928 Forum 1978-1995
Sponsored by: 928 Specialists
What is this key/crank to?
Old 07-16-2009, 01:29 AM
OrionKhan
OrionKhan's Avatar
Default What is this key/crank to?
What is this crank in the picture next to the keys? What is it called and what's it for?
Old 07-16-2009, 01:30 AM
cold_beer839
cold_beer839's Avatar
Sunroof motor, so you can close it if the motor dies.
Old 07-16-2009, 01:52 AM
The Sharkologist
The Sharkologist's Avatar
Yup, manual sunroof tool. Turns the transmission attached to the motor. Just pop off the sunroof motor cover, I honestly can't think of if there's any trick to that right now. A lot of the cars I've seen actually haven't had the cover (see avatar) and it's 1:00 AM on the east coast, and the '85 drivetrain and motor removal today wiped me out... All work and no play make the Sharkologist... something, something.
Peace,
Evan
Old 07-16-2009, 01:54 AM
OrionKhan
OrionKhan's Avatar
Thanks, guys. That's what I thought it was. I don't have one with my car. But a buddy who just got an S4 has it and I wasn't sure.
Old 07-16-2009, 06:00 PM
Hoops88S4
Hoops88S4's Avatar
I might need to get me that key soon, my motor to my sunroof has been moving real slow...
Old 07-16-2009, 06:09 PM
danglerb
danglerb's Avatar
Slow sun roof needs the tracks cleaned and relubricated.
I think that handle also works on the moving the seats forward and backwards.
BTW you know a set of keys can be made from the picture you posted.
Old 07-16-2009, 06:24 PM
Hold On
Hold On's Avatar
Remove the sunroof cover,unscrew the brass clutch screw on the transmission with the slot end of that there gizmo. Turn it around and screw the screwwy end into the now empty hole and you got a manual crank to close your room if motor/battery/ trans takes a crappola!!! Hey Im here to help LOL
Old 07-16-2009, 06:26 PM
RyanPerrella
RyanPerrella's Avatar
Q: Where was the factory location to store that tool?
I had it in my GT, never used it and it just sat in the glovebox. If i bought the car brand new, where would i have first found it? Where did Porsche put it? It doesnt go in the tool kit, where is it supposed to be stored?
Old 07-16-2009, 07:43 PM
Leon Speed
Leon Speed's Avatar
I think the glovebox. It is also the crank for the seat.
Old 07-16-2009, 10:51 PM
OrionKhan
OrionKhan's Avatar
Not my keys.
Old 10-12-2011, 01:43 PM
Ducman82
Ducman82's Avatar
how does one remove that slot/screw in the sunroof trans? or does that crank just slide in the slot?
Old 10-12-2011, 02:48 PM
James Bailey
James Bailey's Avatar
The screwdriver end removes the screw and then the thumbwheel screw goes into the hole....replacing the slotted screw.....one tool does it all
Old 10-12-2011, 03:33 PM
Ducman82
Ducman82's Avatar
i tried to use a normal screw driver... no luck. just opens the roof . i still need to find that handle.... car did not have one when i got it.
Old 10-12-2011, 10:59 PM
gmendoza
gmendoza's Avatar
So it's just lose bouncing around in the glove box?
Quick Reply: What is this key/crank to?
