928 Forum 1978-1995
Sponsored by: 928 Specialists
need a WUR
Old 10-13-2008, 11:56 PM
Kevin Michael
Rocket Pilot
Kevin Michael's Avatar
Default need a WUR
The euros and US 4.5 and 4.7 apparently uses the same WUR. So if ya got one PM me price and condition please.
Kevin
Old 10-14-2008, 06:10 AM
tailpipe
tailpipe's Avatar
just buy a rebuilt one from one of the suppliers they are relativley cheap less than $250 with shipping i have tried used ones before and have never EVER had any luck with them if you need a core to send in for rebuild hit the auto wreckers and get WUR off of an early 80s 2.5 ltr turbo audi 5000 or 4000 the casting is the same and the guts are all repaired in the rebuild anyway good luck
paul with 4 79 928s
Old 10-14-2008, 06:19 AM
Nicole
Cottage Industry Sponsor
Nicole's Avatar
What is a WUR? A woman using rennlist?
Old 10-14-2008, 08:44 AM
Kevin Michael
Rocket Pilot
Yes Nicole! And you are the #1 WUR.
Old 10-16-2008, 10:51 AM
checkmate1996
checkmate1996's Avatar
kevin, I have a working WUR that was pulled from my 4.5L that i sold not long ago..
Old 10-16-2008, 11:26 AM
Sean79 5spd
Sean79 5spd's Avatar
My experience is the same as Paul's. I tried rebuilding myself, I tried used ones, no luck. I bought a rebuilt one and have been fine ever since.
Sean
Old 10-16-2008, 01:23 PM
Dennis Wilson
Dennis Wilson's Avatar
+1 on getting a rebuild. If a used one has sat too long, the vacuum diaphram can deteriorate and crack like the last one I bought off Ebay.
Dennis
Old 10-16-2008, 01:32 PM
928ntslow
928ntslow's Avatar
I pulled one off of a 78 that has been sitting out in the Oregon rain for 5+ years...worked like a charm...and still does!
Old 10-16-2008, 01:35 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
Kevin they are NOTall the same...BUT the euro will run with the wrong WUR just not like it is supposed to run ! Since the WUR is the brains of a brainless system it is what controls the mixture at all times during warm up and also adjusts for vacuum , altitude etc. It is the key to getting CIS running while many fuel distributors get blamed and replaced .....the rebuilder has said that nearly half of the ones sent to him have NO PROBLEM .... In the past is was very hard to get Euro regulators and few knew that they were different so many shops / dealers would fit the USA unit and the car would be able to drive away .....Which is the goal of all shops have the car drive away after they have paid their bill.
Old 10-16-2008, 01:55 PM
928ntslow
928ntslow's Avatar
No SH*T Jim!?!?! I had no clue of that. My 82 Euro has a US WUR and seems to run nice and strong. What is the difference in the US version and the ROW? Should I be looking to replace it at some point?
Old 10-16-2008, 02:13 PM
I believe that it gives somewhat more enrichment at higher RPM high throttle opening .....the fuel distributor is the same , the airflow sensor the same....what is different is the WUR....so if a 300 hp engine needs a different fuel delivery curve it MUST come from changes in the control pressure. The 28/11 , 28/ 12 Euro 4.7 S uses a 928 606 109 04 BUT the 28/01-04 ....28/09 and 10 engines the 4.5 use the 928 606 109 05. The WURs only job is setting control pressure which determines the fuel mixture.
Old 10-16-2008, 02:56 PM
Dennis Wilson
The euro WUR has two vacuum ports (side and top). One is for manifold vacuum and the other is intake vacuum. Not sure how they affect enrichment differently than the US version. BTW my 78 US also has the 2 vacuum ports. Converted?
Dennis
Old 10-16-2008, 03:03 PM
928ntslow
928ntslow's Avatar
Same with the US version Dennis...unless that is all I have is ROW WUR's....
Old 10-16-2008, 03:32 PM
Dennis Wilson
Keith,
One vacuum diagram in the WSM shows a single vacuum port but a later diagram shows two. All the other WUR's from my 924 and 931 (both US) were a single port. Now I'm really confused!
Dennis
Old 10-16-2008, 07:31 PM
Kevin Michael
Rocket Pilot
couldn't I just drive down the pin to get a better control pressure Jim? Believe it or not it now has a WUR from a 500 series Mercedes! I just wanted the one that belonged on it.
Quick Reply: need a WUR
