classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#31 |
Rennlist Member Rennlist Site Sponsor Join Date: Jul 2001
No one would know about the suspension or much care , the big brakes would be a plus. S wheels are strong , light, and cheap plus you cannot see the brakes . Tires must have a minimum TWR of 180 .... Cut a magic window in the tunnel to check and add AT trans fluid..... add an additional air to oil trans cooler. Gut everything that is not needed to get the weight well under 3,000 lbs so you can use smaller tubing
I would run it without the rear hatch....
Jim Bailey ph 714-632-9288 , 928 International visit the online store www.928intl.net
#32 |
Kuhmo Ecsta XS tires have a 180 rating reads like it is close to a DOT competition tire which is a very GOOD thing ! Somethings you can save money on but tires are such a huge factor when it comes to handling ! probably good to sell the gas tank and put in a cheap fuel cell !
#33 |
Rennlist Member Join Date: Dec 2005
Location: I be lime'n mon.. on a port tack.... passing snowbirds ;-)
Thanks Jim,
We are starting to take her apart Sunday and will hopefully be posting some parts for sale! ![]() I'm not much of a parts salesman - maybe that's why I can't keep all my 928's in a 3,500 sq ft garage ![]() I wonder if I can buy my own headlights and front spoiler... hmmmmm.. maybe I ought to ![]() I have plenty of S wheels - one set even has the Khumo's mounted ![]() Please keep the ideas coming! Thank you!
Sea Ya, ~~_/) ~ Crazy Mike '87 S4 Auto - Who said there is no such thing as a free car ![]() '86.5 5spd ![]() '85 Euro 5spd "Trouble" X-pipe, dual exhaust, RMB, Short Shift, Cup 2's ![]() '78 Euro 5spd - 4 sail @ $2,000 - mechanical perfection with dyslexic paint! '78 Euro Auto - leMon's wannabe A big set of tools coupled with a little bit of knowledge can be a very dangerous thing. ![]() Those who quote the wisdom of others do so as they have none of their own. |
#34 |
Rennlist Member Join Date: Sep 2006
I'm picturing something like this when you're done...
![]() Every driver signs a waiver... right?
'81 Euro 'S' 928 5-Speed 383 Stroker Project "Muscle-schnitzzzle" >>>>>STROKER?? Has Ricer Lost His %*&$&#)&^ Mind?<<<<<< Yes I look like the Shamwow guy, only old, fat and red hair... Other than that, just like him.
#35 |
Rennlist Member Join Date: Sep 2007
Can you rebadge it so nobody knows its a 928?
Don't want to be fighting rednecks for the derelicts.
85 928 Auto, factory spoiler delete, 87FPR + Porkchip!! 86 928 Auto 84 928 Auto 84 928 5-speed |
#36 |
I was going to ask Mark if I can borrow the 911 number...
maybe the rednecks will think it's a cop car and get out of the way...
#37 |
Big brakes...for lemons?
How about Brembo covers instead for $20. You'll just look like you're stoping quicker.
#38 | |
Rennlist Member Join Date: Dec 2004
Quote:
Mark Litherland 1983 928S 5sp rauchquarzmetallic, Bilstein/Eibach, short shift, 7" E-code Cibies, Fikse FM/10s 17x9 and 17x10, Motorsports Y-pipe + Borla, 928 Motorsports aluminum radiator 79SC, 73 914 2.0 track beast, 71 914 2.0 turbo, 83 928S, 86 951 - all gone |
#39 | |
Quote:
Cool, That saves a good bit of time.....
#40 |
Man of many SIGs
Rennlist Member Join Date: May 2005
This is so exciting. Mike, who is coming over on Sun.?
1984 928s w/ 5-speed 1982 928s Turbo w/ 5-Speed 1978 5-speed Euro Widebody 1980 Auto Silver/Black Needs paint. FOR SALE $2,500 My 928 turbo is like a hot stripper. I just keep throwing money at her and hope that someday she will give me the ride of my life. ![]() 24 Hours Of Lemons Porsche 928 Donations of safety gear will be greatly appreciated. Last edited by Fabio421; 11-26-2008 at 12:38 PM. |
#41 |
Nice video Shawn... Made me GLAD were using the auto trans unit!
I know me, myself, and I will be there ![]() It didn't take Kenny long to decide the black truck in the avatar was less of a chick magnet then the red Porsche, "no wrench - no play", so he's willing. ![]() I can see a case or two of Land Shark appearing to wash down the turkey sandwiches. I know I can drink it myself, but some help would less'n the hang over.
#42 |
It is going to be a nearly 3,000 lb car with driver and fuel at least go to S brakes for the ventilated discs besides you MUST replace the front wheel bearings and get rid of the aluminum lower ball joint carrier anyway. Running the S-4 upper A arm and early lower arm gives you a BUNCH of negative camber , too much so shim it back to about 2 1/2 negative , the tires will thank you and plan on changing the springs at the same time. For the fuel cell get at least a 20 gallon for extended runs. Fueling takes time as do driver changes so long runs are best.
#43 |
Man of many SIGs
Cutting the stock springs would be free and give the same effect, right?
1984 928s w/ 5-speed 1982 928s Turbo w/ 5-Speed 1978 5-speed Euro Widebody 1980 Auto Silver/Black Needs paint. FOR SALE $2,500 My 928 turbo is like a hot stripper. I just keep throwing money at her and hope that someday she will give me the ride of my life. ![]() 24 Hours Of Lemons Porsche 928 Donations of safety gear will be greatly appreciated. |
#44 |
To double the spring rate you would need to cut away nearly 1/2 of the spring .....
#45 |
Man of many SIGs
S-4 springs are double the spring rate of the early cars? Wow, I never knew that.
| Tags |
| 928, 944, build, cibie, coupe, h4, headlights, lemons, pull, sc2, small, trailer, v8, volvo, www24hroflemonscom |
| Thread Tools | |
