928 Forum 1978-1995
Sponsored by: 928 Specialists
88 Fuel Sender Seal Replacement w/pics
Old 06-22-2008, 11:23 PM
Dwayne
Dwayne's Avatar
Default 88 Fuel Sender Seal Replacement w/pics
A while back we noticed the smell of fuel coming from the rear of the '88 after we filled it up. I couldn't find any fuel leaking on the ground but there was definitely a strong fuel smell coming from the rear. I opened the hatch, looked under the carpet and opened the cover over the fuel sending unit. There was fuel standing in the depression all around the top of the fuel sending unit! Apparently the seal was ruptured or had failed.
We drove the car enough to get the fuel level down and it stopped leaking. I ordered a new seal (about $3 at 928 Intl) and just this weekend decided to replace the seal. For other noobies like myself, I've include a few pics of the procedure. I'm still trying to figure out the photo software I'm using on my computer and the pictures are smaller than I'm used to with my old software. Hopefully, they are large enough to make sense.
Before beginning this procedure, ensure you do NOT have a full tank of fuel. Ours was about 1/2 full which worked out well for this procedure. Under the rear hatch carpet you'll find a square fabric pad that is attached to the floor with adhesive. Just peel it away.
Name:  002 peel fabric cover.jpg
Underneath the fabric, you'll find a round black plastic cover. This fits snugly on a lip. Get your finder under the lip (or use a flat blade screwdriver) and pull the plastic cover off.
Underneath, you will see the fuel return hose and the electrical connector to the fuel sender unit.
At this point, if you are not going to be testing the electrical connections, it is wise to disconnect the battery. In my case, I wanted to check voltages coming into the sender and return voltages coming out so I left the battery connected. Just be very carefull not to create any sparks while testing the electrics! The electrical connector simply pulls off. Pull straight up while rocking side to side.
Name:  005 pull plug.jpg
Next, you can open the connector housing by using a flat blade screwdriver to pry one of the side tabs open and pull the top off the connector.
Name:  007 pry cover apart.jpg
With the top off the connector, you can see the wires coming into the sender unit. The brown wire is ground. The purple wire is the voltage that indicates fuel level while the yellow wire is battery voltage and is used to indicate when fuel is so low (reserve) that the low fuel light will come on.
Name:  008 ID wires.jpg
I checked the voltage coming to the sending unit by connecting the voltmeter to the gound and the purple wire while the wires were disconnected from the sender unit. You have to turn the ignition switch on to get the voltage - you do not need to start the car. I receive 5.35V at the sender. When I tested the '84, I received 5.25V at the sender.
Name:  009 voltage to level.jpg
Next, I checked the yellow wire and ground and received battery voltage while the ignition switch is still on.
Name:  011 full voltage.jpg
Next, I reconnected the wires to the sender unit without the connector housing so I could check the voltage coming back from the sender. It should be a smaller voltage than coming in depending on the fuel level. I got 1.917V while the tank was just below 1/2 full.
Name:  012 volts with fuel.jpg
Name:  016 fuel level.jpg
At this point, turn the ignition switch off and disconnect the battery if not done so already. Reassemble the electrical connector in the same order as they came out and snap the top on the connector into place. Then using a flat blade screwdriver, loosen the clamp on the fuel return hose and disconnect. You may want to place a towel around the area to soak up any dripping fuel - the hose is not under pressure but may have some fuel still in it.
Name:  017 remove fuel hose.jpg
Now you can remove the ring nut. I used a large pair of oil filter pliers. Mine was on pretty tight so get a good grip with the tool so you don't damage the ring nut too much - it's just plastic.
Name:  018 remove ring nut.jpg
Once the ring nut is loose, remove it from the sender unit.
Name:  021 remove ring nut 2.jpg
Now you can lift the sender unit out. Lift straight up but don't remove it from the tank. It will be filled with fuel so lift it high enough to let it drain out first then with it almost out of the tank, tilt it slightly side ways to drain what's left in the bottom cup out. Then remove the sender unit.
Name:  022 drain sender.jpg
Continued.....
Old 06-23-2008, 12:01 AM
Dwayne
Dwayne's Avatar
With the sending unit out, you can remove the old seal.
Name:  024 remove seal.jpg
I compared the old seal to the new and it was obvious why the tank was leaking when filled. Parts of the old seal were deformed around the perimeter of the sending unit.
Name:  027 compare old and new seals.jpg
With the sending unit out, just for fun, I checked the resistance of the unit by connecting the multi-meter (set for ohms) to the ground and fuel level pins (where the purple wire goes and the brown ground wire goes). Holding the sending unit upright, the float will sink to the bottom (you should hear it fall). This simulates a completely empty tank. I got 70.5 ohms resistance.
Name:  030 resistance for low fuel.jpg
Then I turned the sending unit upside down and the float falls to the top (simulating a full tank) and I got 5 ohms. So in theory, when the tank is full, the voltage being returned from the sending unit should be close to the same voltage coming in (i.e., 5.35V minus about 5 ohms resistance). A low voltage should be returned (less than 1V) when the tank is empty or near empty.
Name:  031 resistance for full fuel.jpg
Next, you can start putting it back together. First, place the new seal over the top of the sending unit.....
Name:  032 new seal on.jpg
....and ensure it is seated properly all around.
Name:  033 new seal on 2.jpg
Carefully lower the sending unit back into the tank. You will need to feel or search around for the unit to go into the holder at the bottom of the tank. In other words, there's a plastic hood at the bottom of the tank with a round hole in the top of it that the sender unit fits down into. Once you get it, you can seat the unit to the top of the tank. Then place the plastic ring nut back on the sending unit and tighten back down. Make sure the return hose pipe fitting is oriented to (facing) the rubber hose before tightening the ring. Next, you can fit the hose back onto the return fitting. It's a cramped fit but you can bend the hose to get it on - then tighten the clamp with the clamp oriented the same as it came off. Finally, place the electrical connector back on securely then reconnect the battery.
Name:  035 all back together.jpg
At this point, you can fill it up with fuel and check for leaks. I filled it up and let the car sit over night with a completely filled tank and checked for leaks the next day. Dry as a bone! After ensuring there are no leakes, you can put the black platic cover back on, place the adhesive fabric in place and place the carpet back in place. You're done!
Feel free to comment or recommend improvements to this procedure. THANKS for reading!
ezrajones (02-14-2022)
Old 06-23-2008, 12:12 AM
Marine Blue
Marine Blue's Avatar
As always, nice write up!
Doesn't look very difficult either, especially after seeing your step by step.
Old 06-23-2008, 12:29 AM
AO
Supercharged
AO's Avatar
Nice simple, easy-to-follow write up. Good job.
Old 06-23-2008, 12:37 AM
Skiviking
Skiviking's Avatar
As with all of the ones you've done.....JUST GREAT!! The Photo's TOO!!
Old 06-23-2008, 12:40 AM
Daymon66
Daymon66's Avatar
you're an ace Dwayne.
thank you AGAIN for being such a solid and contributing member here...
(maybe i should not have used the words "solid" and "member" in the same sentence..)
Old 06-23-2008, 10:26 AM
Nine2Eight
Nine2Eight's Avatar
Also, NEVER replace the sending unit without replacing the seal. Personal experience here. Put in a new sender, used the old seal, then raced to the gas station for a fillup to see if my gauge was now accurate. Upon returning home, the wife commented on a bad gas smell coming from the car. Sure, I said, I've been working on an open tank and thought nothing of it. Later on she persisted about the fuel odor, so I opened the hatch, pulled the carpet and the fuzzy patch away, only to find to my horror a pool of gas 2 inches deep in the recess on top of the tank and overflowing! Luckily I found a siphon hose and siphoned off the pool of gas, then milked about 5 gallons from the tank to get the level down so it would stop spewing over. Immediately got on the horn to 928 International and ordered a new seal.
Should be here today I hope. In the meantime I have kept the tank at no more than 1/2 full.
Moral - Always use a new seal. Heck, they are cheap enough.
Joe Celeste
Seminole, FL
87 928 S4
64 356 Coupe
Old 06-23-2008, 10:59 AM
ajmarton
ajmarton's Avatar
Great write up. I have been postponing this project for a while but you have inspired me to do it (sometime this summer)! Andrew
Old 06-23-2008, 12:32 PM
Mike Frye
Craic Head
Mike Frye's Avatar
Dwayne, I'm convinced you're a borg with a camera in place of one eye.
One more for the archives. And another vote to have all of your posts immediately go into the 'How-to' section immediately upon posting.
Old 06-23-2008, 01:26 PM
SharkSkin
SharkSkin's Avatar
Nice write-up, Dwayne!
Old 06-23-2008, 03:50 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Another classic added to Dwayne's Garage.
Old 06-23-2008, 04:57 PM
G Man
G Man's Avatar
Dwayne's Garage! What a great idea Bill. Thanks for putting that there for our use.
Old 06-23-2008, 05:28 PM
Dean_Fuller
Dean_Fuller's Avatar
Many thanks from those of us that LOVE pics.
Old 06-23-2008, 05:30 PM
j.kenzie@sbcglobal.net
j.kenzie@sbcglobal.net's Avatar
Fantastic write-up Dwayne. Again!
Old 06-23-2008, 06:55 PM
jpitman2
jpitman2's Avatar
Very useful set of pics for all.
Just so you know....I looked into replacing the rubber end of the return line in my 83 while the tank was out being cleaned etc. The rubber part ONLY comes as a unit with the whole steel return pipe! Very large job to lace the steel pipe also - drop rear suspension! Guess what - a light tug on the rubber end at the tank - slid right off! So, if you have the tank out for any reason, and the end of the rubber is frayed from multiple R&R operations, pull it off, fit a new piece of fuel hose with a good quality hose clip while you have the access necessary. If the tank is NOT out, take care pulling on that hose.
jp 83 Euro S AT 51k
Quick Reply: 88 Fuel Sender Seal Replacement w/pics
