Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Sign in using an external account
Register Forgot Password?
Search
This Rennlist Forum is sponsored by      ....dedicated to Your Porsche 928
Thread Tools Search this Thread
Old 06-14-2009, 04:43 PM   #1
oups59
oups59's Avatar
Send a message via MSN to oups59
Default Another bad day - Coolant in engine oil !!
When for a ride today and after 100 miles my coolant warning light went on. I stopped and 2 liters was missing. Drove back home and another 1,5 liters was needed.
I tried to find the leak but the visible leak. The car was not overheating, in fact the temp needle was at 1/3 like always.
Then I found this Looks like the coolant is in the engine oil.
Head gasket ??
To remove this ad, register today or login if you already are registered!
Luc
'88 928 S4 Venetian Blue 5-speed C02 018 158 220 383 387 418 474 481 494 650
'87 928 S4 Silver AT folding wing LSD --(Sold )--
'88 928 S4 Black 5 speed Euro --(Sold )--
PCA-Rennsport Region
oups59 is offline   Reply With Quote
Old 06-14-2009, 04:49 PM   #2
blown 87
Rest in Peace
blown 87's Avatar
Maybe it is a head gasket, maybe not.
I have seen more than a few cars look like that when the problem was a lot of short drives or the engine never getting hot enough.
Good luck.
Greg
blown 87 is offline   Reply With Quote
Old 06-14-2009, 05:02 PM   #3
Fogey1
Fogey1's Avatar
I'd think that a 200 mile round trip would have gotten the oil hot enough long enough to boil off H2O condensate.
Time to get out the compression tester. ;-(
Good Luck X 2.
ww
Fogey1 is offline   Reply With Quote
Old 06-14-2009, 05:14 PM   #4
oups59
oups59's Avatar
A bit more info.
1. No white smoke on start up
2. No oil in the expansion tank
Luc
Old 06-14-2009, 05:20 PM   #5
blown 87
Rest in Peace
blown 87's Avatar
Good Luck X 2.
ww
Not in the oil filler neck, once it is there, it normally stays there on most cars.
How does the oil look on the stick?
That is a go-no go test?
As far as a compression test, it would have to be a really bad head gasket leak to find it with a compression gauge.
See if you can find a shop that has a chemical called Block Test and a tool to use it in, that will show if any chamber gasses are getting into the cooling system.
Old 06-14-2009, 05:26 PM   #6
oups59
oups59's Avatar
Quote:
Looks normal. No white deposit on the stick.
Luc
Old 06-14-2009, 05:27 PM   #7
zoltan944
zoltan944's Avatar
Quote:
Originally Posted by oups59 View Post
A bit more info.
HG leaks can be one way- coolant to oil or oil to coolant
with all that coolant loss with no visible signs.....
you really do need to check the dipstick tho. It is also possible there is no smoke because it is going to the oil and none-a little is going into the chamber. But with all that coolant loss you should be able to see the deal on the dipstick.
let us know
zoltan944 is offline   Reply With Quote
Old 06-14-2009, 05:28 PM   #8
zoltan944
zoltan944's Avatar
so the oil on the dipstick doesn't look like 'milk chocolate'?
Old 06-14-2009, 05:39 PM   #9
blown 87
Rest in Peace
blown 87's Avatar
The vast majority of cars we see with blown head gaskets have no coolant in the oil or oil in the coolant.
most times it goes out the tail pipe.
Old 06-14-2009, 05:45 PM   #10
oups59
oups59's Avatar
Quote:
Looks good !!
Luc
Old 06-14-2009, 06:09 PM   #11
Bill Ball
Under the Lift
Bill Ball's Avatar
With that much loss of coolant that fast, no white cloud and and no external leak, I would have expected chocolate milk. A leak in the radiator sidetank oil cooler is another possibility but that usually leaks the other direction as coolant pressure is about 15psi and oil usually much higher except when the engine is turned off. In that case I would expect chocolate milk and oil in the coolant. The one time I actually saw this type of leak, it was almost all oil in the coolant.
Bill
GP White '89 S4 - 265K carefree (well, almost) miles, creeping up slowly on 300K. Motor unopened and original TT bearings.
'87 rear resonators; '83 LSD; PKlamp on TT, Bilsteins, 2002 996 wheels; Momo Club 4 steering wheel; H4 Hi/Lo HID headlights; HID driving lights.
Sharks in the Park XIII, May 4, 2013 - Tilden Park, Berkeley, CA.
If you live in North or Central CA, join our group at Norcal928.org
Bill Ball is offline   Reply With Quote
Old 06-14-2009, 06:29 PM   #12
blown 87
Rest in Peace
blown 87's Avatar
Quote:
I am betting that the external leak has not been found yet.
Old 06-14-2009, 06:44 PM   #13
oups59
oups59's Avatar
I will put the car on jack stand tonight and take a closer look.
Luc
Old 06-14-2009, 06:47 PM   #14
tveltman
If you can do a leakdown test, you may be able to spot the leak if it's in the head gasket. Pull the plugs, remove the dipstick, airbox, and coolant expansion tank cap, and move the cylinders to TDC one at a time, and while at TDC, use the gauge (which hooks up to an air compressor) to pressurize the cylinder. You will hear some hissing from the dipstick, though not a lot, and this is normal, because no piston-to-cylinder seal is perfect, but if you hear it hissing through any of the other cylinders, or if you see/hear bubbles in the expansion tank or excessive noise from the dipstick, then it's probably a head gasket (unless the head or block is cracked, which we all hope it isn't). Good luck!
BTW you can get a leakdown tester from Harbor Freight. I used it on mine and it worked fine, and it hasn't broken yet, despite two or three uses. If you don't have an air compressor, then see if you can find someone who does. Although they are useful, I wouldn't buy one just for the test.
Thomas
'88 S4 Marineblau metallic, 5 sp.
'84 Toyota Hilux, 2L engine, 5 speed, 4WD
Proud owner since 2003
tveltman is offline   Reply With Quote
Old 06-14-2009, 06:50 PM   #15
oups59
oups59's Avatar
Just another info. I am using a 35% anti-freeze and 65% water. Would that change anything?
Luc
Paid Advertisement
Tags
2005, 951, bad, boxster, condensation, coolant, cooler, engine, freight, gasket, harbor, head, mixing, oil, pic, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
