OB Water Pump Replacement
Water pump started leaking so have removed. Seems impeller has been touching block and a small amount of metal has been removed. How serious is this?
Sean
Sean
Under the Lift
Almost never serious unless a lot of metal is removed creating a large gap between the impeller and the block. You say a small amount, so you are probably OK. Post a picture if you can. And for academic interest, it would be nice to see some shots of the WP to determine what happened to allow the impeller to contact the block and any history you might have about the WP (when installed, rebuilt or new, Laso or Porsche).
The pump has a sticker "rebuilt by an independnt rebuilder". The casting has a porsche number embossed on it. The impeller is a brass colored alloy. The bearing failed causing the shaft to skew and allowed the impeller to touch the block. Pics attached
I have heard that a pump with a rubber impeller can be purchased, sound like a good idea. Opinions?
Sean
Sean
Sean,
You can purchase waterpumps with plastic impellers, it is normally not thought to be a good idea as the plastic impellers have been known to freewheel on the shaft causing an overheating issue.
Basic Sponsor
Looks like a Laso casting that has been used in a rebuild.
The more of these Porsche and Laso rebuild failures of the seal cartridge moveing within the casting due to over use of the casting the more I want to go with new!!!
Mine just failed the same way, and my block looks the same. Rebuilt pump (metal impeller) from Int. (15 months and 6k miles)
Needless to say, my S4 that I have spent the last 4 years making nice, now has a bad block. Great!
I really need to read more technical threads and skip the fluff. That is what brought me here in the first place.
Basic Sponsor
Nobody else agrees with me but the interferance fit of the seal cartridge within the casting is the biggest issue. Everytime the casting - be it Porsche or Laso or ?? - is reused the fit becomes looser. Thats why the seal cartridge moves within the casting and towards the block. A new - not rebuilt - casting and seal cartridge assembly is the answer.
Just my 5cents
Just my 5cents
Under the Lift
