Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Old 10-19-2009, 09:55 AM   #1
StratfordShark
StratfordShark's Avatar
Default Help identify connector under centre console!
So this morning I found that the cabin temp sensor showed open circuit. I need to check if it's the sensor or connections to it which means removing centre console.
having done this before I know that though there seem to be lots of connectors, almost all are unique/colour coded so it's easier than it looks to put things back. Even so I've been labelling some connectors as I undo them just to speed up re-assembly.
While I'm freeing up the harness wires to the window/sunroof switches, I notice this 6 pin male connector. I'm almost certain it's not one I'd disconnected, and I can't find a mating connector hanging around.
From the colours does anyone have an idea what it could be for? The cable joins into the very thick loom that snakes up and behind the dash.
My only guess is that's it's wiring for rear aircon (don't have it), but would be reassuring to have a definite ID! The wiring colours suggest grounds, and switched/x-bus 12V supplies?
1991 S4 Auto Amazon Green
StratfordShark is offline   Reply With Quote
Old 10-19-2009, 11:34 AM   #2
John Speake
John Speake's Avatar
Check against circuit diagram ?
John '86 Euro S2
SharkTuned LH & EZ-F
www.jdsporsche.com
Home of the SharkTuner
Rebuilt LH, EZK ECUs & MAFs available from agents worldwide
Diagnostic testers for all models of Porsche 1987 >
John Speake is offline   Reply With Quote
Old 10-19-2009, 11:54 AM   #3
StratfordShark
Tried that first John but didn't help. Only candidates were an airbag connector in central console (91 not equipped, but may have been option?) but wires didn't match. Ditto the wiring diagram lists one other 6 pin connector in centre console for aircon but the colours don't match my orphaned plug.
Old 10-19-2009, 12:11 PM   #4
Tony
Tony's Avatar
Send a message via AIM to Tony
Alarm wiring? I think that is up under the glove box though? The alarm bypass on my car was a yellow and black wire ..but..only a two pin connector if i recall ?
Tony1987 S4 Auto
SuperCharged
Click for my 928 Webpage
My PcarOnline Profile
448 Rwhp - 422 Rwtq
0-60mph 4.4sec
Tony is offline   Reply With Quote
Old 10-19-2009, 02:05 PM   #5
John Speake
How about "T24 Trailer coupling" - location "under the central electric" ?? Sheet 9, option code M208.
I claim the prize !!
John '86 Euro S2
www.jdsporsche.com
Old 10-19-2009, 03:41 PM   #6
Mrmerlin
Petie3rd
Mrmerlin's Avatar
Well if there is a prize, my suggestion is ,that connector looks like it gets connected to the lock button panel on the console
Reference Sheet 11 location 99 E Central locking button panel
1988 S4 Elfenbein Perlglanz with a full Pearl Gray leather interior, Auto
Mrmerlin is online now   Reply With Quote
Old 10-19-2009, 04:25 PM   #7
John Speake
Good one Stan !
John '86 Euro S2
www.jdsporsche.com
Old 10-19-2009, 04:43 PM   #8
Mrmerlin
Petie3rd
Mrmerlin's Avatar
OK so who wins the prize??
OP are you there???
What is the prize,
who said there was a prize,
why would you offer a prize.....
....... Where is the prize patrol..... LOL
Old 10-19-2009, 04:49 PM   #9
StratfordShark
Sorry John, prize goes to Mr Merlin.
When i disconnected the central locking/aircon panel I was surprised that there was only 1 connector (the write-up I was following referred to another) but thought little of it. I put the panel in the parts box and now taking a look there is a socket on umbilical. The wiring colours in the plug match the wiring diagram.
Come to think of it I hadn't tried the central locking button since buying car in April, so had no idea that button wasn't working.
Last one in there hadn't reconnected it. I know someone's had the console out in past because one of the tabs that clicks into base of shift lever is broken, and has been repaired by glueing in a bolt! Everything else was re-connected ok though.
Old 10-20-2009, 06:20 AM   #10
John Speake
Ok, that's good :-)
John '86 Euro S2
www.jdsporsche.com
Tags
964, connector, dash, wire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
