Weird Turn Signal Behavior
I turn into the drive, put it in park, pull the handbrake, turn the light off and remove the key. The warning bell keeps going off telling the light are still on. I turn the light switch but it full left. I'm looking and looking and find that my left turn signal is still on. Not blinking but on. With the ignition completely off and the key removed, I center the turn stalk and the bell goes off. Is this normal?
Team Owner
Yes the owners manual will describe the turn stalk functions, this is a normal feature
I don't have the stupid "ding ding ding", but that switch is supposed to light the parking lights on one side of the car with the key out. For dark alleys or something like that. We all park in dark alleys on a regular basis, right?
Road Warrior
my headlights pop up whenever a hottie crosses the street in a crosswalk in front of my shark. don't know why, but it must be a feature of some kind... maybe it's a male shark?
Right, Alan.
I just re-read the OP. It keeps "dinging" with the key out and the stalk not in the center position? That doesn't sound right. Unless it only does it while the door is open, which would make sense but I am not sure exactly how it is supposed to behave.
Yeah, the ignition off, key removed, lights off, turn stalk not centered, door open then we get Ding, Ding, Ding.
[Edit]I see that the member websites are acting up again. Attaching the image to make sure the damn thing shows up. [/Edit]
Electron Wrangler
Yes on the later models the chime is activated when the door is open and either: the keys are left in the ignition, the marker lights are on or the parking lights are activated on either side.
The warning is for current draw and security issues.
Alan
Alan
They're called parking lights for a reason
You can leave those side lights on, to help other drivers avoid driving into the side of your car.
If you've driven down the narrow countryside lanes you get all over Europe, you'll understand why this is actually a good thing to do sometimes
