it with gloss black spray paint. If you have an old piece of plywood, lean it up agains a table or wall at an angle and put the foam against it. It will stay (like velcro) while you paint.
Name:  16 paint foam 1.jpg
For the piece with the tire cover, it will require the tire cover be taped off to avoid overspray. Make sure you tape the edge of the cover. Otherwise, paint will overspray into the passageways and show up on the plastic cover.
Name:  17 paint foam 2.jpg
After the paint has dried, do another test fit. Don't install in the car right away because it still stinks like paint. Let it air out until you don't smell the paint any more (noticeably). I like the way it turned out. It's not too thick as I thought it might be. I also put scrap foam in the cavities behind the tool holder at the rear of the car.
Name:  18 install painted foam.jpg
Here's a pic with the carpet back in. I would like to get one of those cargo nets like my wife's car has but not sure where they are available - assuming it's original Porsche equipment - not sure.
Name:  19 install carpet.jpg
I'm very happy with the results here. Between the adhesive (which I already had), the spray paint (which I had also) and purchasing the foam, I think the total cost was about $20 and took me about 3-4 hours to complete. Please feel free to comment or suggest improvements. THANKS for reading!
Old 05-26-2008, 03:08 PM
Dwayne
Dwayne's Avatar
Not sure what happened.....when I loaded the pics the first time, they didn't come through. So I edited the post, deleted the links and uploaded them again and now it seems to be working. THANKS.
Old 05-26-2008, 03:36 PM
RyanPerrella
No they work now, no worries!
Old 05-26-2008, 06:22 PM
NickT
NickT's Avatar
Dwayne.. as alway excellent write-ups.. Thanks for taking the time to put it all together...
Old 05-26-2008, 07:10 PM
Brad W
Brad W's Avatar
I used stuff called JUTE for mine. About 1/2" thick.
Quick Reply: Rear Interior Foam Underlayment Replacement with Pics
