928 Forum 1978-1995
Sponsored by: 928 Specialists
New Product - SHARKVENT Crankcase Ventilation System - NO more Oil in your Intake!
Old 02-26-2009, 12:07 PM
DR
Rennlist Sponsor
DR's Avatar
Default New Product - SHARKVENT Crankcase Ventilation System - NO more Oil in your Intake!
Due to the many requests for a complete bolt-on Crankcase Ventilation System using the Provent I have developed a new product line for all 928s.
Introducing "SharkVent" Crankcase Ventilation Systems.
Below are some sample details and pics from various year models.
You can find full details for your specific year 928 at www.sharkvent.com or visit www.928gt.com and look under "Performance", then "Crankcase Venting".
Special Introductory sale pricing is available for the next few weeks.
Kits are shipping now, but there is an approx 1 week wait time for new orders.
A complete, simple, and highly effective Crankcase Ventilation System for your 928.
Self contained, no messy catch can to worry about!
Genuine Porsche 928 Hoses/Clamps/Adapters used where ever possible.
Custom Hand-crafted Powder Coated Aluminum Fittings for a Perfect Factory Type Fit to your 928.
Our SharkVent Systems completely eliminates any oil vapors going back into the intake tract.
Some of the benefits of preventing the oil from entering the intake of your 928 are:
Reduced oil consumption.
More power and better fuel economy.
Reduced tendency to knock or ping.
Cleaner intake tract, ports, valves, and combustion chambers.
Typical SharkVent 32V Systems
(There are separate versions for 85-86, 87-88, 89-92, and 93-95)
The 928 Specialists 32V SharkVent System is available in 2 versions:
(See illustrative graphics below)
Standard SharkVent:
Requires no physical modifications to your 928.
Uses the original factory cam cover and oil filler neck crankcase vent ports.
Recommended for stock or mildly modified 928s.
SharkVent X (Xtreme):
Additional 1" Oil Filler Neck Port for increased crankcase breathing.
Requires drilling a 1" hole in the oil filler neck.
Includes Custom Aluminum 1" Elbow with 5/8" Port added for the Cam Cover Vents.
Recommended for highly modified and/or Race 928s..
Typical SharkVent 16V System
(there are separate Versions for 78-79, 80-82, 80-83 Euro, 83-84 US, and 84-86 Euro)
928 Specialists 16V SharkVent:
Includes Custom Adapters for additional venting from the cam tower and oil filler lid crankcase vent port.
Recommended for stock or modified 928s.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old 02-26-2009, 12:20 PM
ptuomov
ptuomov's Avatar
Originally Posted by DR
[CENTER]Due to the many requests for a complete bolt-on Crankcase Ventilation System using the Provent I have developed a new product line for all 928s.
Is there an emissions legal or legalish version of this system?
Old 02-26-2009, 12:25 PM
DR
Rennlist Sponsor
DR's Avatar
The separated Air Out is very clean and you can accomplish this in a couple of ways.
You can very easily run the "air out" back into the port on the air cleaner lid by "Y"ing it with the air pump bypass hose.
OR, you can be sneaky and hook up the air out to the air pump inlet hose. Then it passes the air thru the air pump system and out the exhaust. This method will give you more scavaging of the crankcase vapors (think vacuum pump).
On an 87-up the Air Pump filter hose is right beside the ProVent so it is Super easy to do this(see photo). We offer an inexpensive Air Pump Hose for the 78-86 that does the same thing.
Old 02-26-2009, 12:35 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,072 Likes on 1,183 Posts
DR,
I'm assuming you are tying into the stock drian back hose on the 16V. The stock hose is NLA (last time I checked) and somewhat fragile. It's a very simple 90 degree hose, might be worth looking into offering a good replacement over stock.
Time for a plug
I have a very similar setup on my supercharged 81 - works very well.
Old 02-26-2009, 12:38 PM
DR
Rennlist Sponsor
DR's Avatar
Originally Posted by Hacker-Pschorr
DR,
Time for a plug
Correct, see photo below.
I have no problem getting that hose, the one in the pic came in 3 days ago. BTW, As you can see in the pic it is a little more than just a 90. This is the newer style hose that replaced the very early "single 90" hose.
Old 02-26-2009, 12:39 PM
Fabio421
Man of many SIGs
Fabio421's Avatar
DR,
Time for a plug
If you are refering to the hose that goes down the front of the engine between the stock catch can and the oil pan, it is available. I bought two of them within the last couple months.
Old 02-26-2009, 12:46 PM
hacker-pschorr
It's been a couple of years since I needed one, maybe supply has changed or I'm thinking of a different hose....
The part I've had fail (twice) is the 90 degree bend part, cracking on the underside and leaking oil down the front of the motor. You could use a straignt to 90 hose down to your adaptor, and still use the lower curved section. I forgot about the lower curved section since I keep re-using the same one
But - if the hose is readily available like you and Fabio pointed out, then I recommend people replace it like every other 20+ year old hose on their 928
Old 02-26-2009, 12:49 PM
ROG100
Basic Sponsor
ROG100's Avatar
DR,
Very nice and an awesome addition to your product list.
Does this mean my GTS will stop smoking every time I hit the throttle hard?
Thanks,
Roger
Old 02-26-2009, 12:51 PM
DR
Rennlist Sponsor
DR's Avatar
They are also pretty cheap, if I can get some costs of the kits down in other areas (Making those custom fittings is killing the cost) I will start including one of those hoses pre-assembled with the Oil Return assembly.
Old 02-26-2009, 12:53 PM
hacker-pschorr
Ok, I must be thinking of a different hose since I paid a small fortune for the one I'm thinking of.
Brain dead this morning........
Old 02-26-2009, 12:55 PM
DR
Rennlist Sponsor
DR's Avatar
Originally Posted by ROG100
DR,
Thanks,
Roger
Thanks Roger.
IF the smoke is coming from the excess oil in the intake it will for sure eliminate the smoke, it will also reduce oil consumption in the GTS ... unless it is caused by Piston and/or valve guide issues.
Old 02-26-2009, 01:14 PM
Rick Carter
Rick Carter's Avatar
Can I buy the kit minus the ProVent? Good work as always.
Old 02-26-2009, 01:21 PM
Fabio421
Man of many SIGs
Fabio421's Avatar
I think it was around $20. I can't remember exactly but it wasn't something that struck me as crazily overpriced since it does have that special little curve to avoid the belt.
Old 02-26-2009, 01:23 PM
DR
Rennlist Sponsor
DR's Avatar
Hi Rick,
Of course, I haven't added the Variants on the product pages for that option yet, but you can always call me or Jeannie. BE sure to let us know if you already have the check valve or not.
If there is enough interest we also are thinking about offering a Kit with just the ProVent, Check Valve and Mounting Bracket for those that want to get and/or make their own hoses, fittings, clamps etc. I realize that the kits are pricey due to all the custom fittings and stuff we make here, plus using Porsche clamps and hoses etc. So if I can offer a "Do it Yourself Kit" to help out I will be happy to do it.
Old 02-26-2009, 02:19 PM
PorKen
Inventor
PorKen's Avatar
Dave,
Have you considered making a oil fill cap with a vent pipe instead of drilling the tower? (Like Louie and others have done?)
Quick Reply: New Product - SHARKVENT Crankcase Ventilation System - NO more Oil in your Intake!
