928 Forum 1978-1995
Sponsored by: 928 Specialists
Experience with velcro pad adhesive remover on vinyl dash/pod?
Old 08-11-2009, 03:12 PM
S4ordie
Not the sharpest tool in the shed
S4ordie's Avatar
Rob - Be sure to let us know how this worked out. We have 'before' pics will be good to see 'after'.
I know, I know, you always do this but I am really interested in your results as I have a number of similar issues with this same sort of residual adhesive.
Old 08-11-2009, 10:51 PM
polecat702
Vegas, Baby!
polecat702's Avatar
Martha Stewart says: " MAYO it will remove the stickum on duct tape, and everything else."
Old 08-12-2009, 12:32 AM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Active ingredient is vegetable oil.
Old 05-07-2017, 01:34 AM
michael_j_brown
michael_j_brown's Avatar
Default How I removed very difficult adhesive from my dash
I bought my Boxster and whoever owned it before me had stuck some adhesive pad to the dash – very unfortunate.
obviously I did not want to damage the dash because it's perfect except for this adhesive issue. I first tried goo gone with a Q-tip that did absolutely nothing.
here is the method I used to successfully remove adhesive from the dash with no marks and leaving the dash exactly as it came from the factory
Heat the adhesive with a heat gun on low, you should see the adhesive turn white. Be careful to not get the dash too hot.
Next, spray a small amount of WD-40 on a microfiber cloth and gently rub the adhesive to start removing it. No need to use a lot of pressure, let the WD-40 do the work
In my case, it took 4 separate times with the heat gun and rubbing with WD-40 to remove all the adhesive. Once the adhesive has been removed mist the area with clean water and lightly scrub with a magic eraser.
This method completely removed the adhesive and left my dash perfect.
Old 05-07-2017, 04:18 AM
Dave928S
Dave928S's Avatar
I've used citrus oil, which contains d-limonene, and which is probably a principal ingredient in most citrus cleaners, such as goo gone. I've also found neat citrus oil to be a brilliant cleaner/degreaser on parts, to get gunk off without using more aggressive/nasty solvents.
Quick Reply: Experience with velcro pad adhesive remover on vinyl dash/pod?
