Hardware source for automotive bolts, washers?
I haven't had much luck finding a source for replacement washers and bolts for my engine rebuild. Secondly, the original porsche hardware seems to be on backorder very often. Specifically, I am looking for (according to PET) m12 x 1.5 washers for the head studs. Any leads?
Here are some 12 x 2.5...
http://www.eagleday.com/washerkits.html
They seem to stock lots of metric stuff, and the price is right.
http://www.eagleday.com/fayzi.html
Maryland Metrics stocks any metric fasteners or any metric hardware known to the civilized world. Ask for John.http://mdmetric.com/
Hammer
Hammer
I have purchased from boltdepot.com
Fastenal (sp) is a source too. Their website says they have a washer similar to the rubber backed one used on the valve covers on an '85.
I'm reasonably sure that washers aren't spec'd by the same grading as bolts. But they will be hardened for sure are probably thicker than, and probably won't have chamfered edges like, a plain washer. They may possibly have a surface finish that is higher quality than a plain stamped washer, reduce torque losses when tightening.
Not a home despot purchase.
Team Owner
you should either use the old washers of the correct type or new ones of the correct type.
They dont usually go bad unless they have gotten corroded, i am sure there are a few used ones floating around that will work fine
Hammer
Hammer
