928 Forum 1978-1995
Sponsored by: 928 Specialists
85 928 Throttle Switch Adjustments ??
Old 07-18-2009, 07:07 PM
wag
wag's Avatar
Default 85 928 Throttle Switch Adjustments ??
I put in a new throttle switch of late and tried to set it to where the old one was set at. It is not working up to snuff though. Somewhere I have seen the adjusting info on this in the the blogs and just can not locate it.
Do any of you guys have this info on how to go about it??
wag
85s American Edition, 5 speed
Old 07-18-2009, 08:35 PM
zoltan944
zoltan944's Avatar
I think it may be on the 928specialist.com site
I believe you only need to set it so it comes off the idle click with little movement and that you get WOT somewhere around 80% of the throttle....
Old 07-18-2009, 08:36 PM
zoltan944
zoltan944's Avatar
Old 07-18-2009, 11:59 PM
Mike Frye
Craic Head
Mike Frye's Avatar
The WOT is not adjustable. If you adjust it so that the idle switch swings to open 'just off idle' then the WOT switch is also set (which does work out to be a little more than about 2/3 throttle or so).
Old 07-19-2009, 02:45 AM
mark kibort
mark kibort's Avatar
what do you mean that its not up to snuff?
Old 07-19-2009, 11:32 AM
9two8
9two8's Avatar
.....basically it means, that it,s not doing what it should be doing.., hence the term ( Not up to snuff )
Ken
80 928 S
5 Speed
UK
Old 09-08-2009, 03:07 PM
wag
wag's Avatar
Thank you guys for the info. Adjustment was off on it as I had thought and seems to run as it always had now. Appreciate the comebacks!!!! walt
Quick Reply: 85 928 Throttle Switch Adjustments ??
