928 Forum 1978-1995
Sponsored by: 928 Specialists
My son's 1980 repaint begins.
Old 05-25-2012, 11:57 AM
  #631
77tony
77tony's Avatar
Those rear seats look very comfortable and look great. Wish I were a bit smaller so I could actually fit back there ! Great job Dean. T
Old 05-27-2012, 02:32 PM
  #632
Dean_Fuller
Dean_Fuller's Avatar
I had pulled the stock insulation out of the car before paint because it was moldy and dry and held water big time. The damaged insulation was mainly on the flat surfaces like the floor board and back deck. I left the stock stuff on most of the transmission tunnel and firewall. I never felt good about just putting carpet on the metal floor boards and I knew I could not afford the good stuff like DynaMat....so I picked up some cheap commercial carpet at Lowe's with a rubberized backing and tight looped weave. Cut and fit it as needed and glued it down so it should help with sound, some heat and vibration. Total cost...$28.00
Now I will have a soft flat area for the new carpet to sit.
I Know this maybe a little too red neck for some here.. ...but you don't see it after the carpet is installed and its got to be better than nothing.
Old 05-27-2012, 03:02 PM
  #633
AirtekHVAC
AirtekHVAC's Avatar
Looks good dean. In my case, the sound deadening, and old carpet caused some severe rust due to a water leak the PO did not address...I will be cutting out some floor pan area and welding in new steel...interested to see how the carpet works out for ya!
Old 05-27-2012, 08:29 PM
  #634
pcar928fan
pcar928fan's Avatar
Dean, I bet that will work just fine!!!
Old 05-27-2012, 09:37 PM
  #635
FLYVMO
FLYVMO's Avatar
Dean, your doing great, I am very impressed. You may want to check out Eastwood's "Dynamat equivalent" which sells for $129.00 each if you buy two boxes. But even one box covers around 33 square feet which should be enough for the floor boards and more, sells for $149.00. A lot cheaper than Dynamat which is way overpriced.
Keep up the great work!
Cheers!
Carl
90GT Project
Old 05-27-2012, 10:05 PM
  #636
BigAl1
BigAl1's Avatar
Nothing wrong at all with finding creative solutions - looks good!
Old 05-28-2012, 01:00 AM
  #637
FLYVMO
FLYVMO's Avatar
Absolutely nothing wrong, and I hope I did not come across as implying it. Just wanted to pass along some inexpensive yet effective options to the very overpriced Dynamat
Cheers!
Carl
90GT Project
Old 05-28-2012, 04:40 AM
  #638
Podguy
Podguy's Avatar
There are a few places that sell an equivilant to the original mat. Closed cell foam over dynamat kills the heat and sound and gives a nice base for the rest of the interior. I think you might find some out gassing problems with commerical carpet. Generally automotive carpet follows a different spec than household carpet.
Old 05-28-2012, 08:58 AM
  #639
BigAl1
BigAl1's Avatar
Good info there Carl - Thanks!
Old 05-28-2012, 09:36 AM
  #640
Doug&Julie
Doug&Julie's Avatar
Originally Posted by Dean_Fuller
...so I picked up some cheap commercial carpet at Lowe's with a rubberized backing and tight looped weave...
We actually use something very similar in the exhibit industry...we call it "wall rib" or "acoustical wall fabric"...we put it on conference room walls as sound deadening material. So, yes...it should work well for you!
Old 05-28-2012, 12:48 PM
  #641
depami
depami's Avatar
Looks great Dean. It will certainly suffice for carpet backing but may do little or nothing for sound deadening and blocking heat.
The work you’ve done on this car is amazing. Don’t take this wrong, but, you don’t want to skimp on this. It will be a real pain to redo after everything is put back together.
That is a totally different application. You are keeping the sound from bouncing off the walls and around the room, not from coming through the walls.
I agree with that.
Here is some basic stuff.
http://www.acousticalsolutions.com/s...-damping-sheet
http://www.b-quiet.com/hliner.html
http://www.jcwhitney.com/universal-s...erid=c2673u0j1
http://www.edesignaudio.com/product_...c0f2daeac37ce0
Interesting.
http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
Be sure to check this out!
Insulation from Home Depot
http://www.team-integra.net/forum/19...nsulation.html
Just my thoughts.
Keep up the good work. We can’t wait to see it finished.
Cheers,
Denny
Old 05-28-2012, 04:11 PM
  #642
Dean_Fuller
Took Denny's advice and went to Lowe's. Bought 2 rolls of Freeze King Duct insulation. $40.00 and some change. Pulled the carpet up and laid this under it on the metal floor board. I replaced the carpet so the new carpet will not slide around. I did glue the gray carpet to the shiny side of the insulation. This insulation is easy to work with and I WILL DEFIANTLY use it inside both door.
Back to putting the fuse panel back in and then figuring how the rest goes back together. If anyone has good photos of the wire routing, vac tube connections I could sure use them as mine were lost in a computer crash. I do have the PET printed and of course the manuals.
Old 05-28-2012, 06:37 PM
  #643
pcar928fan
pcar928fan's Avatar
VERY COOL! This car is going to be SOOOO AWESOME when finished! I will probably steal it... Just sayin'!
Old 05-28-2012, 10:46 PM
  #644
Dean_Fuller
Tomorrow I hope will get a lot done thanks to BigAl1...I had lost all my photos I had taken while disassembling Marvin over 2 years ago due to a computer crash. Allan was kind enough to take time to resize and email about 120 VERY detailed photos for me to use in the dash / firewall area. It will be a HUGE help and I just wanted to thank him publicly. What a HUGE weight off my shoulders as I was about to freak the fudge out! This is a great community we have here.
THANKS again Allan...I owe you big time...as I do a few others here!
Old 05-28-2012, 11:29 PM
  #645
pcar928fan
pcar928fan's Avatar
Yea, the owners both here on RL and in the 928 Owners Club REALLY are what make owning a 928 special! The cars are great and all, but that only gets you so far...the people are what really make it just THE BEST!
Quick Reply: My son's 1980 repaint begins.
