928 Forum 1978-1995
Sponsored by: 928 Specialists
Head gasket
Old 10-20-2010, 12:54 AM
928fan4life
928fan4life's Avatar
Default Head gasket
My buddy is doing a rebuild of his 928 engine. he has a 4.7L M28-11 euro block and was going to put on a set of rebuilt 4.5L US heads. Does he get a head gasket for a 4.5L US or a 4.7L euro or does it matter?
Old 10-20-2010, 12:59 AM
namasgt
namasgt's Avatar
you need 4.7, cylinder wall has a bigger inner diameter.
Old 10-20-2010, 01:34 AM
928fan4life
thought so, thanks for confirming
Old 10-20-2010, 01:48 AM
gbgastowers
gbgastowers's Avatar
Location: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
If you want to wait before you put those 4.5L heads on I have 2 sets of heads and cams in cam carrier for a Euro S 4.7L . One set is off of a 1982 M28/11 and the other set is off a 1980 M28/12.
I am in the process of deciding which set to use and soon the extra set will be for sale. Your friends Euro S motor will be a lot better with these heads and cams especially if you have the Euro S intakes. 300HP. Gunar
Old 10-20-2010, 02:06 AM
928fan4life
His car is a 4.5L US Model L-Jet. Would complete euro motor drop in or will there have to be changes made?
Old 10-20-2010, 05:04 AM
danglerb
danglerb's Avatar
Easiest option, keep the intake and injection and put them on the Euro block and heads, should have a nice bump in power, but with a truncated top end.
Find a set of 84/86 Euro S intake and fuel injectors and marry that to the Ljet brains and air flow meter. You might need an adjustable fuel pressure regulator to "tune" the air/fuel ratio.
Middle option with Jjet air flow meter replaced with a MAF and either use a MAF calibration box (John Kuhn worked out how to do this for his turbo package), upgrade to 85/86 brains and sharktune.
Quick Reply: Head gasket
