Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Old 11-07-2009, 01:44 PM   #1
syoo8
syoo8's Avatar
Default Nicole/Jager LED Instrument Pod Illumination Question
Do LEDs burn out?
I installed the Jager/Nicole LED kit into my instrument pod (86.5) and the right LED started flickering, then went out, followed by the left, followed by the center. Is there such a thing, or do I have a bad connection in there?
Scott
'86.5 928S (Guards Red/Black)
'97 986 (Silver/Black)
syoo8 is offline   Reply With Quote
Old 11-07-2009, 02:54 PM   #2
Gtaebr
Gtaebr's Avatar
Connection would be my guess. Did you try fiddling with the dimmer wheel?
Joe
86.5 Garnet Red Metallic
Gtaebr is offline   Reply With Quote
Old 11-07-2009, 02:56 PM   #3
syoo8
syoo8's Avatar
Just pulled the instrument pod and tested each LED by hand with a 12 volt power supply-- each of them are dead.
Did I get unlucky with a bad batch of LEDs, or is there something happening in my electrical system to burn out LEDs?
Scott
Old 11-07-2009, 02:59 PM   #4
Gtaebr
Gtaebr's Avatar
What voltage do you get at the sockets?..... Could be bad LEDs but rule everything out first.
Joe
Old 11-07-2009, 03:01 PM   #5
syoo8
syoo8's Avatar
I don't know what voltage at the sockets because i had to pull out the instrument pod to get at the LEDs. However, when I feed 12 volts through pin 16 and 17 (ground) I get 12 volts at the sockets, so there's nothing weird happening there.
Scott
Old 11-07-2009, 03:06 PM   #6
Gtaebr
Gtaebr's Avatar
Check voltage on the car side of the pod connector to be sure.... Sounds like they failed....Nicole/jäger are great at customer service shoot em a line or call, they will take care of you.
Joe
Old 11-07-2009, 04:01 PM   #7
syoo8
syoo8's Avatar
Dissected the LED, which had a 270 ohm resistor soldered in. (The resistor was hidden by white tape which I cut out.)
I don't know what the LED current is of the Jager illumination kit but most LEDs are 2 mA, 10 mA and 20 mA. If that is so, the resistor necessary would be between 500-5600 ohms.
In other words, if the LED current is between 2 and 20 mA, then the wrong resistor was installed into the kit, which resulted in the LEDs blowing out. I am going to the store right now to buy replacement LEDs and resistors to see if this solves the problem.
Scott
Old 11-07-2009, 07:06 PM   #8
Nicole
Nicole's Avatar
When did you purchase, and when did you install them?
PM or email me, if you got them through me.
Nicole
'91 928 S4, slate grey metallic / all classic grey, GTS mirrors, 17" 'Turbo Twist' rims, Custom Wood Interior Trim
'00 9-3 SE, silver metallic (zzZAABi)
This one after I won the lottery
Clear/smoked lenses, books, and accessories:
www.HookedOnCars.com
New:
Porsche 928 Book by Brian Long
Smoked lenses and marker lights
AutoArt 928 1:18 and 1:43 Scale
Nicole is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
