928 Forum 1978-1995
Sponsored by: 928 Specialists
FREE - Printable Relay stickers
Old 05-31-2009, 10:35 AM
aircooler
aircooler's Avatar
Default FREE - Printable Relay stickers
Hello all,
Here is a little project that I did a few years ago. These pics are of relay name stickers for printing on adhesive paper.
Right click and save the larger file for printing.
Once printed, you can then apply an adhesive laminating material over top of them (or just simple clear packing tape), and just stick them on your relays for easy ID.
I offer no guaranty that they are correct. I don't have the time to check them for accuracy, nor correct any problems if any. Please don't ask.
The first pic is of the sheet for web viewing. The second is for saving to print.
Cheers,
Michael
Now don't go mess around with trying to print on specific Avery label paper.
This is too easy.
Just print a test page on regular plain paper. Cut one of the relay stickers out to make sure your printer has sized the full sheet of relays to a good size for a real relay. If it has, then you are good to go.
Pick up (at Staples, Office Depot, etc) a packet of Avery "FULL SHEET LABELS" like these below...
Print a whole page of relay stickers on one page of Avery "full sheet label" paper. Once you have printed the relays, run some clear packing tape over the printed relay stickers to laminate them. (You can also buy Avery full sheet laminating film, but packing tape should be fine)
Now you just cut the relays stickers out of the full sheet, peel the backs, and stick them to your relays.
I do recommend leaving the relays in the car while applying the stickers. It makes the whole process allot easier. Also, make sure you dust/clean the top of the relays so that the adhesive with stick well.
BTW if anyone wishes to make changes, the font is DENMARK. Common to MSWord.
Cheers,
Michael
The following 8 users liked this post by aircooler:
Bales (10-23-2021), dimi5928 (06-11-2022), English Bob (01-29-2022), esharon (01-07-2023), JJ928S4 (01-07-2023), Kolll (02-11-2023), no.radar (01-22-2022), Pete in DC (01-28-2022) and 3 others liked this post. (Show less...)
Old 05-31-2009, 10:40 AM
JWise
JWise's Avatar
Cool, thanks!
Old 05-31-2009, 11:10 AM
Herman K
Herman K's Avatar
Default Very Nice....
I like that, thanks for sharing...
Old 05-31-2009, 11:15 AM
Kevin Michael
Rocket Pilot
Kevin Michael's Avatar
Excellent.
Old 05-31-2009, 12:47 PM
ew928
Owns the Streets
Needs Camber
ew928's Avatar
Cool.
Now if only someone like 3M will make kevlar reinforced sticker paper we can wrap around the whole relay so the top can doesn't pull out from the base.
Old 05-31-2009, 01:59 PM
aircooler
aircooler's Avatar
BTW, the relays that are part # 141.951.253.B are all highlighted in reverse so you can see what relays are interchangable for trouble shooting.
Cheers,
Michael
Old 05-31-2009, 02:35 PM
leperboy
leperboy's Avatar
Originally Posted by aircooler
Hello all,
Very cool. Aircooler, do you mind if I use your template to make an 85-86 set of stickers to post for us early 32V'ers?
Matt
Old 05-31-2009, 05:27 PM
aircooler
aircooler's Avatar
Have at'er man
Cheers,
Michael
Old 05-31-2009, 05:58 PM
Leon Speed
Leon Speed's Avatar
Cool, thanks a lot
Old 05-31-2009, 07:18 PM
Rick Carter
Rick Carter's Avatar
Matt
Have at'er man
Cheers,
Michael
I look forward to it, thanks!
Old 05-31-2009, 07:30 PM
Manfred
Manfred's Avatar
Thank you many times over.
Old 05-31-2009, 07:48 PM
kccampro
kccampro's Avatar
Many thanks!!!!
Old 05-31-2009, 08:45 PM
Marine Blue
Marine Blue's Avatar
Thank you Michael, very much appreciated!
This also helped me to realize that the two fuel pump relays I bought for my S4 will also work in the GT.
Old 05-31-2009, 08:49 PM
mark kibort
mark kibort's Avatar
That was very cool to do this. Im printing it out and sticking it to my false fuse box cover in my race car!
Old 05-31-2009, 09:12 PM
blown 87
Rest in Peace
blown 87's Avatar
Now I have another thing to do before I can make SITM.
Thanks man, neat idea.
Quick Reply: FREE - Printable Relay stickers
