Wheel Nut Lubricant
Rennlist Site Sponsor
Wheel Nut Lubricant
From the 1986 booklet of service info by year:
Wheel Nut Treatment on Aluminum Rims
If wheel nuts are lubricated with the wrong type of grease prior to installation or even installed
dry, the spherical calottes of wheel nuts could seize in the countersunk holes of the rims.
The factory is using OPTIMOLY TA paste successfully at the present time.
This lubricant is available in 150gram tubes for Service (Part No. 000.043.020.00).
The tightening torque for wheel nuts is still 130 Nm.
Lots of interesting reading in this series of booklets, available in Jim Morehouse's CD set.
Very interesting - have always put lugs on dry up till now.
Does anyone knwo of non-Porsche equivalent for Optimoly TA? What are we talking about chemically?
Basic Site Sponsor
Basic Site Sponsor
We use the factory lubricant, and have, for 20 years. We "smear" on a coat, every time the wheels are off. Takes a bunch of extra time (if you add it all up, in a year) and the stuff is expensive, but we never have an issue with lug nuts....although we fix a lot of lug nuts that have "issues", from other places. The other thing we do is use a lug nut socket that goes the entire way over the nut portion and torque every lug nut. We're a bit "****".
I've tried just about every product someone has mentioned, but always go back to the factory stuff.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Found this on the landsharks.oz site:
"Optimol, a German Company, was taken over by Castrol many many years ago. Optimoly TA is now
called Optipaste TA and is available in 400 g spray cans, and 500 g or 5 kg containers from Castrol
distribution outlets. Another very similar product is Mobil’s Greaserex RGM-2. [Doug Hillary —
Australian landshark mailing list.] Both Porsche and BMW specified Optimoly TA for wheel nuts on wide variety of models.
Never use a copper based grease such as ‘‘coppercoat’’. The copper reacts with water and bonds the aluminium nut to the steel studs."
Would the standard-issue Permatex Anti-Seize fit the bill similarly?
Rennlist Sponsor
Here is the MSDS sheets for the Optimol TA which lists composition of ingredients that could be compared to similar products.
http://msdspds.castroladvantage.com/...e/113846%2Epdf
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
Received 1,542 Likes
I've always used aluminum-based anti-seize paste on the collet of the lug nut. (And on the back of the rotor and on the mating surface of the back of the wheel on my winter daily drivers.)
And, of course, I always use a torque wrench. So far never an issue.
Thoughts? Wheels about to fall off or....?
A view, perhaps, that has divided nations . .... but I prefer to never lube these surfaces ( I do, however, lube the lips of the hubcentric areas).
Team Owner
This is good information, I always recoat the threads and the collets with aluminum antiseize as well as the concentric hub ( the part that fits into the wheels) so it wont stick when the wheel is being removed.
I have found that uncoated studs have a higher tendency for damaging the lugs and if steel lugs are used they can seize onto the studs..
Think about this next time your removing the lugs and they are shreiking from being loosened.. usually from dry threads.
On the properly torqued lug I have not ever found any of the lugs that I have installed to be loose after being put into service
Wally, this is great info. I've always used the standard Permatex silver-colored goop on wheel lugs without problems-- torqued to spec, always tight when loosened with no "screeching" (gawd I hate that noise!).
But using the factory stuff makes sense, those parts are expensive! And I bet I know where to find it!
Also good thoughts on using the goop on the hub-center. I've never seen corrosion on the 928, but our Volvo xc70 ski-wagon likes to corrode there- a real pain in the butt to get the wheels off. Maybe I'll have to start treating it nicer-- get some Optimaly for the 928 and relegate the Permatex to the Volvo...
Thanks Wally!!
Thanks Wally!!
Basic Site Sponsor
Basic Site Sponsor
BTW....We never lubricate the portion of the lug nut that touches the wheel, just the threads of the stud.
Greg,
The reason for the post can be summed up by the manual statement:
"If wheel nuts are lubricated with the wrong type of grease prior to installation or even installed dry, the spherical calottes of wheel nuts could seize in the countersunk holes of the rims."
Sounds as if Porsche wants the portion of the lug nut that touches the wheel lubed.
Owns the Streets
Needs Camber
Needs Camber
Thanks Wally.
Now I don't have to wonder whether the lug nuts are mounted dry, lubed on just contact surface, lubed threads.
That dry lug nut release graunch is not a pleasant sound.
Owns the Streets
Needs Camber
Needs Camber
I've seen what a not fully seated socket will do to the alloy lug nut.
Not many have enjoyed removing decapitated lug nuts.
When I torque the nuts, I give the socket a nice smack to make sure it's seated fully.
If the smack doesn't feel right, then I've got the socket on a locknut without the key.
(Going to put in normal lug nuts on the next wheel swap cycle.)
