928 Forum 1978-1995
Sponsored by: 928 Specialists
Update on the 86 Mossgreen Metallic 5 speed
Old 05-23-2010, 12:57 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,243 Likes on 1,241 Posts
Default Update on the 86 Mossgreen Metallic 5 speed
I am in the middle of a refurb on an 86 5 speed. it has about 180K miles and seems to run pretty good it has a Louis Ott X pipe and 2 1/2 in pipe all the way to the back.
The brakes were toast and the LF spindle was blue so here are a few pictures
Old 05-23-2010, 01:48 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
A couple of notes. First the car is an early 86 no sunroof no side strips,
the first pictured spindle is the new replacement part, the second is the blued unit.
This car appears to have come with the longer rear studs and slide on factory spacers, I am also installing new rear shocks,
and replacing the front adjusters for the shocks as they are frozen,
car came with a new recovered vinyl dash and the pod was redone by Rob Budd.
I am searching for a new used leather console as the original is pretty well hacked up
Old 05-23-2010, 01:55 AM
pcar928fan
pcar928fan's Avatar
Looks like the put a hole in the center of the main dash too...
That is standard on the long studs on the factory S cars...all of mine have had the slide on spacers.
Will be a great save when you are done. That center console does looked hacked up...nice try at a Keith Widom center console, but I give it a Fail unfortunately!
Old 05-23-2010, 02:01 AM
Landseer
Landseer's Avatar
Sounds like a candidate for the Jerry Feather console.
Old 05-23-2010, 02:41 AM
Nicole
Cottage Industry Sponsor
Nicole's Avatar
Hi Stan: That looks like a nice project for you!
Did you paint the whole brake discs, and let the pads scrape away what's not needed?
That interior looks like quite a challenge. It's an interesting hodge podge of vinyl and leather covered items, and the pod cover is "off" at the top. I hope you can make it nice and clean looking again!
Old 05-23-2010, 05:35 AM
danglerb
danglerb's Avatar
What are the rectangles below the instruments on the pod?
Old 05-23-2010, 09:48 AM
surfridermason
surfridermason's Avatar
Location: Philadelphia, PA , USA The Great Fighting City of Brotherly Love
sweet. no roof
Old 05-23-2010, 12:00 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Mike ,they were for an O2 read out and boost pressure as the PO was going to supercharge the engine.
too bad they are coming off.
when driving, light is reflected on them and back at the driver, its a distraction.
Nicole the rotors are called coated they are done this way to prevent corrosion anyway on the instructions it mentions to not clean off the coating the brake pads will do that I dont know what the coating is it doesnt look like paint.
Greg N. suggested to clean it off so the pads wont get damaged but i will try following the MFG instructions and if needed clean the pads after the car is driven
Old 05-23-2010, 02:07 PM
cfc928gt
cfc928gt's Avatar
Stan, glad to see you made it home with the new project. What did it take to get it running?
Old 05-23-2010, 02:45 PM
SQLGuy
SQLGuy's Avatar
Love that color!
Old 05-23-2010, 04:57 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
I had to install the engine harness at my friends shop it took about 5 hours to RnR the wires, engine cranked right up and ran steady.
amazing what a good set of wires will do.
Old 05-23-2010, 05:32 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
More pictures, RnR of the dash what a mess of wires this car is I hope that I can figure it all out, note the dangling wires from the roof
Old 05-23-2010, 05:49 PM
Landseer
Landseer's Avatar
Keep the pictures coming!
Old 05-23-2010, 06:02 PM
Nicole
Nicole's Avatar
This car has never been in better hands!!!
I don't know, if there is a simple front bumper fix short of a full respray, but the smaller chips might become much less visible with the Dr. Colorchip touch-up paint. This stuff seems to work well on darker colors, but not on silver.
Old 05-23-2010, 06:24 PM
docmirror
Shameful Thread Killer
docmirror's Avatar
Did you go to the later big brakes in front?
Quick Reply: Update on the 86 Mossgreen Metallic 5 speed
