928 Forum 1978-1995
Sponsored by: 928 Specialists
Oil in the water. what does it mean?? UPDATE: WATER IN THE OIL TOO!! :(
Old 12-30-2009, 12:01 AM
  #61
inactiveuser1
inactiveuser1's Avatar
Originally Posted by M928
Not sure if it would help.I had someone do some heads before and went to far in porting didnt know it till after.
From a radiator shop I borrowed a tool to pump up the air pressure into the the water system while the radiator was in the car.It screws on where the radiator cap goes and puts pressure into the whole water system while the car is off.I could see water come up the intake port and fill the intake.Not sure that would help depends where the leak is.Once you get it back in and if you still have the problem pump the whole system up.Then take the plugs out and crank the motor over,if any water is in the sytem under pressure that is getting into the cylinders it should fly out of the spark plug hole.With the one cylinder I tested the water hit the ceiling in the garage!That may check the heads if anything getting into the cylinders.Then I left it under pressure could see water slowly coming up the intake port till it started filling the intake.It was on a different style motor but was a new race motor.
Originally Posted by mark kibort
That's why I turned the engine over without the plugs in. But, i think the problem is in the headgasket, but not around the fire ring. Ill do a leak down and that might show something there as well.
Hopefully its only the gasket.I like using the permatex copper head gasket spray depending thou on the type of head gasket.
Old 12-30-2009, 12:09 AM
  #62
blown 87
Rest in Peace
blown 87's Avatar
I used spray hylomar on my Cometic's, not sure if you can find it any more, I got the last few cans at the warehouse.
Old 12-30-2009, 12:43 AM
  #63
inactiveuser1
Not sure if they had it on their site.
This place shows some at:
http://www.partsplaceinc.com/product...=526&sku=18945
If this is the same one?
This was the other copper spray.
http://www.permatex.com/products/Aut...ve_Sealant.htm
Used it on head gaskets,motorcycle side cover gaskets instead of silicone.
Few light layers on each side seemed to work good.
Let it tack alittle put another layer on etc so it doesn't drip.
I have put as much as 4 to 5 light layers on each side for head gaskets.
Like it says in ad Fills minor surface irregularities. Seals instantly. Fills hot spots and surface imperfections.
Old 12-30-2009, 01:25 AM
  #64
mark kibort
mark kibort's Avatar
Mark find a shop with a chemical tester called Block Check, they are cheap to buy and cheap to use.
It will show if you have combustion chamber gasses in the cooling system.
Seems like every time some one thinks head gaskets the first thing that is suggested is a compression test, I have seen MANY, MANY blown head gaskets that would only show up with a chemical test.
For what it is worth.
Greg
thanks greg. Yep, done that with scots when it was pushing out water from the overflow. barrs stop leak doesnt stop that kind of leak, but it does stop it from seeping out the heads or out of a radiator. I would think that the issue I have is from the gasket or warping of the heads (or a crack) based on what we are seeing . (oil in the water, slightly, and lots of water in the oil).
How hot did it run?
Were the heads retorqued after it had been ran?
What was the finish on the block and the heads?
I doubt you have a head gasket problem unless it has been ran hot.
It ran great, in the new chassis, except for the bad (cracked) distrib. cap where it was backfiring during accel. heads were not retorque after it ran, that is near impossible and not needed with a 928, but with cometic, who knows. for a full season and a half of racing, there has been no issues at all.
the finish on the heads and block were over the 50RA recommeded surface quality. Yes, the engine ran hot during the testing in the new chassis, as the red light came on after the gauge only read a little over 3/4. I believe the warning light! But, that was only for a few seconds, and that might have warped something.
Originally Posted by dr bob
M928--
He has water in the oil, and suspects that there's a leak between the water jacket and one of the oil galleys via either a crack or a head gasket failure. Your advice is tsill sound, but instead of looking for oil in the intake or a cylinder, the coling system could be pressurized with the tester, with the oil sump plug out. Water will find its way to the sump via an oil passage if there's a gasket failure. Cracks change size with heat though, so you may not find a leak through a crack with this method unless it stays open when cold.
Remember, most of the water ran into the oil after it was cooled down, so maybe I do that test with no oil and the plug open and see if it leaks. too bad I cant dye the water different colors for each side and see what color comes out.
next I think Ill fill it with cheap oil and run it with barrs stop leak to see if I can stop the water seeping. now, the oil might be a different issue, or maybe the same passage. the Barrs works on the water exiting the breach, and doesnt keep stuff from coming in . so the oil might push open the hole and the water will leak out again or if it seals it enough, maybe it will stop the oil as well. I have a feeling its a warping around the high pressure passage.
Old 12-30-2009, 01:26 AM
  #65
blown 87
Rest in Peace
blown 87's Avatar
Yea, that is the same one, but there was a problem with some, they ended up with thousands of spray cans that had a lot of solvent and not much hyolmar in it, there was a lot of finger pointing and no product being shipped or sold, but that was a year ago.
Hylomar is some really good stuff.
I hate RTV and like Hylomar.
Old 12-30-2009, 02:33 AM
  #66
inactiveuser1
Thanks for posting the Hylomar also and the info on it.
Old 12-30-2009, 01:02 PM
  #67
mark kibort
is this the only hole that feeds the heads under full pressure?
(little round hole next to the oil return passage to the lower right of the head)
Old 12-30-2009, 01:10 PM
  #68
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,464 Likes on 1,461 Posts
yes
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 12-30-2009, 02:26 PM
  #69
mark kibort
So, if that is so, then the breech might be between this hole and the water jacket when running, and when off, a slow drip leak of water back in through that hole, or over to the oil return passages.
ahhhhh!
mk
Originally Posted by GregBBRD
yes
Old 12-30-2009, 08:41 PM
  #70
SharkSkin
SharkSkin's Avatar
So, the radiator came back from the shop with no issues. they did replace the "O" ring on the oil cooler, but the cooler didnt leak under the pressure test.
Unfortunately this only proves that you don't have a huge leak -- it doesn't prove that there is no leak in the heat exchanger. It could be leak-tight when cold but it's possible for a crack to open up and leak only when hot.
Old 12-30-2009, 09:02 PM
  #71
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
ahhhhh!
mk
No. Never seen or heard of this....even with Cometics.
Fret about a different path.
Old 12-30-2009, 09:13 PM
  #72
SharkSkin
SharkSkin's Avatar
...run it with barrs stop leak...
Old 12-30-2009, 09:24 PM
  #73
jcorenman
jcorenman's Avatar
So, if that is so, then the breech might be between this hole and the water jacket when running, and when off, a slow drip leak of water back in through that hole, or over to the oil return passages. ...
Entia non sunt multiplicanda praeter necessitatem
Cheers,
Old 12-30-2009, 10:21 PM
  #74
blown 87
Rest in Peace
blown 87's Avatar
Mark, I am pretty sure you can take one of your cooler hoses off the engine and loop it back into the inlet, taking the cooler out of the things you are testing, all that will take is a little time and some fresh oil.
I am with Greg Brown, I doubt you have a head gasket issue.
The chances of it leaking just to the high presure port in the block and the water jacket are slim, at best, with no other signs of a head gasket leak.
EDIT, never tried this on the car, but I did have mine looped when on the engine stand.
Old 12-30-2009, 10:37 PM
  #75
davek9
davek9's Avatar
+1 "The chances of it leaking just to the high presure port in the block and the water jacket are slim, at best, with no other signs of a head gasket leak. ".
I would lookd at the cooler first too.
Quick Reply: Oil in the water. what does it mean?? UPDATE: WATER IN THE OIL TOO!! :(
