classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#16 |
928 Barrister
Rennlist Member Join Date: Sep 2002
Just in time for me. That seems to be the next item to replace in my search for a leak free system. So far, my plastic bottle is holding pressure, but it is a matter of time before it needs to be replaced. My problem now is the sensor which is set off easily for no apparent reason. I jump out to check the level and it is right up there, but the dash light is on. $#*%&$^#@!!!! Maddening!
I don't need a sight glass. I am accustomed now to removing the lid and looking in, or I can devise a measuring rod I can keep handy for that purpose.
Ron 1986.5 928S 1970 914/6 1995 900SE Saab Luau feet 'Let the fear of danger be a spur to prevent it; he that fears not, gives advantage to the danger.' - Francis Quarles (1592 - 1644) "Far better it is to dare mighty things, to win glorious triumphs, even though checkered by failure, than to take rank with those poor souls who neither enjoy much nor suffer much, because they live in gray twilight that knows not victory or defeat." Theodore Roosevelt |
#17 |
Super User
#18 |
Rennlist Member Join Date: May 2002
Carl -
Will the version with sensor interfere with the Murf kit intercooler? Don T . .
Don T. '87 S4 black/black KLAUS ~ S/C w/IC Murf kit #6 ~ F & R sway bars (928 SP) ~ X-pipe (928 SP) ~ Carrera III wheels |
#19 |
Rennlist Member Join Date: Nov 2003
Any chance to make one for a right hand drive car?
Dan 1990 928Gt |
#20 |
Rennlist Member Join Date: Feb 2003
Im all for transparent aluminum, or sight glass.
![]() Otherwise, cool.
Mark Kibort 1987 928S4 - Holbert Race Car Replacement Project. http://video.google.com/videoplay?do...67&q=928+video Laguna Seca SCCA ITE race with Comp Coupe Viper http://www.youtube.com/v/Sih48Dby9d0 TV Highlights http://videos.streetfire.net/video/5...bdf5891242.htm viper race http://video.google.com/videoplay?do...55778690778093 HP vs Torque: http://forums.rennlist.com/rennforum...5-post246.html |
#21 |
Rennlist Member Join Date: Aug 2003
Carl,
Any chance you have played around with this to see if an additional unit can be fitted somewhere under the hood? It looks like a great intercooler reservoir as well if 2 can be fitted. Thanks Hans
-1989 928S4 Auto, Diamond Blue, full Paul Champagne interior and twinscrew installation in the works -1985 500SEL AMG 5.0L 32v |
#22 |
Rennlist Member Join Date: May 2009
I love the look of welded sheet aluminum parts! Very trick...
B. B. |
#23 |
Developer
Rennlist Member Rennlist Site Sponsor Join Date: Dec 2001
Thanks Dave.
Most fellas will replace the old plastic bottled just cause the aging and cracking. But - if you run a racer or a supercharged 928 there is a secondary benefit. I think we can agree that heat is a byproduct of work performed and gasoline burned. The more HP you produce, the hotter your engine will become. The first place that water boils in most engines is in the head(s) right around the exhaust valve seats, and is often the insult that causes a failed head gasket. Should the water boil in a pocket like around the exhaust seat, the steam generated is very high pressure and frequently at the root of many a post race/DE-day head gasket repair. The pressure of the coolant system (provided by the radiator cap) and the ethylene-glycol are the two items at work to raise your boiling point to prevent this from happening. And if you have a race car - the glycol is gone and the pressure in the system is all you've got. If you have replaced your plastic-tanked radiator with one of ours, then you can add this all-aluminum coolant reservoir and safely add a 20 psi radiator cap. The extra pressure will add a margin of safety to your supercharged or race engine to prevent the coolant from boiling. Both our all-aluminum radiators and our coolant reservoirs are tested to 37 psi before shipping. They can operate at 20 psi indefinitely without harm. Fun Facts: A 16-lb. cap will raise the boiling point 48 degrees higher than the normal 212 degree boiling point. A 20 pound cap adds another 12 degrees to the boiling point.
Carl Fausett Member SAE 928 Motorsports, LLC Visit our Website - get a Free Catalog! Click here! |
#24 |
I currently depend on a peek and the sensor - I don't need a sight glass - my $0.02...
Don T . .
#25 | |
Developer
Quote:
BTW: we tested it and it holds exactly the same amount of fluid to the ml.
#26 |
Super User
Dang snap frack. Just a couple of months too late
![]() Dan '91 928GT S/C 475hp/460lb.ft
#27 |
#28 |
Rennlist Member Join Date: May 2001
I agree, my reservoir is so opaque now I can't see through it anyhow. Pop the top, takes two seconds.
#29 |
Ordered 1...
Don T . .
#30 |
Rennlist Member Join Date: Jan 2003
Hmmmm.....Only $35 more than the stock reservor I was thinking about ordering today. Hmmm.....
It would be cool to have a dual chamber reservor-one for intercooler and one for engine.
'79 928 5 speed cab w/euro S hybrid motor(on stands for 1 yr) '88 928 S4 rogerbox (daily driver wanna be) '91 944 5 speed cab (daily driver) '55 speedster replica (perpetual project) |
| Tags |
| 2004, aftermarket, black, boxster, cap, cayenne, concours, coolant, fluid, focus, ford, nc, pine, pipe, porshe, radiator, replace, reservoir, spruce |
| Thread Tools | |
