Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Old 10-16-2009, 09:41 PM   #1
kaptnknemo
Bumbling Neophyte
Default Remove Upper Bellhousing Bolts?
How? I can barely get a 12 pt 19mm wrench on them and I can't get no satisfaction. Already soaked them in PB Blaster, but they aint budjing.
TIA KK
KaptnKnemo
1986 928S (vin 0268)
The Black Pearl
Black/Black
AV 300+HP!
kaptnknemo is offline   Reply With Quote
Old 10-16-2009, 09:46 PM   #2
SeanR
SeanR's Avatar
Send a message via Yahoo to SeanR
A really long 19 is what I use. Not much room in there.
http://www.928srus.com/
Anotherplace
'88 S4
•• Law of Mechanical Repair - After your hands become coated with grease, your nose will begin to itch and you'll have to pee.
SeanR is offline   Reply With Quote
Old 10-16-2009, 09:47 PM   #3
GlenL
Super User
GlenL's Avatar
You need a flexible-head ratchet, a 19mm six-point socket and 3 feet of cheater bar.
GlenL is offline   Reply With Quote
Old 10-16-2009, 09:59 PM   #4
Mrmerlin
Petie3rd
Mrmerlin's Avatar
Sears has flex head gear wrenches that you can lock in a bent position this is a great tool to get the bolts loose, you can use a 19mm wrench on the other end if you need more leverage
1988 S4 Elfenbein Perlglanz with a full Pearl Gray leather interior, Auto
Mrmerlin is offline   Reply With Quote
Old 10-16-2009, 10:22 PM   #5
Lizard931
Lizard931's Avatar
I use a regular 19mm wrench and then snipe it with another 19mm wrench. I never have issues breaking them free. Once the first turn or two has been done they always come out with my fingers.
Colin J
JDS Porsche Western Canada Supplier.
Don't steal, the government hates competition!
1981 928S Euro, S4 bumper caps, 86 engine, currently undergoing MASSIVE changes.
1987 928S4 Auto
1987 928S4 5 speed
They ALL have the porkensioner!
Lizard931 is offline   Reply With Quote
Old 10-16-2009, 11:32 PM   #6
blown 87
blown 87's Avatar
What ever you do make sure the wrench is held on there good, if it slips and rounds the head off, you got a problem.
I have a guy use a long bar hold the wrench on so it can not come off at a angle.
blown 87 is online now   Reply With Quote
Old 10-16-2009, 11:56 PM   #7
Big Dave
928 Engine Re-Re-Rebuild Specialist
Big Dave's Avatar
I wasn't able to get them off when I did my engine rebuild. I pulled the engine out with the bellhousing still attached.
1985 928S Auto Black/Black, Chipped, Ott X-over - reborn twice!
1983 911 SC Cabriolet - SOLD
2005 Acura TL
My 928 Home Page
928 Owners Club - Michigan Chapter
Big Dave is offline   Reply With Quote
Old 10-17-2009, 12:46 AM   #8
Shark_Week
Having recently needing to remove these, i feel for you. i tried everything mentioned here. what ended up working was taking a torch and heating my box wrench and bending the wrench exactly where i wanted. it took a couple tries but it's perfect now and i'll have it for next time.
Martin G.
1993 928 GTS- 5 speed Black on Black
Shark_Week is offline   Reply With Quote
Old 10-17-2009, 04:33 AM   #9
kaptnknemo
Bumbling Neophyte
thanks, looks like i'm of to k-mart, opps sears as soon as they open, I have a 19mm from them with the right angle, i think i'll get another and rotozip the open end off so my torque intensifier will fit over it.
KK
KaptnKnemo
The Black Pearl
Black/Black
AV 300+HP!
Old 10-17-2009, 08:11 AM   #10
Mike Frye
Craic Head
Mike Frye's Avatar
Quote:
That's the ticket. For those of you following along at home: (I've never heard this term before either) I assume 'sniping it' means to use the open end of the one on the bolt with the box end of another wrench of a similar size. Those bolts are a b!tch. After you break them free, a 19mm gear wrench will do the trick.
I think Bill Ball had a write-up about this from when he did the rear main seal. I'd do a search on that.
HWFM Racing: Official Team Power Tool Expert
1985 grey shark (222k mi, over the hill and picking up speed)Porkenized!
Rear seat delete/Porken s300s chips/55psi FPR/Lomas )(-overs/shortened shifter, Snorkel filters
1998 Mustang convertible
...Waiting for forums.rennlist.com...
Mike Frye is offline   Reply With Quote
Old 10-17-2009, 09:12 AM   #11
Mrmerlin
Petie3rd
Mrmerlin's Avatar
Just googled this.
GearWrench 19MM XL Locking Flex Combination Ratcheting Wrench
( 0 Reviews ) | Sold by Sears Item# 00993141000 Model# EHT85619
$32.99
Old 10-17-2009, 09:43 AM   #12
RyanPerrella
Super User
RyanPerrella's Avatar
here is a cool one for you, try and follow me here
step 1 ) Ok 19mm combo wrench on the bolt with the box end (fully round) on the bolt and the open end now in the air
step 2) now 19mm is very close to 3/4" so now take a 3/4" breaker bar and use the square portion which you would usually plug a socket onto and insert that into the open end of the 19mm combo wrench. This is a tight enough fit that you can use allot of torgue on the long 3/4" breaker bar and it will go through the wrench and pop that bolt free.
Install isnt as difficult, the standard length 19mm wrench should allow you to get the recommended torque on the bolt when you tighten
I wish i had a picture of this little trick
RyanPerrella is offline   Reply With Quote
Old 10-17-2009, 01:25 PM   #13
Mike Frye
Craic Head
Mike Frye's Avatar
Old 10-17-2009, 02:48 PM   #14
kaptnknemo
Bumbling Neophyte
Default Problem solved!
After an unfortunate incident involing a roto-zip, the cut off end of a $10.99 19mm craftmans wrench fit nicely into a 1" water pipe 2ft long. Passenger side was a piece of cake, on the drivers side I had to remove the FPR. It only took 1/10 of a turn to lossen them up.
Thanks for the help!
KK
KaptnKnemo
The Black Pearl
Black/Black
AV 300+HP!
Old 10-17-2009, 04:25 PM   #15
Schocki
Schocki's Avatar
That's what I used
Schocki
1991 944 S2 cobaltblue aka "Mario"
1972 911 T Targa geminiblue aka "Shelley"
1992 928 GTS amazongreen aka "Sharky"
It's not the speed that kills you, it's the sudden stop
Schocki is offline   Reply With Quote
Tags
356, 40, bell, bolt, bolts, differential, engine, housing, loosen, porsche, rear, removal, remove, removing, upper
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
