928 Forum 1978-1995
Sponsored by: 928 Specialists
Widest tire on a 928
Old 01-02-2011, 11:24 AM
Exotic_Car_Guy
Exotic_Car_Guy's Avatar
Question Widest tire on a 928
I bought a set of Porsche Carrera IV wheels with the following dimensions:
Front: 8 x 18 et 57
Rear: 10.5 x 18 et 60
What would be the right tires for my '85 928S? I'd like to go widest possible in the rear 10.5" wheel without rubbing (and closest to orig overall wheel/tire diameter).
Thanks,
Gil
Old 01-02-2011, 11:29 AM
123quattro
123quattro's Avatar
295/30. It will be a squeeze to get it in there.
Old 01-02-2011, 12:08 PM
LostInSpace
LostInSpace's Avatar
Very interested to see what these look like on the car.
Old 01-02-2011, 12:16 PM
Exotic_Car_Guy
When you say a squeeze, will there be rubbing with suspension travel during driving (bumps, etc.)?
Gil
Old 01-02-2011, 12:35 PM
dprantl
dprantl's Avatar
They will probably fit, but you will need a ~5mm spacer with those 60mm offset rear wheels. Also, you may need to pull out the rear fenders just a little, but that is quite easy since they are steel.
Dan
'91 928GT S/C 475hp/460lb.ft
Old 01-02-2011, 12:59 PM
tlsmith1999
tlsmith1999's Avatar
285/30/18 with no spacers will fit nicely.
Old 01-02-2011, 01:07 PM
SeanR
SeanR's Avatar
There will also be a difference in width, depending on tire brand. My wheels had P-Zero's 295/30/18 on an 11.5 rim and rubbed like crazy. Put on my Kumhos of the same size, I now have 1/4 inch more room between the fenders/tire than I had previously. They my say they are the same size, but there are a lot of variations on side wall width.
The following 2 users liked this post by SeanR:
dzaprev (04-15-2020), hacker-pschorr (04-13-2020)
Old 01-02-2011, 01:47 PM
Gretch
Range Master
Pepsie Lite
Gretch's Avatar
Received 1,234 Likes on 754 Posts
Side to side suspension tolerances are NOT the same........ one side is always tighter than the other.......
I run 275x35x18s on the rear of my 89 GT and one side is definately closer to the fender than the other.
Old 01-02-2011, 01:56 PM
Exotic_Car_Guy
Thanks guys for all your inputs.
Gil
Old 01-02-2011, 05:11 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by Gretch
Sid to side suspension tolerances are NOT the same........ one side is always tighter than the other.......
I've noticed the same thing too. I thogth it was probalby caused by an accident at some point in the car's life but, mabye it isn't.
Old 04-13-2020, 09:23 PM
Zimoludek
Zimoludek's Avatar
Default Max Tire size on 19s
Will my 79 928 fit a 245 35 19 in the front and 285 30 19 in the back. No spacers.
Thanks,
Adam
Old 04-13-2020, 10:44 PM
Bigfoot928
Bigfoot928's Avatar
Old 04-13-2020, 11:14 PM
slownrusty
slownrusty's Avatar
I think there is a happy medium in there but I don't see the need to run anything 275 or wider in a 928 unless you're putting down north of 450 wheel power. At 275 and larger with the bigger wheels(for example 18") that is a ton of inertia.
just_drive (04-14-2020)
Old 04-14-2020, 05:45 PM
Drewshepard60
Drewshepard60's Avatar
What about 16" rims?
Old 04-15-2020, 09:26 AM
WALTSTAR
WALTSTAR's Avatar
I have 225 and 255-16's front and rear on BBS wheels. rears have a stock spacer cut down 5mm and they do not rub whatsoever
Quick Reply: Widest tire on a 928
