Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Old 07-25-2009, 01:57 AM   #1
Ed Scherer
Ed Scherer's Avatar
Question Need help with A/C condenser removal on '90 S4
I'm in the middle of a complete A/C overhaul and am at a point where the condenser is disconnected. I'd like to remove it to flush it, but don't know how it's attached at the bottom. It's free at the top, but there are some kind of tabs at the bottom and I can't find where the bolts might be underneath to free those tabs. The diagrams I've got show the hardware and the tabs, but they don't show or indicate where the other side of the surface is that they bolt to.
The A/C section in the workshop manuals is a mess and doesn't really provide the answer to this question (at least that I can find).
If I can't get the damn thing removed, I'll just try to flush it in place, but it really seems like I'm just two fasteners away from getting the thing out.
Ed Scherer is offline   Reply With Quote
Old 07-25-2009, 02:17 AM   #2
Rob Edwards
Rob Edwards's Avatar
Ask AND YE SHALL RECEIVE!!!!
It's a little bit more than two bolts. Pull the front spoiler and the oil cooler ducting to get to the lower condensor bolts. Not sure if the radiator needs to move, mine was out at the time.
I need to add some better keywords to the thread:
http://forums.rennlist.com/rennforum...ight=condensor
1990 928GT #278, Black/Black, C03 048 418 474 498 538 570 850 691 935 980 112K miles
1993 928GTS 5-speed, Midnight Blue/Light Gray, C02 139 340 418 474 570 586 650 691 980 XD4 XGB65L 100K miles
"If you wish to lead a joyous life, you should always spend 10% more than you earn." - Jeremy Clarkson
Rob Edwards is offline   Reply With Quote
Old 07-25-2009, 02:22 AM   #3
Ed Scherer
Ed Scherer's Avatar
Perfectamundo!
Thanks so much, Rob. I feared that it might be a lot more involved, as you've now confirmed.
"Condensor" didn't turn up in a search for "condenser removal".
Now I just need to decide whether or not it's worth getting all that crap off to get to those bolts.
Thanks big time for providing this information so quickly.
It's getting late here and I really wanted to get stuff disconnected as much as possible so tomorrow I can spend the day on compressor replacement, flushing, and resealing.
Old 07-25-2009, 02:29 AM   #4
Rob Edwards
Oops. Will have to go do some speel cheking.
Old 07-25-2009, 02:34 AM   #5
zoltan944
zoltan944's Avatar
Quote:
Your avatar also needs to change to show some progression
Sean<---My name is here so you know the fool to pity
Past
1986 944 can can N/A - sold
1982 928 auto mato used to call it fatso-sold
1988 924S auto? WTF - sold
1985 928S blk/blk 5speed - sold
1988 951 - 300hp kit from lindsey + too much to list
Herbal Remedies
Present
1984 RX7 with SBC swap
1985 928S blk/blk 5speed-
zoltan944 is offline   Reply With Quote
Old 07-25-2009, 03:52 AM   #6
Rob Edwards
[hijack] You're right, Sean- not much progress since 3PM Sunday...
Old 07-25-2009, 11:52 AM   #7
Ed Scherer
Ed Scherer's Avatar
FWIW, I succeeded in getting the condenser out last night. Thanks again for your help, Rob.
I'll also take this as an opportunity to get all the crud cleaned up that was between the radiator and the condenser now, too.
Old 07-25-2009, 01:33 PM   #8
KenRudd
KenRudd's Avatar
Send a message via MSN to KenRudd Send a message via Skype™ to KenRudd
That is a shockingly clean engine/engine bay. Nice!
Ken Rudd
'88 928 S4 Felsengrün/Grey Green AT "U-238", RMB
http://www.livestream.com/splintercellracing
KenRudd is offline   Reply With Quote
Old 07-25-2009, 03:50 PM   #9
WallyP
Rennlist Site Sponsor
"Flushing" the condensor/condenser might include more than removing metal particles and crud from a failed compressor...
I flushed the condensor from my XJS for four or five hours, and it made a real difference. The solvent was still coming out dirty after several quick flushes - the oil had apparently coked from the heat in the condensor. I set it up with a pump and pumped mineral spirits through it for several hours, and eventually got it clean.
The A/C system was more effective afterward.
WallyP is offline   Reply With Quote
Old 07-25-2009, 06:03 PM   #10
Ed Scherer
Ed Scherer's Avatar
Thanks, Wally. I just got done pulling out the old compressor; I think I'm past the halfway point on this complete overhaul. I'm pretty sure I'll be able to put everything back together about twice as fast as I pulled it apart.
Haven't got to flushing things yet; I'll be curious what that reveals. I'm hoping to be able to just do quick flushes with some flush solvent I got at NAPA.
Tags
048, 1990, 968, ac, ca, clean, condenser, ed, flush, mineral, napa, porsche, procedure, removal, rx7, scherer, spirits
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
