Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Old 07-12-2009, 04:29 AM   #16
worf928
worf928's Avatar
Quote:
Originally Posted by Bill Ball View Post
So, do we have a consensus?
Let's start a poll.
-- Dave C
94 928GTS - Iris Blue 5-speed (CarChick's ride)
91 928GT - Amazon Green Metallic - 928SP TSIC-0011
89 928GT - Black
928 Owners Club Charter Member
Inspecting a 928? Link to my guide: 928 Periodic Inspection.pdf Or, just the tables: 928 Inspection Tables.pdf
worf928 is offline   Reply With Quote
Old 07-12-2009, 07:31 AM   #17
Sailmed
Sailmed's Avatar
Location: I be lime'n mon.. on a port tack.... passing snowbirds ;-)
Water is highly over rated - lets just circulate amsoil and the WP bearings will last forever!
Sea Ya,
~~_/) ~
Crazy Mike
'87 S4 Auto - Who said there is no such thing as a free car
'86.5 5spd
'85 Euro 5spd "Trouble" X-pipe, dual exhaust, RMB, Short Shift, Cup 2's
'78 Euro 5spd - 4 sail @ $2,000 - mechanical perfection with dyslexic paint!
'78 Euro Auto - leMon's wannabe
A big set of tools coupled with a little bit of knowledge can be a very dangerous thing.
Those who quote the wisdom of others do so as they have none of their own.
Sailmed is offline   Reply With Quote
Old 07-12-2009, 07:43 AM   #18
Lizard931
Lizard931's Avatar
I will still use the rebuilds.
Colin J
JDS Porsche Western Canada Supplier.
Don't steal, the government hates competition!
1981 928S Euro, S4 bumper caps, 86 engine, currently undergoing MASSIVE changes.
1987 928S4 Auto
1987 928S4 5 speed
They ALL have the porkensioner!
Lizard931 is offline   Reply With Quote
Old 07-13-2009, 12:46 AM   #19
H2
H2's Avatar
I've replaced 3 pumps on 3 different cars...all Porsche new. I'm hoping someone comes up with a more secure design before my next WP job.
Where's PorKen on this issue?
H2
H2 is offline   Reply With Quote
Old 07-13-2009, 02:09 AM   #20
GregBBRD
Quote:
Originally Posted by blown 87 View Post
The pumps that Greg and I had fail were new lasso's and both were adjusted with the 9201 and his failed very quickly, mine went about 3000 miles.
I used a Snap-On torque wrench and it was installed correctly with new everything that the belt touched and many things it did not.
For your and my failures, the pumps could have been installed with an impact and the belt could have been at 12.9 belt units and none of that stuff would have a thing to do with the impeller falling off. That's just a damn poor press fit. Laso certainly "changed" their design to compensate....on the "new" version. They use the same impeller and the same bearing, but they put a bushing into the impeller to tighten up the press fit. I'd guess that they have a whole bunch of impellers already machined, discovered they are too loose, and did the logical thing to "save" a few bucks....install a bushing.
I do have the tool done to fix the block. Just waiting for Steve to finish up the inserts and the insert drilling tool. I'll start a thread about this stuff, when it is all done.
gb
GregBBRD is offline   Reply With Quote
Old 07-18-2009, 08:51 PM   #21
JG928S4
User
JG928S4's Avatar
any more comments??
JG928S4 is offline   Reply With Quote
Old 07-18-2009, 10:02 PM   #22
heinrich
928 Collector
heinrich's Avatar
Mattel make a cool pink one.
"Life moves pretty fast. If you don't stop and look around once in a while, you could miss it" ...
'87 S4 5spd all leather 2.64 GZILLA
94 GTS taking years to resurrect.
Proudly South African
heinrich is offline   Reply With Quote
Old 07-18-2009, 10:10 PM   #23
heinrich
928 Collector
heinrich's Avatar
The pumps that Greg and I had fail were new lasso's and both were adjusted with the 9201....
Personally I owned and used both 9201 and Kempf tools and the 9201 gave me inconsistent, non-repeatable readings evry time, so I sold it and love the Kempf tool, it works great.
Old 07-18-2009, 10:34 PM   #24
blown 87
blown 87's Avatar
Quote:
Mine gives me dead on, repeatable readings, we tested my 9201 against three of the Kemph tools and all three of the Kemph tools had different readings.
I can set a belt at 5.0 turn it 720 degrees check it again and it is going to be 5.0.
Not sure what to tell you other than no Pro mechanic that works on these cars that I know uses anything but the 9201 because it is reliable and repeatable.
blown 87 is offline   Reply With Quote
Old 07-18-2009, 11:12 PM   #25
H2
H2's Avatar
I have and trust my 9201 tool...but admittedly it's slower to use as compared with the Kemph tool. I've tested three Kemph tools against my 9201 and I had to mark my last Kemph wth a mark just barely aboved the notch. I kept thinkin I was getting bad ones. I use the Kemph for quick checks....but to the mark I filed on the tool..not the center of the factory notch. I think it's pretty well accepted, on S4s, that the proper setting is towards the high end of the notch. Set your belt to the center of the Kemph notch and you'll be running a bit loose. Obviously, it's not enough to make much difference but I think you have more of a safety factor by setting at 5.0 rather than lower.
Kemph and I corresponded on this a few years ago. With no complaints he didn't see the use in changing anything. BTW, the Kemph tool was developed while Kemph had a pre-85 928.
I also compared both gauges to the factory Porsche tool from which the Kemph tool was copied.
Where the 9201 really shines is tensioning the AC ribbed belt.
H2
*928 S4, Polar Silver, '88, 5-spd, 42K miles
*968 Cpe, Black, '94, 6-spd, 74K miles
Old 07-18-2009, 11:29 PM   #26
heinrich
928 Collector
heinrich's Avatar
Glad you like the 9201 I sold you Harvey
Old 07-19-2009, 01:49 AM   #27
Stromius
Stromius's Avatar
Send a message via MSN to Stromius
I am in process to converting to the Porken Tensioners so I guess I (will) have one surplus Kempf tool...and a tensioner (88) Anyone??
Stefan Damstrom
88 928 S4 - 5 speed Venetian Blue / Blue&Champagne
928 on Top Gear "..this is a He-Man car,it's a brute, it's a kind of thing that would go out and just eat a tractor...for fun. I wish Porsche still made it today..(Jeremy Clarkson)"
PNW 928 and 928OC member
Stromius is offline   Reply With Quote
Old 07-19-2009, 02:00 AM   #28
H2
H2's Avatar
I'm a little slow,Heinrich. I'm just now about to install the belly pan set you sold me! Keep the castoffs coming!
Harvey
Old 07-19-2009, 02:09 AM   #29
blown 87
blown 87's Avatar
Quote:
Harvey
Look on the bright side, you can work a 9201 correctly.
Old 07-19-2009, 04:04 AM   #30
GregBBRD
Hmmm.
gb
Tags
928, bird, boxster, diy, failures, greg, hole, laso, lasso, porsche, pump, pumps, replacement, stud, water, waterpump, weep
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
