928 Forum 1978-1995
Sponsored by: 928 Specialists
Hot Air From Center Console
Old 05-04-2009, 01:08 AM
oceanvue
oceanvue's Avatar
Default Hot Air From Center Console
When I open my windows the vacuum creates hot air and I mean HOT AIR coming up from under my center console to the point that the metal base of the auto stick will get hot. My wrench is stuck as it appears that the insulation is all in place. This thing is a real bummer...Has anyone else had this and what was the remedy? I seached and nothin' doin.
Old 05-04-2009, 01:22 AM
blown 87
Rest in Peace
blown 87's Avatar
Just because you can see the foam there, it does not mean it is all there.
Mine just had fell apart in many places I could not see.
Just a touch and in places, it would crumble.
Old 05-04-2009, 01:53 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
How are you motor mounts?
Old 05-04-2009, 01:56 AM
Nicole
Cottage Industry Sponsor
Nicole's Avatar
Did you run over a used car salesman lately?
Old 05-04-2009, 06:35 AM
Ron_H
928 Barrister
Ron_H's Avatar
Motor mounts most likely. Miserable condition especially on hot summer nights when the sunroof is open.
Old 05-04-2009, 09:08 AM
Stylemobile
Stylemobile's Avatar
Will someone please explain the relationship between motor mounts and this hot console condition?
Tanks,
Allen
Old 05-04-2009, 09:15 AM
sidehatch
sidehatch's Avatar
Its that toilet bowl contraption on the passenger side in the engine compartment its not closing.I had the same thing happen.
Old 05-04-2009, 09:39 AM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
If the motor mounts are bad (as they are on most 928s), they collapse enough to let the foam insulation pull away from the floorpan. This allows hot air from the engine and exhaust to enter the opening in the floorpan and thus into the center console.
Plan on getting really. really dirty and frustrated over a long day of work as you replace the motor mounts, steering rack mounts, rack boots and oil pan gasket - but the results are worth the effort!
Old 05-04-2009, 10:21 AM
Angel84-928
Angel84-928's Avatar
Wally, I replaced all that and I'm still getting that heat coming up from the center Console. Just like the OP stated, the shifter gets really hot.
Old 05-04-2009, 10:49 AM
heinrich
928 Collector
heinrich's Avatar
Old 05-04-2009, 11:14 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,283 Likes on 1,265 Posts
also what can happen is that when the TT is removed the foam padding can be cut or not replaced correctly or eaten by animals, any of these things can cause the foam to not seal.
Worn MMs can also cause this as they let the drive line slip down a bit and then the foam isnt pressed up into the chassis hump
Old 05-05-2009, 05:23 AM
tailpipe
tailpipe's Avatar
has anyone tried putting spray foam like in the arisol cans down the sides through the shifter hole? Might be a cheap easy fix just don't get any foam on the interior its a bitch to get off
Old 05-05-2009, 10:36 AM
oceanvue
oceanvue's Avatar
Can the motor mounts be checked visually and is replaciing the foam and the motor mounts lateral jobs meaning if I'm doing the foam (or having it done in my case) than the MM's are just a step away?
Old 08-23-2016, 01:44 PM
linderpat
linderpat's Avatar
Received 2,259 Likes on 1,259 Posts
resurrect thread (rennlist search function really sucks anymore). I know this topic has been covered, but what are the easy fixes for that insulating foam under the shift lever?
Old 08-23-2016, 01:55 PM
Ron_H
928 Barrister
Ron_H's Avatar
In my case, my motor mounts had collapsed compromising the fit of the foam gasket against the tunnel. Replacing your motor mounts will probably cure the problem.
Quick Reply: Hot Air From Center Console
