928 Forum 1978-1995
Sponsored by: 928 Specialists
2-ohm and 4-ohm speakers mixed in 10-speaker system
Old 09-04-2008, 07:48 PM
MBMB
MBMB's Avatar
Default 2-ohm and 4-ohm speakers mixed in 10-speaker system
On my '89 GT, the rear Blaupunkt woofers are marked 2Ω. The rear Blaupunkt mids are marked 4Ω. The rear tweeters are unmarked. As far as I know these are original equipment speakers.
Porsche appears not to have had a problem mixing 2Ω and 4Ω speakers. Why is this not a good practice?
The MB Quart mids that fit in the doors are too deep to fit in the wheel wells, so I'm inclined to refoam the original mids and stick with them. The woofers have built-in crossovers; can a 2Ω speaker be turned into a 4Ω speaker by soldering a 2Ω resistor in series?
Thanks,
Mark.
Old 09-04-2008, 08:44 PM
michaelathome
michaelathome's Avatar
Here's a good read for you:
http://en.wikipedia.org/wiki/Electri...c_loudspeakers
I hadn't read about it in a while so I wanted to check
Michael
Old 09-04-2008, 09:09 PM
jleidel
Almost Deleted
jleidel's Avatar
MBMB, what size OEM speakers are in the 89's? Its tough to beat the sound of a set of MBQuarts with a clean signal. Diamond Audio used to make some a semi low profile reference speaker for just such applications.
Old 09-04-2008, 09:16 PM
Okv
Okv's Avatar
Originally Posted by MBMB
.. can a 2Ω speaker be turned into a 4Ω speaker by soldering a 2Ω resistor in series?
This is not a really practical solution, because it will change the characteristiscs of the speaker (The electrical Q-factor will be much lower - not that important for a car stereo, this isn't exactly high-end audio..), and more important - the sound level from the speaker will be reduced by 6 dB.
Also, the series resistor would have to be L A R G E, because it must be able to dissipate the same power as the loudspeaker - a, say, 20W resistor may be sufficient - if the resistor gets too hot, it may set the interior of the car on fire before it fails.
And, if there is some kind of passive crossover attached between the amplifier and the speaker, this crossover will not function as intended anymore.
It does not matter if the resistor is put in front or after the crossover.
I think I would leave the speaker as it is, and just gamble that the new stereo unit can handle the 2 ohm load.
Or, you could try to replace the speakers, following advices which I am sure can be found in here - which reminds me, I must read about this now, as I may want to install a new, simple stereo in the shark, just to be able to have the radio in the background.
Car stereo is no fun, actually; too many wires going to unknown destinations, and in the shark there are speakers and amplifiers and god knows what all over the car.
Old 09-04-2008, 10:43 PM
MBMB
MBMB's Avatar
Thanks, Øyvind and Michael.
JLeidel, I'm not quite sure where the speakers are measured. The woofers are 5.5-ish inches, the mids are 4.25-ish.
I'm putting MB Quarts in the doors. I'm no audiophile and the shark cabin is not a concert hall, so I'll probably be content with the stock rear speakers.
Old 09-04-2008, 11:28 PM
David L. Lutz
David L. Lutz's Avatar
Hey Mark, I notice the E55 in your signature. I have an S55 and yes your are so correct in saying "probably worth more to me..." I recently tried to sell mine and well still have it
But a blast to drive
I wouldn't worry about the unmatched speakers you will be OK.
Old 09-05-2008, 02:34 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Refoam the stock speakers. Although MB Quarts and a lot of other speakers will fit the holes, you find yourself installing a subwoofer to get even modest bass. The stock speakers for all their faults, are pretty well balanced and work well if the cones have good foam and the voicecoils don't rattle. Leave the speaker impeadance alone.
Old 09-05-2008, 11:01 AM
RngTrtl
RngTrtl's Avatar
No offense to anyone, but the electrical information is so grossly inaccurate that it is funny. Posts #2 and #4 should be deleted so as not to give someone in the future that is using the search bad info. I swear that I am not trying to offend anyone.
Old 09-05-2008, 11:41 AM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,079 Likes on 1,186 Posts
Rule of thumb, you can always go up in impedance, down depends on the amp.
An amp rated for 2 ohm's will run a 4 or 8 ohm speaker all day long without issues.
Running a 2 ohm speaker on an amp rated for 8 ohms can cause an issue.
This may not be ideal (that's open for debate) but it works.
Then we can get into wiring up stuff in series or parallel....
Old 09-05-2008, 12:28 PM
mj1pate
mj1pate's Avatar
Yes....you can get audio resistors with sufficient wattage, so as to impedance match the load with the amplifier. That will make the amplifier output stage happy again. BUT, do you really want to dissipate half your power to particular speaker across a series power resistor? "Why is this speaker volume so subdued?"
Old 09-05-2008, 07:03 PM
Okv
Okv's Avatar
Originally Posted by RngTrtl
.. the electrical information is so grossly inaccurate that it is funny.
And, that is?
Old 09-06-2008, 06:24 AM
RngTrtl
RngTrtl's Avatar
And, that is?
Shoot me a PM so we dont hijack the thread
Old 09-06-2008, 11:41 AM
Okv
Okv's Avatar
I am sure the others would like to know as well, if faulty information is presented.
Which is always possible; I could be wrong, or, I may have presented the information so that it can be misunderstood.
Old 09-06-2008, 01:29 PM
Fogey1
Fogey1's Avatar
Quote Originally Posted by RngTrtl : Shoot me a PM so we dont hijack the thread
QUOTE Originally Posted byOkv : I am sure the others would like to know as well, if faulty information is presented.
+1. I was already hoping that Turtle would identify the errors he saw, explain and correct them.
Old 09-07-2008, 02:32 PM
MBMB
MBMB's Avatar
+1.
Quick Reply: 2-ohm and 4-ohm speakers mixed in 10-speaker system
