Last Bolt for Rear Seat Backs
Where's the last bolt for the rear seat back inner mounting bracket? That is, that fastens the body side of the bracket alongside the rear seat console unit.
I found the one that you reach through the slit in the upholstery to the rear of the seat, but there's one more lurking under there somewhere ...
Should just be the two 6mm allen bolts. Put the backseat down to access them, then slide the seat out away from the center console after the bolts are removed from the side bolster. There shouldn't be anything on the side of the package box (center console). Hope that helps
