Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Old 11-07-2009, 01:39 AM   #1
starcms
User
Default Unknown Electrical Connector under Hood
I was replacing my heater control valve today and some vacuum hoses, and I noticed an odd looking electrical connector under the hood. It's below the master cylinder and was hanging and leaning right against where the fender meets the firewall.
It measures 0V on ACC and 1.5Vish on ON. The connector is solid black rubber, round at the top with the two prong connectors as on a typical car fuse and narrowing down towards the bottom and goes into the wiring harness entering the cabin by the master cylinder. Everything electrical on the car works and it runs great (for now lol). What is this for? Maybe for an auto tranny?
Sorry for no pics. Its a US '78 928.
starcms is offline   Reply With Quote
Old 11-07-2009, 02:07 AM   #2
76FJ55
Maybe the plug for the brake pad wear indicator. It is round with two blades on it. the sensor then has the two female blade connectors that plug onto it. there is a clip on the back side of the shock tower that it should be mounted in if that is what it is. the easiest thing would be to trace the wires from the brake pad sensor and see if it is connected.
76FJ55 is offline   Reply With Quote
Old 11-07-2009, 03:31 AM   #3
starcms
User
That must be what it is. The P.O. told me he had "cut" all of the brake pad wear sensors and I had never noticed them any sensors nor any electrical wiring around the calipers.
Since the plug is there (assuming the other 3 are there too), could new sensors simply be installed or are more parts needed?
Old 11-07-2009, 11:18 AM   #4
joejoe
User
just need the new sensors,
joejoe is offline   Reply With Quote
Old 11-07-2009, 04:10 PM   #5
ZEUS+
ZEUS+'s Avatar
What color are the wires ? Is the brake pad warning light on ?
1988S4 Auto w/89 low gear trans, LSD, X-Pipe, RMB, AFPR, AAchips, 18's
1984S 5spd Drove it hard,now with Juvius
ASE Master Technician
Associates in Automotive Technologies, NHTC 1983
ZEUS+ is offline   Reply With Quote
Old 11-09-2009, 12:05 PM   #6
76FJ55
The pad wear system would have to have been shorted somewhere to keep the indicator light from being lit continuously. If you find where the PO shorted the system you should be able to revive it by undoing the short and adding the pad sensors back into the system.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
