Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Sign in using an external account
Register Forgot Password?
Search
This Rennlist Forum is sponsored by      ....dedicated to Your Porsche 928
Thread Tools Search this Thread
Old 08-10-2009, 05:21 PM   #1
Rob Edwards
Rob Edwards's Avatar
Default Experience with velcro pad adhesive remover on vinyl dash/pod?
I'm finally turning attention to the GTS. A brilliant PO stuck some sort of electronic gizmo on top of the pod using a 3" square velcro adhesive pad, which is still tightly stuck to the (vinyl) pod. Any thoughts about how to get it off and clean up the adhesive without affecting the vinyl? The pod and dash are otherwise perfect, so I'm afraid to try goo-gone/acetone/xylene/gasoline/napalm without some BTDT reassurance.....
To remove this ad, register today or login if you already are registered!
1993 928GTS Midnight Blue/Light Gray, C02 058 130 139 218 239 323 340 403 418 423 437 438 464 474 481 484 537 553 562 567 570 573 586 595 602 650 691 912 980 XD4 XGB65 105K mi
1988 S4 5-speed, White/White, C03 158 220 418 474 481 494 513 538 570 586 650 91K mi
There's no "O" in VIN.
928 Option Codes List, Current as of October 2013 Here: https://webfiles.uci.edu/redwards/pu...2010-7-13.xlsx
Rob Edwards is offline   Reply With Quote
Old 08-10-2009, 05:35 PM   #2
zoltan944
zoltan944's Avatar
3M adhesive and wax remover has given me previous success on similar problems, although your velcro is still on there so I don't know how much you will need to keep spraying to remove? Fishing line to remove velcro? maybe add some light heat?
zoltan944 is offline   Reply With Quote
Old 08-10-2009, 06:01 PM   #3
danglerb
Super User
danglerb's Avatar
The problem may be that there isn't just one type adhesive used with velcro. Start at a corner with maybe a needle or hobby knife and raise it up to get a look at what was used.
danglerb is offline   Reply With Quote
Old 08-10-2009, 06:06 PM   #4
Darien Nunn
Darien Nunn's Avatar
WD-40 was introduced to me years ago to remove tape glue residue. Just spray some on a rag and gently wipe off the residue...It's oily so it won't dry out the mating surface...it's also good for removing stickers from windshields/windows
Darien
Palmdale, Ca
1986.5 Shark (Rocket)
475 RWHP / 502 RWTQ
Darien Nunn is offline   Reply With Quote
Old 08-10-2009, 06:14 PM   #5
Rob Edwards
It's really goopy/tacky stuff, I'll pull up a corner and get a photo to illustrate. A real mess!
Old 08-10-2009, 06:23 PM   #6
danglerb
Super User
danglerb's Avatar
Heat and peel, then work on cleanup.
Old 08-10-2009, 06:26 PM   #7
dr bob
The Doctor is IN
dr bob's Avatar
Rob,
I'm that same PO and have little Velcro pads to hold the dash rug in place. Denatured alcohol takes the adhesive off. This is with the gooey black adhesive. If you have the yellow or white adhesive it's a little more of a challenge.
WD40 is essentially mineral spirits (actually closer to Stoddard solvent) ith some light oil added. A little won't hurt the dash vinyl if you don't get too aggressive. You will want to carefully pull the velcro part off first if you can so the solvent can do its job.
'89 S4 Auto, black
928OC Charter Member #81
SoCal 928 Co-Founder #3
PCA SGVR Member
Free advice and shared experience, with absolutely no relationship to your real-world conditions. No warranty of any kind expressed or implied. Use at your own risk.
Last edited by dr bob; 08-10-2009 at 08:49 PM. Reason: have a real keyboard now...
dr bob is offline   Reply With Quote
Old 08-11-2009, 01:32 AM   #8
Richter12x2
User
Richter12x2's Avatar
When I'm worried about the surface, I typically start with rubbing alcohol. If that won't cut it, a little dishsoap should take it off. In either case, it's going to dry it out, so immediately go back over it with your vinyl/leather conditioner of choice - even Armorall in a pinch would be better than letting it set dry.
Richter12x2 is offline   Reply With Quote
Old 08-11-2009, 02:43 AM   #9
Rob Edwards
Here's the goo, looks like the pad has been sliding down the pod for a while:
Click the image to open in full size.
Old 08-11-2009, 10:21 AM   #10
Darien Nunn
WD-40
Darien
Palmdale, Ca
475 RWHP / 502 RWTQ
Old 08-11-2009, 10:48 AM   #11
auzivision
auzivision's Avatar
Two words... Goo Gone
Great stuff; perfect for this type of work.
http://www.amazon.com/MAGIC-AMERICA-.../dp/B00006IBNJ
It's available everywhere
Kurt
Guards Red 1987 S4 Auto, RMB, Turbo Twists, Apline, MB Quarts, and Murf Stage 1.25
Personal email: Auzivision'at'Yahoo.com ('at'=@)
http://www.linkedin.com/in/auzins
auzivision is offline   Reply With Quote
Old 08-11-2009, 12:45 PM   #12
RyanPerrella
Super User
RyanPerrella's Avatar
ryanperrella porscheconnect ryanperrella porscheconnection
Quote:
I like the fishing line idea, I dont think you need it for this but ill try and remember that.
RyanPerrella is offline   Reply With Quote
Old 08-11-2009, 01:01 PM   #13
ew928
Owns the Streets
Needs Camber
ew928's Avatar
They even got the orange goo gone at Staples.
Cap has a built in mini plastic scraper.
Ernest (NYC)
88S4 5-speed LSD
ew928 is offline   Reply With Quote
Old 08-11-2009, 01:43 PM   #14
auzivision
auzivision's Avatar
If you use Goo Gone (it’s a citrus solvent) it will make short order out of that project. At most you might need some sort of scraper. Old hotel room keys or credit cards work great… much less chance of damaging anything than using a metal blade.
This stuff is also great for removing bugs and tar and it smells much better than the kerosene based stuff. Also takes off bumper stickers, dealer decals, price tags, etc. Just about any kind of sticker or tape residue is no match for this stuff.
I have it on my shelf right next to the Kriol, PB blaster, WD-40, Bug & Tar remover, Isopropyl, Acetone, Lacquer Thinner, Paint Thinner, and Bleach. I always try this stuff first and it rarely lets me down.
Kurt
Old 08-11-2009, 01:52 PM   #15
Rob Edwards
Thanks guys. I have the shelf o' goops too, with the big can of Goo-gone, I was just afraid of its effects on vinyl. Will give it a shot tonight.
Paid Advertisement
Tags
3m, 928, adhesive, dash, glue, pad, pb, plastic, removal, remove, remover, removing, velcro, vinyl, wax
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
