Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Sign in using an external account
Register Forgot Password?
Search
This Rennlist Forum is sponsored by      ....dedicated to Your Porsche 928
Thread Tools Search this Thread
Old 06-25-2009, 04:11 PM   #1
The Sharkologist
User
The Sharkologist's Avatar
Default Exterior Door Handle Removal
Next question... Is there a way to remove the exterior door handle without gutting the entire door? I've done that a few times, but seems like an awful lot just to get to that piece. Anyone ever removed one a different way?
Just trying to soak up anything I can, I should have been on a here a while ago... so far the information and responses from everyone have been great. Thanks everyone.
To remove this ad, register today or login if you already are registered!
The Sharkologist is offline   Reply With Quote
Old 06-25-2009, 04:53 PM   #2
Hilton
Hilton's Avatar
Short of sawing through the arms on it, the minimum I'd say you have to remove is:
Unscrew interior door handle and rotating lock ****
Remove door card and 5 bolts holding door panel in place, as well as the 2 pesky screws hidden in the carpet.
Pull the panel clips out, unplug the switches (if drivers door or memory seat), and remove the panel completely for space
Peel back plastic moisture barrier
Wind window up - remove the bolts on the annoying security shield
Wind window down - wiggle security shield out while carefully scratching your tint in several places
Unbolt the handle
I took the lock out completely last time I did this - adds a little maneuvering room for the anti-theft plate, and not hard to do.
Hilton
87 & 89 ex-UK no-sunroof 5-speed S4's
Hilton is offline   Reply With Quote
Old 06-25-2009, 05:12 PM   #3
The Sharkologist
User
Quote:
Unscrew door handle and rotating lock ****
Unbolt the handle
Thanks Hilton! I'm pretty familiar with removing the door panel, and that pesky security shield! ...I might use a different word than pesky, but not so appropriate for here. I was working on one this morning, and attempting to record the process for everyone to see. Unfortunately, I was a little impatient and the outer latch bolts stripped on me with very little effort... after attacking that with an arsenal of weapons, I had to stop to get other work done. So then I thought, well cool, now I can upload a video removal of the door panel at least... but apparently I WASN'T RECORDING!!! It's about 93 outside right now (at least 100 in the shop), and I don't feel like fighting with it anymore today. But stay tuned, the photo shoots and videos are in process... Started on that sliding roof cable this morning also, danglerb (if you're reading)
-TS
Old 11-25-2011, 12:49 PM   #4
pavlooshka
New User
Im working on the same drama. Looking forward to taking a look at what you have with pictures and/or video.
Id like to get a better idea so I dont rip out any guts.
Whats the "security shield" you guys speak of?
Thanks.
pavlooshka is offline   Reply With Quote
Old 11-25-2011, 01:00 PM   #5
Rob Edwards
Rob Edwards's Avatar
Good pics of the security shield here:
http://forums.rennlist.com/rennforum...-write-up.html
1993 928GTS Midnight Blue/Light Gray, C02 058 130 139 218 239 323 340 403 418 423 437 438 464 474 481 484 537 553 562 567 570 573 586 595 602 650 691 912 980 XD4 XGB65 105K mi
1988 S4 5-speed, White/White, C03 158 220 418 474 481 494 513 538 570 586 650 91K mi
There's no "O" in VIN.
928 Option Codes List, Current as of October 2013 Here: https://webfiles.uci.edu/redwards/pu...2010-7-13.xlsx
Rob Edwards is offline   Reply With Quote
Old 11-25-2011, 01:28 PM   #6
Landseer
Landseer's Avatar
Lifting exterior handle a bit can give a better angle of approach to the nuts that hold it in place.
Several mid-series (84,5,6) 928's.
Landseer is offline   Reply With Quote
Paid Advertisement
Tags
964, cayenne, door, exterior, front, handle, hidden, inside, instructions, knob, panel, porsche, removal, remove, removing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
