classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat     |
Sign in using an external account
| This Rennlist Forum is sponsored by | ![]() | ....dedicated to Your Porsche 928 |
Thread Tools | Search this Thread |
#1 | ||
User
#2 |
Rennlist Member Join Date: Feb 2004
Sounds like blowby, meaning the engine is worn. A compression and leak down test will confirm this. The compression test should give even readings on all 8 cylinders, within a couple of PSI of each other. The leakdown test will tell you where you are losing compression, probably the rings in your case. Most likely you have an engine rebuild or an engine swap in your future. Joe
#3 |
Super User
#4 |
User
are you supercharged?
#5 |
Rennlist Member Join Date: May 2008
I had a similar situation with a 1964 Chevrolet I bought in Oklahoma a long time ago. It was blowing oil out all over the engine when I was driving it back to Colrado. It was coming out of the filler as I recall. I took the car to someone and they said the exhaust gas recirculation valve was clogged up. He replaced it and no further problem.
I don't know how the 928 engine recirculates the crankcase gas, but some recent posts suggests that there is a similar set-up. Figure that out and see what it takes to clean that system out and I suspect your problem will be solved. It might be, however, that that system is clogged up because of blow-by from worn rings as previously suggested, but I have my doubts unless you car has an awful lot of miles. Jerry Feather |
#6 |
Super User
#7 |
Rennlist Member Join Date: Sep 2004
I would do a compression-leakdown test to make sure the rings are still good.... "if" they are then make sure you get a correct dipstick that fits with enough tension...I've found many early style dipsticks are far too loose
"think all cops are bad....try living in a world without them!" Brian Co-founding member of the "Stockton Sharks Society" 79 racer "Casper" 5spd, 265whp 289torque 2624lbs 10 Silverado (tow rig) 13 Scion FR-S FUN commuter!! ![]() ---------------------- 84 auto "Estate" racer 215whp 256torque, 2800lbs 08 M3....gone but not forgotten 88 S4 Guards Red/Champagne Leather (gone to a new home) 89 S4 5 speed track beast!!!! BLACK WIDOW (gone..dead)
#8 |
Super User
My truck would push the dipstick out when it had four cracked pistons, but only at WOT.
#9 |
User
I've done that in my truck on a really cold morning when I stepped on it and the crankscase vent hose was kinked.
#10 |
Rennlist Member Join Date: Apr 2003
I doubt it is a collapsed vent hose, but is possible.
I concure that a leakdown test would be best.
Colin J 1981 928S Euro, 1987 928S4 Auto 1987 928S4 5 speed Koni 1000/600, Stage II cams, Aluminum flywheel, dual disc Stage 3+ Spec clutch, Crankcase vacuum pump, CT4 6767 custom mid mount turbo @ 5.8PSI 408/400+, Really loud horn! PM me for services/parts. |
#11 |
Rennlist Member Join Date: Dec 2004
I had to get a new rubber for my 80 a while back. There was nothing wrong with the engine. I might have gotten a whole dipstick, it really was a while back.
#12 |
Moderator - Cracklin' Rosie
Lifetime Rennlist Member Join Date: Aug 2001
Both of my 928's do this because the O-Ring on the dipstick is so worn out (add that to the "must buy" list...)
Leakdown / compression is spot on for both engines. Jean-Louis came up with a slick spring hold down for his track car since it kept popping out.
_ _ _ Individual rights are not subject to a public vote; a majority has no right to vote away the rights of a minority; the political function of rights is precisely to protect minorities from oppression by majorities (and the smallest minority on earth is the individual. - Ayn Rand |
#13 |
Super User
| Tags |
| air, blowing, car, dip, dipstick, engine, hood, oil, range, rover, saturn, shot, smoke, smoking, stick, yukon |
