View Poll Results: Have your say, do you like the flutes?
Voters: 43. You may not vote on this poll
Functional body change what do you think?
I posted this in the Carbon Thread, just in case others are interested here's the pics. Also just in case others can/want to photoshop this properly just let me know.
The piece that needs to be welded in.
So what do you think? I plan to actually use the vents, it can be used for coolers and aerodynamic advantage as high pressure develops here.
Greg
Greg
Cottage Industry Sponsor
Why would you want to open up an area that seals-in and protects the components mounted under the fender, when there really is not any reasonable way to connect it to the engine compartment for ventillation?
I'd rather install a belly pan from a later model, along with an adapter piece in the front.
By Flying Dog
Give that man a beer, you are correct.
I also think it has a distinct shark like character. The high pressure air will be ducted through coolers mounted in that area. I also plan some small bonnet ducts that release the high pressure and hot air from under the bonnet. It is referred to a zero drag cooling.
Greg
Duct high presure air from the wheel well to reduce drag, increase downforce (or reduce lift) and improve brake cooling.
Greg
I don't like it - it clutters up ther clean look of the sides of the car. If it is being added strictly for a racing function, then have at it - that is different, since all cars that are raced are modified in ways that often detract from the original aesthetics but add to functionality deficiencies in order to go faster at the track.
Not the sharpest tool in the shed
Purely functional to me. The appearance, though "gill-like" and therefore "shark-like as well looks over stated for the car IMO.
Seems like you would have to move a number of things from that area as indicated by Nicole.
As a racing adjunct, yes definitely.
I like the looks. It works especially with the pre-S4 style rear spoiler and with the rub strips removed.
On functionality.
I thought that the area behind the wheel well had a relatively low pressure, lower than typically under the hood or on top of the hood right in front of the windshield. The air would be flowing out of those fender vents, if the other side has the underhood pressure. Perhaps this is what you wrote anyway and I just misread it.
I also thought the spinning wheel causes a low-pressure area inside the wheel well. At least in front of the front wheel, there's a low pressure area. Perhaps it's different behind the wheel, but doubt it. Just punching it thru to the wheel well may not generate much flow. You'd have to duct it to the engine compartment somehow.
In my opinion, for a normally aspirated car, the best way to cool front brakes is cut a hole in the bumper under the headlights (a high pressure area) and run a duct to brakes. It might also be beneficial to duct the hot air out from the top of the fender in the low pressure area.
The hood vents work for sure as long as they are not too close to the windshield. I am wondering if you've photoshopped an example of those yet?
On functionality.
I am also a little unclear as to the brake cooling benifit of these vents. it seems to me that it will actually decrease brake cooling as I under stand it to work. To cool the brakes the vented rotor acts similar to a cetrifugal compressure (think inlet side of a turbo). air that enters the center of the brake rotor is slung out through the vented section of the rotor where it comes into contact with the rim. the rim then using the same principal slings the air out through the slot in the rim to the outer edge where it exits to the outside. in order for this to work you want to get as much air flow into the center of the brake rotor, decteasing the pressure inthe wheel well and encouraging the inducted air to exit through the fender will decrease the flow through the brake.
First: I have had a glass or two of red wine. That gives You honesty and gives me a headache in the morning.
Second: I think it is a non-solution to a non-problem (the automotive industry is full of it). Additional cooling/venting. Why would You want that ? To my knowledge, the stock venting is adequate, provided that things work as intended.
That leaves the design change as a cosmetic thing and should be judged as such. My judgement: Spend the money on regular maintenance or renewing suspension parts. On any 928 those are the areas that can be improved the most. At least in 95% of the cases.
Ragnar
Ragnar
