928 Forum 1978-1995
Sponsored by: 928 Specialists
Clutch unit removal
Old 08-02-2009, 05:55 PM
Giovanni
Giovanni's Avatar
Default Clutch unit removal
With the engine removed, how do you get the clutch unit out of bellhousing?
Help please.
Its on the 1988.
Old 08-02-2009, 06:16 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
How did you get the engine out without unbolting the pressure plate first? Crank is bolted to flywheel is bolted to PP is wrapped arond TOB and intermediate shaft. All these would have to come out first, no? Sorry, I can't visualize what you have left in the car....
Old 08-02-2009, 07:12 PM
Giovanni
Giovanni's Avatar
In the Manual page 30-10 (clutches/controls) it gives the breakdown of the assembly, to me it looks like the snap ring need to come out first.
Old 08-02-2009, 07:55 PM
Rob Edwards
Archive Gatekeeper
Gio-
So you rotated the engine and unbolted the PP from the flywheel and then pulled the engine. Huh. Since the intermediate shaft is gone, I presume the coupler that clamps the intermediate shaft and the TT driveshaft must have been loosened and slid back. If that's the case then the only thing holding the PP assembly in place is one or both of the following: 1) the guide tube (2 10mm bolts AFT of the PP, holding the guide tube against the bellhousing flanges), and 2) The clutch release arm is still hanging on the pivot ball in the top of the bellhousing
Those are the two things I'd imagine are holding you up.
Old 08-02-2009, 08:02 PM
BBX
BBX's Avatar
Man! you work quick! (want to come over and play with my 79?...lol.)
Old 08-02-2009, 08:04 PM
Giovanni
Giovanni's Avatar
Are we dismattling? I am good at that :-)
Rob, you are correct. The arm is holding the assembly. I will remove the clip tomorrow and see if some out.
Quick Reply: Clutch unit removal
